Question about Porsche 2004 Cayenne S
Fuel pump primary circuit malfunction - Porsche 2004 Cayenne S
Codes are...p1352-p1481-p1335-p0180-p1351-p1350p0115
P1352 - Ignition Coil 'A' Primary Circuit Malfunction P1481 - Fan Secondary Low With High Fan On P1335 - Crankshaft Position Sensor P0180 - Fuel Temperature Sensor 'A' Circuit Malfunction
P1351 - IDM Input Circuit Malfunction/ Ignition Coil Control Circuit High Voltage P1350 - Fuel Level Sensor 'B' Intermittent/Bypass Line Monitor P0115 - Engine Coolant Temperature Circuit Malfunction
Oct 14, 2015 | Cars & Trucks
Where is the bank 1 sensor 1 air flow sensor located on a 2000 toyota avalon?
Sensor diagram for a 2000 toyota avalon and list of Pcodes dbd372cc-f8f3-49ef-b0c2-2adab46c4182.jpg 8fc069a5-bedc-447d-a1ef-4335798a0a0f.jpg
P0100 Mass or Volume Air Flow Circuit Malfunction
P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
P0102 Mass or Volume Air Flow Circuit Low Input
P0103 Mass or Volume Air Flow Circuit High Input
P0104 Mass or Volume Air Flow Circuit Intermittent
P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
P0110 Intake Air Temperature Circuit Malfunction
P0111 Intake Air Temperature Circuit Range/Performance Problem
P0112 Intake Air Temperature Circuit Low Input
P0113 Intake Air Temperature Circuit High Input
P0114 Intake Air Temperature Circuit Intermittent
P0115 Engine Coolant Temperature Circuit Malfunction
P0116 Engine Coolant Temperature Circuit Range/Performance Problem
P0117 Engine Coolant Temperature Circuit Low Input
P0118 Engine Coolant Temperature Circuit High Input
P0119 Engine Coolant Temperature Circuit Intermittent
P0120 Throttle/Pedal Position Sensor/Switch "A" Circuit Malfunction
P0121 Throttle/Pedal Position Sensor/Switch "A" Circuit Range/Performance Problem
P0122 Throttle/Pedal Position Sensor/Switch "A" Circuit Low Input
P0123 Throttle/Pedal Position Sensor/Switch "A" Circuit High Input
P0124 Throttle/Pedal Position Sensor/Switch "A" Circuit Intermittent
P0125 Insufficient Coolant Temperature For Closed Loop Fuel Control
P0126 Insufficient Coolant Temperature For Stable Operation
P0130 O2Circuit Malfunction (Bank #1 Sensor #1)
P0131 O2Sensor Circuit Low Voltage (Bank #1 Sensor #1)
P0132 O2Sensor Circuit High Voltage (Bank #1 Sensor #1)
P0133 O2Sensor Circuit Slow Response (Bank #1 Sensor #1)
P0134 O2Sensor Circuit No Activity Detected (Bank #1 Sensor #1)
P0135 O2Sensor Heater Circuit Malfunction (Bank #1 Sensor #1)
P0136 O2Sensor Circuit Malfunction (Bank #1 Sensor #2)
P0137 O2Sensor Circuit Low Voltage (Bank #1 Sensor #2)
P0138 O2Sensor Circuit High Voltage (Bank #1 Sensor #2)
P0139 O2Sensor Circuit Slow Response (Bank #1 Sensor #2)
P0140 O2Sensor Circuit No Activity Detected (Bank #1 Sensor #2)
P0141 O2Sensor Heater Circuit Malfunction (Bank #1 Sensor #2)
P0142 O2Sensor Circuit Malfunction (Bank #1 Sensor #3)
P0143 O2Sensor Circuit Low Voltage (Bank #1 Sensor #3)
P0144 O2Sensor Circuit High Voltage (Bank #1 Sensor #3)
P0145 O2Sensor Circuit Slow Response (Bank #1 Sensor #3)
P0146 O2Sensor Circuit No Activity Detected (Bank #1 Sensor #3)
P0147 O2Sensor Heater Circuit Malfunction (Bank #1 Sensor #3)
P0150 O2Sensor Circuit Malfunction (Bank #2 Sensor #1)
P0151 O2Sensor Circuit Low Voltage (Bank #2 Sensor #1)
P0152 O2Sensor Circuit High Voltage (Bank #2 Sensor #1)
P0153 O2Sensor Circuit Slow Response (Bank #2 Sensor #1)
P0154 O2Sensor Circuit No Activity Detected (Bank #2 Sensor #1)
P0155 O2Sensor Heater Circuit Malfunction (Bank #2 Sensor #1)
P0156 O2Sensor Circuit Malfunction (Bank #2 Sensor #2)
P0157 O2Sensor Circuit Low Voltage (Bank #2 Sensor #2)
P0158 O2Sensor Circuit High Voltage (Bank #2 Sensor #2)
P0159 O2Sensor Circuit Slow Response (Bank #2 Sensor #2)
P0160 O2Sensor Circuit No Activity Detected (Bank #2 Sensor #2)
