Netbook keyboard -unlock
Netbook keyboard locked
  • 7,627 Answers
It would be helpful if you posted the Make ,Model, of laptop.
Posted on May 02, 2013
Testimonial: "Thank You. I'll try doing this what you advise. Funny enough i was wondering if i could connect it up to an external keyboard/typepad, there are several plug-ins on the netbook,so will try this main typepad( my main pc) and see what happens.I've ordered a mouse too, then hopefully will be able to get around much quicker. I noticed today that on somethings it does type, just the caps lock/or numbers lock remains frozen.There is no real manaul with the device, so that i can troubleshoot. But will try what you said. Many Thanks for your help.Much Appreciated. Kindest from pennine:-)"
2 Suggested Answers
  • 6771 Answers
SOURCE: eee pc900hd keyboard lock
Hook a external keyboard to the laptop, if okay! unless you have pressed something that locked it down, the laptop keyboard will need to be changed. But if both have same problem you may have a virus, device driver issue. If mouse pad works try a system restore before this occured.
Posted on Mar 19, 2012
Unlock keyboard
If you are booting your laptop and cannot use the keyboard, it is likely the keyboard may be faulty. Try a USB keyboard to test the system.
Nov 20, 2013 | Advent Netbook
How to replace a keyboard on a hp Mini 1000
HP Support > HP Mini 1000 CTO Netbook > Main Support page,
http://h10025.www1.hp.com/ewfrf/wc/product?product=3832471&lc=en&cc=us&dlc=en&lang=en&cc=us
Before I go on.........
HP = Manufacturer
Mini 1000 = Model Series
The actual Product Number (Model Number) is on the Bottom of the Netbook, in a white Service Tag. P/N = Product Number.
However what is going on here, is we are just looking for the Service Manual.
It covers the HP Mini 1000 series of Netbook PC's........
In the list click User Guides.
Now click on -
HP Mini 1000 and Compaq Mini 700 - Maintenance and Service Guide
[Ignore if you are aware;
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the above file name, it may take up to 30 seconds, before the first page comes up.
Go to the top left corner, and click on the Toggle Slider icon, to see the Bookmarks menu.
When your mouse cursor is hovered over the icon, Toggle Slider will briefly appear.
To the top left now, will be the Show Thumbnails icon, and to it's right; the Show Document Outline icon. Click on the Show Document Outline icon ]
Scroll the Bookmarks menu down.
Under the subheading - Component replacement procedure -
click on - Keyboard.
Or go to Page 48 using the Adobe Reader page number box, at top. (Actual manual page is 40)
A) Remove ALL power. Remove the AC adapter, (Charger), and Battery.
B) Suggest lay a soft static free cloth on the table, you are working on, then laptop on it.
Prevents scratching the table, and laptop. (Netbook)
Turn the Netbook over, bottom side up.
Look down in the Battery Compartment. There are two Philips head screws to remove, which hold the Keyboard in place.
Looking across the Width of the Battery Compartment, draw an imaginary line in the middle.
One screw to remove is in the Middle, and towards the Front of the Netbook.
The other screw to remove is also in the Middle, and towards the Back of the Netbook.
C) Turn the Netbook over to it's normal position.
Open the Display Assembly. (Open the Netbook)
There are FOUR small TABS formed out of the Keyboard, that are on the side you are on. Also known as the Front of the Netbook.
These Tabs slide down into the Palm Rest Cover.
It is for THIS reason, that when removing the Keyboard, DO NOT bring the Keyboard straight up.
It is also for the reason that the Keyboard Cable, will still be attached to the motherboard.
The Keyboard Cable STAYS attached to the Keyboard.
The Keyboard Cable is disconnected FROM the motherboard connector.
Also on EACH side of the Keyboard, is a Tab.
Grasp the Keyboard at this Side Tabs, and lift the Keyboard up on the LCD screen side; at a slight angle. (1 inch height, or so)
Slide the Keyboard towards the LCD screen, until the Tabs on the Keyboard that are towards you; are clear of the Palm Rest Cover.
Then lay the Keyboard down on the Display Assembly.
(That last sentence is straight out of the service manual.
I <- would advise covering the LCD screen, to avoid any possible damage)
The Keyboard Cable is now disconnected from the motherboard's connector.
The Keyboard Cable is a type of FFC. Flat Flex Cable.
A general example of an FFC,
http://en.wikipedia.org/wiki/File:Flat-Flex-Cable.jpg
As you can see the Keyboard Cable will have NO connector.
