Question about Canon iR 2016i Black and White Copier
What is the course of the wasting of the powder on the paper when the printer is coping
  • Canon Master
  • 1,294 Answers
Fusing unit.
Posted on May 01, 2013
When powder is wasting on the paper what could be the problem?
The image fixing fuser unit dont work.Check the pressure roller lever and the fusing unit heater lamp and the upper and lower rollers.
May 01, 2013 | Canon iR2018N
I just read that random dots being printed on the left side of all my documents means that i need to change the toner. I just changed the toner last week or the week before. Is this something that I call...
Hi
Well not often the problem is same, usually the toner cartridge will have 2 bins 1 is the hopper which holds the un-used powder and the other is the Waste toner bin which holds the waste powder. When it is full and there is no place to escape then the powder spills on the paper. But if this happens then you can just bang your toner lightly and in this was the air pockets in the powder is clear and spill will stop automatically.
PLEASE RATE MY SOLUTION
Jul 06, 2011 | HP LaserJet 1020 Printer
Why does my samsung scx5530fn printer constantly prints blank sheets of paper...we have turned it off/on; changed toner and it just decides to starting printing blank pages..anybody can help me i thank...
Please clean the drum and the fuser, also check the toner cartridges if there's any overflown toner powder spilled. The problem is caused when the toner waste tank in the drum is full or overflowing.
Good luck.
Thanks for using FixYa.
Jun 25, 2010 | Office Equipment & Supplies
We can duplex copy but not duplex print on the KM Bizhub 250. When printing from the computer, in the Konica Document Properties Window on the Layout tab, when the Print Type pull down screen is activated...
Hello
See if you have selected weight paper from the tray in the duplex mode.
Weight paper is selected in duplex mode only from the bypass.
So you check that the paper in the tray 1 or tray 2 must be plain paper and in duplex mode it can print normally.
Jan 29, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Waste tank powders.
It is not good to inhale the waste toner, it is a combination of all the color and black toners, saved in one convenient bottle.
Jun 29, 2009 | Samsung CLP-550N Laser Printer
Black line on left side of paper
inside the printer on the paper pulling roller there will be some powder got collected on it due to this a black line appears on the paper.the power faLLS FROM THE TONER WHEN THE WASTE POWDER COLLECTING SECTION IN THE TONER GETS FULL SO IT FALLS on the roller while printing and this happens.take a air blower .bolw in to all the parts of the printer.keep the printer off .remove the toner cartridge.and keep the toner assessing door opened.and then blow the air in the printer.and then check out.
Feb 09, 2009 | HP LaserJet 3055 All-In-One Printer
My HP Laser Jet (color) 1600 is printing color on pages with no color!!
the wastage part of ur pink toner is full a is dropping the powder on paper.get it cleaned to continue good printing.wish u success
Jun 04, 2008 | HP LaserJet 1600 Printer
Waste Tank Full - Solid Red Light
Technically you do have to buy a new toner tank (they come in packs of 3, Harvey Norman normally stock them), however the carefull application of a vacume cleaner (use disposable vacume bags to do this, cloth bags don't filter well enough) to the full waste tank can at least double its life if not more. You will only be able to do this 2 or 3 times but in a pinch it will let you resume printing for a while. It allso helps to clean the optical sensor windows (their the only optically clear plastic bits on the cartridge so hard to miss) with a cotton bud (a DRY cotton bud). You will need to clean both sides of the window portal from the inside of the wate tank as well. Bending one end of the cotton bud at a 90deg angle will help when doing this. It's fiddly and potentially very messy work if your not carefull so be prepared to make a mess and most importantly keep the vacume nozle near the opening of the waste tank to **** up the super fine waste toner powder.
As for if this is just your printer wasting toner, no its not. If the printer did not clean its roller after every colour print you would end up with colour contamination on the following pages. Hence why colour prints take longer than black.
May 01, 2008 | Samsung CLP 300 Laser Printer
Print paper
Not much,in most cases both can be switched, thermal is different, lasers use toner not ink, Premium inkjet paper has better ink asorbition properties with little spread, and paper designed for lasers can cope with the heat applied when it passes via the 180 deg fuser that melts the toner to it. Generally paper used in inkjets and laser is just standard 80gsm paper
Never use labels/transparentcy's designed for inkjets in laser machines they wont cope with the heat,
Jan 30, 2008 | Nikon COOLPRINT Thermal Printer
Canon iR 2016i Black and White Copier Logo
15 people viewed this question
old marine
old marine