P0161 O2Sensor Heater Circuit Malfunction (Bank #2 Sensor #2)
P0162 O2Sensor Circuit Malfunction (Bank #2 Sensor #3)
P0163 O2Sensor Circuit Low Voltage (Bank #2 Sensor #3)
P0164 O2Sensor Circuit High Voltage (Bank #2 Sensor #3)
P0165 O2Sensor Circuit Slow Response (Bank #2 Sensor #3)
P0166 O2Sensor Circuit No Activity Detected (Bank #2 Sensor #3)
P0167 O2Sensor Heater Circuit Malfunction (Bank #2 Sensor #3)
P0170 Fuel Trim Malfunction (Bank #1)
P0171 System Too Lean (Bank #1)
P0172 System Too Rich (Bank #1)
P0173 Fuel Trim Malfunction (Bank #2)
P0174 System Too Lean (Bank #2)
P0175 System Too Rich (Bank #2)
P0176 Fuel Composition Sensor Circuit Malfunction
P0177 Fuel Composition Sensor Circuit Range/Performance
P0178 Fuel Composition Sensor Circuit Low Input
P0179 Fuel Composition Sensor Circuit High Input
P0180 Fuel Temperature Sensor "A" Circuit Malfunction
P0181 Fuel Temperature Sensor "A" Circuit Range/Performance
P0182 Fuel Temperature Sensor "A" Circuit Low Input
P0183 Fuel Temperature Sensor "A" Circuit High Input
P0184 Fuel Temperature Sensor "A" Circuit Intermittent
P0185 Fuel Temperature Sensor "B" Circuit Malfunction
P0186 Fuel Temperature Sensor "B" Circuit Range/Performance
P0187 Fuel Temperature Sensor "B" Circuit Low Input
P0188 Fuel Temperature Sensor "B" Circuit High Input
P0189 Fuel Temperature Sensor "B" Circuit Intermittent
P0190 Fuel Rail Pressure Sensor Circuit Malfunction
P0191 Fuel Rail Pressure Sensor Circuit Range/Performance
P0192 Fuel Rail Pressure Sensor Circuit Low Input
P0193 Fuel Rail Pressure Sensor Circuit High Input
P0194 Fuel Rail Pressure Sensor Circuit Intermittent
P0195 Engine Oil Temperature Sensor Malfunction
P0196 Engine Oil Temperature Sensor Range/Performance
P0197 Engine Oil Temperature Sensor Low
P0198 Engine Oil Temperature Sensor High
P0199 Engine Oil Temperature Sensor Intermittent
P0200 Injector Circuit Malfunction
P0201 Injector Circuit Malfunction - Cylinder #1
P0202 Injector Circuit Malfunction - Cylinder #2
P0203 Injector Circuit Malfunction - Cylinder #3
P0204 Injector Circuit Malfunction - Cylinder #4
P0205 Injector Circuit Malfunction - Cylinder #5
P0206 Injector Circuit Malfunction - Cylinder #6
P0207 Injector Circuit Malfunction - Cylinder #7
P0208 Injector Circuit Malfunction - Cylinder #8
P0209 Injector Circuit Malfunction - Cylinder #9
P0210 Injector Circuit Malfunction - Cylinder #10
P0211 Injector Circuit Malfunction - Cylinder #11
P0212 Injector Circuit Malfunction - Cylinder #12
P0213 Cold Start Injector #1 Malfunction
P0214 Cold Start Injector #2 Malfunction
P0215 Engine Shutoff Solenoid Malfunction
P0216 Injection Timing Control Circuit Malfunction
P0217 Engine Over Temperature Condition
P0218 Transmission Over Temperature Condition
P0219 Engine Over Speed Condition
P0220 Throttle/Pedal Position Sensor/Switch "B" Circuit Malfunction
P0221 Throttle/Pedal Position Sensor/Switch "B" Circuit Range/Performance Problem
P0222 Throttle/Pedal Position Sensor/Switch "B" Circuit Low Input
P0223 Throttle/Pedal Position Sensor/Switch "B" Circuit High Input
P0224 Throttle/Pedal Position Sensor/Switch "B" Circuit Intermittent
P0225 Throttle/Pedal Position Sensor/Switch "C" Circuit Malfunction
P0226 Throttle/Pedal Position Sensor/Switch "C" Circuit Range/Performance Problem
P0227 Throttle/Pedal Position Sensor/Switch "C" Circuit Low Input
P0228 Throttle/Pedal Position Sensor/Switch "C" Circuit High Input
P0229 Throttle/Pedal Position Sensor/Switch "C" Circuit Intermittent
P0230 Fuel Pump Primary Circuit Malfunction
P0231 Fuel Pump Secondary Circuit Low
P0232 Fuel Pump Secondary Circuit High
P0233 Fuel Pump Secondary Circuit Intermittent
P0234 Engine Over Boost Condition
P0261 Cylinder #1 Injector Circuit Low
P0262 Cylinder #1 Injector Circuit High
P0263 Cylinder #1 Contribution/Balance Fault
