I have taken the computer apart and can not seem to find the bios (cmos) battery to reset. nor the jumpers that are usually found on a desktop motherboard. please help me, i have alot of work files on my hard drive that i really need. Is there a password, generic , that will satisfy this problem. or can i please get a schematic of the motherboard to find the bios battery.. thank you
This seems to be a difficult model to reset.
I did find this though:
To reset the password of a Toshiba, you can use KeyDisk.
Good luck
Apparently, this laptop sets the password by itself because of some kind of glitch in the earlier BIOS releases. I believe this problem was fixed with the latest BIOS release.
But how can you upgrade the laptop BIOS to the latest version if you cannot bypass the password?
1. If the laptop is still under warranty take it to an authorized repair center. They should clear the BIOS password without any charge.
2. If the laptop is not under warranty, you can try to clear the BIOS password yourself. You’ll find instructions here and here.
After the password has been cleared, upgrade the laptop BIOS to the latest version. You can download it from the Toshiba website.
Please feel free to rate this response
Thank you
Reset the CMOS
· The CMOS is, in basic terms, the part of the motherboard that stores the BIOS settings. To remove the BIOS password from your Toshiba laptop, your best option is to forcibly clear the CMOS. Use a Backdoor Password · If resetting the CMOS doesn't work, then your next bet is to try using a backdoor password. A backdoor password is basically a password that manufacturers include with the BIOS so that technicians can access the computers that people send in for repair. An example of a Toshiba backdoor password is, unsurprisingly, "Toshiba." When the BIOS prompts you to enter a password, entering "Toshiba" may allow you to access your PC and clear the old BIOS password. Another option is to hold the left "Shift" key down while booting.
To clear the CMOS, you must remove the battery from your laptop and leave it out for at least 30 minutes to an hour. The way to remove the battery from your Toshiba will largely depend on the model. A common way to remove the battery--particularly with newer models--is to release the battery lock on the bottom of the laptop, while sliding the accompanying tab over to the side. This will pop the battery out from its tray so that you can then pull it out all of the way out.
Before you remove the battery, turn off the laptop and remove the AC adapter. Otherwise, you could end up harming yourself or the laptop components. You must also ground yourself to prevent damaging the laptop with static electricity.
After about a half an hour or more, return the battery back to its tray and lock it into place. Power on the laptop. The computer, ideally, should no longer ask you for a BIOS password.
It's important to keep in mind that resetting the CMOS means that all of your BIOS settings will be reset to factory default. Also, sometimes you may need to leave out the battery for much longer than an hour to reset the password