Also the flat terminal bar connectors on the Flat Flex Cable, are to go back to the original position in the motherboard connector.
The Keyboard Cable MUST, go back in the same position it was originally; in the motherboard connector.
Each flat terminal strip on the Keyboard Cable, lines up with a specific contact pin in the motherboard connector.
This is what you use to determine, how the new Keyboard's Cable will be mounted. By following the old one.
The motherboard connector is a type of ZIF connector.
Zero Insertion Force.
It is rectangular in shape, and composed of two pieces.
HOWEVER, it does NOT come completely apart!
The bottom piece is the larger of the two parts. It is Stationary to the motherboard. It is called the BODY.
The upper piece is the smaller of the two parts. It is Movable.
It is called the Locking Bar.
IF, the Locking Bar is broken, or IF the Body is broken; you are looking at MOTHERBOARD REPLACEMENT, and why I am being so detailed with this.
There are a few styles of Locking Bar types used.
Looking at the Service Manual, I cannot exactly determine which style is used.
No matter because I will show two styles used, that I believe the Mini 1000 uses one of them. (For the Keyboard Cable)
Flip-Up style:
Closed; (Locked),
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L645D-L640D/big/laptop-disassembly-13.jpg
Open;(Unlocked),
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L645D-L640D/big/laptop-disassembly-14.jpg
Suggest just ease open with the thumbnails.
Slide style:
Closed;(Locked),
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L675D-L670D/big-body/dismantle-laptop-10.jpg
Open;(Unlocked),
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L675D-L670D/big-body/dismantle-laptop-11.jpg
With this style, all you can make out is two 'tabs', of the Locking Bar, because the Keyboard Cable is in the way.
Suggest use thumbnails to ease the Locking Bar up.
Distance is ONLY 2mm. That is a little more than 1/16th of an Inch.
Sometimes after a Keyboard Cable has been in a locked position, for a long time; the Keyboard Cable seems to be stuck.
GENTLY wiggle it side to side, then see if you can remove.
If not, then suggest check the Locking Bar, and see if it is in the Open/Unlocked position, all the way.
For additional questions please post in a Comment.
Or click on Reply at end of solution, and post.
Regards,
joecoolvette
May 18, 2013 | HP Mini 1000 Netbook
Hi I have just tried to set up my son's ocean netbook. I seem to have locked the keyboard somehow!! Any assistance would be greatly appreciated.
Locked as in it doesn't accept input? Some laptops will have physical buttons on them for disabling the touchpad and keyboard. Please list the make and model if you need further help.
Thanks
Jan 26, 2013 | Computers & Internet
Eee pc900hd keyboard lock
Mar 19, 2012 | HP Mini 110-1037NR Netbook
How to unlock keyboard
I just think you accidentally locked your keyboard and touchpad by pressing the function key!
Just press: FN + F6
this will unlock the keyboard and touchpad!
Thanks
Nov 30, 2011 | Acer Aspire One D260 Netbook
My hp keyboard is locked but the mouse pad works perfectly fine. How do I unlock the keys?
If you can go to [start] then right click on [computer] then [manage] then [device manager] ... Ok there should be keyboards listed & a little + or arrow next to it... Click on it then find HID keyboard device... Right click on it and UNINSTALL it! Then once uninstalled RESTART system... Should be repaired.
Any doubts you can get in touch with a technician through
www.thebestpcdoctor.com
Toll Free: 877 407 9229
Aug 28, 2011 | HP Mini 1000 Netbook
My keyboard locked on my hp mini laptop. how do i unlock it?
plug in an external keyboard, then you can get into the bios
Feb 27, 2011 | HP Mini 1000 Netbook
My keyboard is not working.. is there a way to lock and unlock it?please help.. thank you very much...
No, there is no option to lock and unlock it. First, try restart your laptop. See if it works, if it doesn't go to Acer website under support and locate your laptop. Download the latest firmare for BIOS and install it. If that doesn't fix the problem, you either have a loose connection on the keyboard or it is faulty. You will have to take the keyboard out, usually has only to clips at the top line around F3 keys and one similar on the other side.
Jan 04, 2011 | Acer Aspire One Netbook 8.9" Notebook
My keyboard and mouse ar locked
COUCL BE CAUSE BY THE function key(fn) key and lock key (mostly f6 just find for the lock icon) press this key combination again to unlock fn+f6 to unlock you keyborrd here is a small digram to help you
please rate this solution........
Apr 11, 2010 | HP Mini 1000 Netbook
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
