Question about Shuttle XPC 250W Power Supply (CSSHMIS10) Power Supply
Shuttle XPC XB51G Barebones - no power
My computer was shut down unexpectedly and when I went to power back on the power switch does not work. I see no visible damage. I press the power switch or the reset switch and get nothing. Not sure if this is a power supply problem or switch problem or hopefully not a motherboard problem. Any ideas?
  • bbrocks Aug 12, 2007
    Thanks for the advice. I tested the PSU in another computer and nothing so I ordered a new PSU for the Shuttle.
  • Anonymous Apr 21, 2009
    Hi - I am using SN95G5 barebone ( with 50GB 10000 rpm primary hdd, 250 gb secondary hdd, ATIx 800pro graphic card). One day when I wanted to start my machine, press the power supply button and can see hdd led gets on and sounds comes like hummmmm!! Every this is getting powered up, even still. But no boot up nothing coming up on screen.
    Sounds like PSU problem. If that is the case then I need slientX 240W PSU. I am not sure from where I can opt from?
    Any help would be much appreciated!!!
    Many many thanks in advance,
    Jigs
  • Shuttle Master
  • 12,061 Answers
I think you will find your PSU has gone faulty, they are very cheap these days, I would guess at the PSU and replace it "On Spec" with a similar one. Remove the four PSU screws around by the Fan at back. Unplug it from The motherboard noting connections, can only go one way thogh. Take the PSU to ya local repair shop and get another... put new one in connect up to MB and power up. If ya lucky.. ya solved ya problem. Or better still see if you can test it with another one B4 buying another.
Posted on Aug 08, 2007
6ya staff
SOURCE:
Reset cmos, doesn't switch on
Plug out your pc, hold the power button for a few seconds and then take out the battery. Then wait a few minutes and put the battery back in. This should reset your cmos. If this doesn't help then the problem might be a corrupt bios, defective psu, faulty cpu or memory.
Mar 17, 2014 | Shuttle Computer Shuttle Xpc Sn78sh7...
Location of cmos in shuttle
the CMOS battery is on the motherboard. it is the size of a quarter dollar, silver is color and it look almost the same like the watch battery
Dec 11, 2009 | Shuttle XPC SN41G2 (XPC-SN41G2-SHUT) PC...
Shuttle shut down problem
go to BioS set up..
see to it if the CD Rom Drive has been detected..
if Not,,, try to connect again
...back to BIOS SET up
if it detect..save it...
then boot the computer until it pop up the windows environment..
double click "my computer " icon
if CD ROM has there..
your computer normally shut down..
Oct 19, 2009 | Shuttle XPC PC Desktop
What happens if i accidently prest the reset button
it will reset the Computer ?
which will shut Down, And restart.
Mike @ compurepair.
Aug 19, 2009 | Shuttle XPC SK41G (XPC-SK41G-SHUT) PC...
Takes up to 30 mins to turn it self on
I had the same problem with 2 of these systems.
You need to replace the power supply.
I know it's a weird problem. It seems like it shouldn't start at all.
But it solved the problem with both of the systems.
here is a link for the power supply at a few stores:
http://www.google.com/products/catalog?hl=en&q=fsp250&um=1&ie=UTF-8&cid=6955864153062084941&sa=X&oi=product_catalog_result&resnum=2&ct=result#ps-sellers
Hope this helps.
Jeff
Oct 20, 2008 | Shuttle XPC SN41G2 (XPC-SN41G2-SHUT) PC...
Shuttle XPC - fan on the back does not stop
I would suggest you have a fan with faulty bearing
and i thing the power supply could want changing
Sep 01, 2008 | Shuttle first SFF barebone with the power...
Computer won't turn on
tnielsen
u did not said ur mother board vander name and chipset. because some mother board can not star if CMOS battery expire. remove CMOS battery check it voltage bellow 3V or not if it's voltage bellow 3V then replace it. and try to trun on ur shuttle.
Jun 29, 2008 | Shuttle 200W Internal Power Supply for...
Open Questions:
Aol verizon customer support number +-1=855=536=5666 Aol verizon Tech Support- KETHHQM [email protected] is one of the biggest companies in the world which is providing its services. It has invested in various functions and can provide the best when we compare to others. So if you are interested in having the services, then you should not think twice. As they even offer you the benefit of having the help from the [email protected] email Toll free Number. Once the person has those, then the user will be able to get the help from the user in a way which is going to make his experience a euphoric one. So dial the number whenever you are facing the problem. [email protected] support number When you are using the [email protected] for the cable, telecommunication, internet services or anything, then you will find it to be the best. The user will find that there is no other option when it comes to the quality of the services they provide. But even after that, there are some problems which are needed to be tackled. For that, the user can dial the [email protected] support number and ask for the help. Once you dial the [email protected] customer support number, you come in contact with a team of experts at the [email protected] customer service. They will be able to help out the user with any situation in which they are stuck. So whenever the user feels that he or she is stuck, then there is no need to make any rash decisions. As the team on the [email protected] support phone number will help you with that simply and quickly. This is [email protected]'s best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a [email protected] agent. Features of [email protected] support number A person can face difficulty while using technology anywhere and anytime. But this does not mean that you will leave that application or make any rash decisions. As you or any user will be able to get the help from the [email protected] customer support phone number. Here are some of the features of customer service: The [email protected] customer support phone number which you will be using to contact them is available 24/7. So the user will be able to get the help whenever they are facing the problem. There is no need for the user to find the solution his or her own and waste time. AS the [email protected] customer service will be doing all that for you. The only thing that will be required from you is to dial the number and apply the solution provided by them. When you want the help for the service for which you have paid, then you do not want to spend any more money. For this [email protected] provides you the facility of [email protected] support phone number. The number which you or user will be using is toll-free. So they will be able to get help from an expert without paying any money. There is no waiting time for the call the customer is making for the help. So the only time that you have to wait to get in touch for the help is a few seconds. And after that, you will be able to get the help that you want. Problem Faced Various problems can be face by the user while using the [email protected] Here are some of the issues that you are going to face when you are using the application: The user might be having trouble with the connectivity of the internet services. There might be questions regarding the plan the user is using, or how can he or she change it? Might be some channels are missing. The list can go on, but there is no need for the user to worry about. As the user can always get the solution to the problem by contacting the [email protected] Customer support number team.
Oct 22, 2019 | HIS Computers & Internet
See all Shuttle XPC 250W Power Supply (CSSHMIS10) Power Questions
Shuttle XPC 250W Power Supply (CSSHMIS10) Power Supply Logo
680 people viewed this question
Top Shuttle Computers & Internet Experts
Ekse
Alun Cox
pvc73
Are you a Shuttle Computer and Internet Expert? Answer questions, earn points and help others
