Question about NorStar M7310 Corded Phone
Canceling call forwarding from one extention to another
We have a phone extension that will ring 3 or 4 times and then forward to another internal extension. How can I cancel that forward, and send an unanswered call to voice mail?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 110 Answers
On the extension that is forwarding use Feature #4 to cancel the call forwarding unless it is programmed under the capabilities section in programming. This will require someone with programming ability to make the forwarding change back to the voice mail access number.
Posted on Feb 09, 2014
  • 3 Answers
SOURCE: Nortel M7310 phone
Feature **266344, PW: 23646, Press top arrow until you can enter your ext. Press the top arrow again until you see "Fwd no answer" and press top arrow again until you see "Fwd to: None" and choose change. Enter your VM box. Press the bottom arrow (down) on right and see "Forward Delay" and change that number then press rls.
Posted on Mar 28, 2008
  • 6 Answers
SOURCE: Voicemail
It sounds like you are using a voicemail service from a provider, meaning you did not buy the voicemail system with the phone system. If you confirm, I can tell you how to fix this.
Posted on May 13, 2008
ynotphone
  • 192 Answers
SOURCE: Unanswered calls will not go to voicemail
Ok, do you know how to get into system programming?
If you do:
-> first dial FEATURE 985 this will give you the DN(Extn) for the voicemail
-> get into programming
-> TERMINALS&SETS enter and put in the extn that is giving you issues
-> then under CAPABILITIES look for FWD NO ANSWER and put in the DN of the voicemail you saw with the Feature 985
-> hit next for the number of rings you want it to ring before going to voicemail
-> hit next and you can now RLS to back out of programming.
Voila, that set will now goto voicemail.
Posted on Mar 25, 2009
consultel1
  • 860 Answers
SOURCE: m7310 rings on 2 extentions
Sounds like the main phone(221?) has an answer dn key on it.
To delete the answer dn key you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wantdelete the answer dn key from.i.e. if entension 223 is also ringing on 221 enter 221.
Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
Press the next key (bottom right arrow) 4 times .
The display say ANSWER DNs.
press the show key (top right arrow)..
The display should ask for an answer dn number.
Press the SCAN key (one of the three soft keys near the display)
The extension that was ringing on this set should be listed here.
Press CHANGE til it says UNASSIGNED.
Press the release key when finished
Posted on Mar 26, 2009
SOURCE: Forwarding a busy phone
you'll need the programming template that goes over the phone keys if you're not familiar with programming...
feature **admin (use #s on dialpad)
type admin again
select #6 permissions
enter set (ext)# you want to forward
scroll down to "forward on busy" & select
you'll see "forward to" hit the "change" button
enter in the extension # you want it to go to when busy
then select to store
Posted on Apr 16, 2009
How to stop / edit all incoming calls ringing to other 2 extensions at the same time?
What phone system are you using?
I will gladly show you how
KX-TEA/TES/TA series or KX-TDA/TDE/NCP series
Oct 25, 2015 | Panasonic KX-T7633 Corded Phone
Express messenger number of rings
This is a "Class Of Service" function. The out-ot-box default setting is generally 3 rings. However, different extensions can be set to each forward to VM after differing number of rings, but each phone will need to be assigned its own specific Class Of Service and the Call forward timers defined accordingly in those classes of service. Normally your system manager will define several classes of service with different forward-no-answer timers then assign those COS to people who request specific call forward timing. The default is usually 3 rings. Hope this helps
Mar 10, 2014 | Mitel Superset 4150 Phone
I'm not sure if the problem is the phone set or the PBX. I have programed the phone set to forward all calls to extension and it works great. But I can not get it to toggle the forwarding on and off...
Check out the instructions for setting forwarding no answer. *7104 xxx # sets the forward and the time it requires to forward is settable in the *713 ss where ss is the number of seconds from 00-99.
A ring cycle is 6 seconds, so 24 would be about 4 rings. Once you set forwarding, you really don't have to cancel it, as even if someone is on the phone, the call waiting and display tell you who is calling and you have the timer time answer or ignore the call.
Carl
Feb 15, 2011 | Panasonic KXDT333 Phone
Norstar M7208, it's direct line number is diverting to another ph
It could be a simple as the phone has call forwarding to another extension set up on it or the direct line could also be programmed on the other set. Does the screen on the non- ringing m7208 display "forward to:xxx" or does it display the current day and time?
Jul 01, 2010 | NorStar M7310 Corded Phone
Voicemail is not picking up for incoming calls...
Sounds like you need to set the call forward no answer to the VM pilot DN for the set with the new mailbox.
May 26, 2010 | NorStar Startalk Flash 2 Phone
HOW TO CANCEL A DIVERT FROM ANOTHER EXTENSION NUMBER
no you cannot prevent this from the attendant console.aa is not normally set up.your installer needs to change the class of service of your extension to stop forward no answer. if the other phone/office is unoccupied try leaving it off the hook,your own phone may not want to forward when the other one is busy...i hope this helps
Dec 16, 2008 | Nortel MERIDIAN M2250 ATTENDANT CONSOLE...
Changing amount of rings when going to voicemail
The call forwarding was turned off. To turn on, press speaker, enter 793, press 1(for set), press extention number, and enter 300. If you have call forwarding on and are looking for more rings, do the above steps except press 2 (for clear).
Nov 19, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Forwarding calls between extensions
Yes, press Feature 4, then enter the extension of the line you wish to forward the ring to. You can also go into the phone configuration to forward after a set # of rings. To ring another extension at set times you will need admin access.
Jul 02, 2008 | Nortel Meridian M7208 Corded Phone
Answering machine
Your phone can be programmed to transfer a call to different places and have different rules for day-ring mode and night-ring mode.
Sounds like what you want to do is change your phone to transfer to another extension instead of your voice mail box. This would in effect eliminate your voice mail box because a call would never automatically be sent to it unless you use (and program correctly) night mode.
Your phone model type does not help resolve this. You can have this phone on different Panasonic phone systems. You will need to determine which phone system you have and locate "programming" manual for the specific system (not a user guide)
There should be a section or option called "no-answer forward", "forward timer", "forward extension" etc...
Dec 13, 2007 | Panasonic KX-T7630 Corded Phone
NorStar M7310 Corded Phone Logo
154 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Computer Repairing
Computer Repairing
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