P0264 Cylinder #2 Injector Circuit Low
P0265 Cylinder #2 Injector Circuit High
P0266 Cylinder #2 Contribution/Balance Fault
P0267 Cylinder #3 Injector Circuit Low
P0268 Cylinder #3 Injector Circuit High
P0269 Cylinder #3 Contribution/Balance Fault
P0270 Cylinder #4 Injector Circuit Low
P0271 Cylinder #4 Injector Circuit High
P0272 Cylinder #4 Contribution/Balance Fault
P0273 Cylinder #5 Injector Circuit Low
P0274 Cylinder #5 Injector Circuit High
P0275 Cylinder #5 Contribution/Balance Fault
P0276 Cylinder #6 Injector Circuit Low
P0277 Cylinder #6 Injector Circuit High
P0278 Cylinder #6 Contribution/Balance Fault
P0279 Cylinder #7 Injector Circuit Low
P0280 Cylinder #7 Injector Circuit High
P0281 Cylinder #7 Contribution/Balance Fault
P0282 Cylinder #8 Injector Circuit Low
P0283 Cylinder #8 Injector Circuit High
P0284 Cylinder #8 Contribution/Balance Fault
P0285 Cylinder #9 Injector Circuit Low
P0286 Cylinder #9 Injector Circuit High
P0287 Cylinder #9 Contribution/Balance Fault
P0288 Cylinder #10 Injector Circuit Low
P0289 Cylinder #10 Injector Circuit High
P0290 Cylinder #10 Contribution/Balance Fault
P0291 Cylinder #11 Injector Circuit Low
P0292 Cylinder #11 Injector Circuit High
P0293 Cylinder #11 Contribution/Balance Fault
P0294 Cylinder #12 Injector Circuit Low
P0295 Cylinder #12 Injector Circuit High
P0296 Cylinder #12 Contribution/Balance Fault
P0300 Random/Multiple Cylinder Misfire Detected
P0301 Cylinder #1 - Misfire Detected
P0302 Cylinder #2 - Misfire Detected
P0303 Cylinder #3 - Misfire Detected
P0304 Cylinder #4 - Misfire Detected
P0305 Cylinder #5 - Misfire Detected
P0306 Cylinder #6 - Misfire Detected
P0307 Cylinder #7 - Misfire Detected
P0308 Cylinder #8 - Misfire Detected
P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction
P0321 Ignition/Distributor Engine Speed Input Circuit Range/Performance
P0322 Ignition/Distributor Engine Speed Input Circuit No Signal
P0323 Ignition/Distributor Engine Speed Input Circuit Intermittent
P0325 Knock Sensor #1 - Circuit Malfunction (Bank #1 or Single Sensor)
P0326 nock Sensor #1 - Circuit Range/Performance (Bank #1 or Single Sensor)
P0327 Knock Sensor #1 - Circuit Low Input (Bank #1 or Single Sensor)
P0328 Knock Sensor #1 - Circuit High Input (Bank #1 or Single Sensor)
P0329 Knock Sensor #1 - Circuit Input Intermittent (Bank #1 or Single Sensor)
P0330 Knock Sensor #2 - Circuit Malfunction (Bank #2)
P0331 Knock Sensor #2 - Circuit Range/Performance (Bank #2)
P0332 Knock Sensor #2 - Circuit Low Input (Bank #2)
P0333 Knock Sensor #2 - Circuit High Input (Bank #2)
P0334 Knock Sensor #2 - Circuit Input Intermittent (Bank #2)
P0335 Crankshaft Position Sensor "A" Circuit Malfunction
P0336 Crankshaft Position Sensor "A" Circuit Range/Performance
P0337 Crankshaft Position Sensor "A" Circuit Low Input
P0338 Crankshaft Position Sensor "A" Circuit High Input
P0339 Crankshaft Position Sensor "A" Circuit Intermittent
P0340 Camshaft Position Sensor Circuit Malfunction
P0341 Camshaft Position Sensor Circuit Range/Performance
P0342 Camshaft Position Sensor Circuit Low Input
P0343 Camshaft Position Sensor Circuit High Input
P0344 Camshaft Position Sensor Circuit Intermittent
P0350 Ignition Coil Primary/Secondary Circuit Malfunction
P0351 Ignition Coil "A" Primary/Secondary Circuit Malfunction
P0352 Ignition Coil "B" Primary/Secondary Circuit Malfunction
P0353 Ignition Coil "C" Primary/Secondary Circuit Malfunction
P0354 Ignition Coil "D" Primary/Secondary Circuit Malfunction
P0355 Ignition Coil "E" Primary/Secondary Circuit Malfunction
P0356 Ignition Coil "F" Primary/Secondary Circuit Malfunction
P0357 Ignition Coil "G" Primary/Secondary Circuit Malfunction
P0358 Ignition Coil "H" Primary/Secondary Circuit Malfunction
P0359 Ignition Coil "I" Primary/Secondary Circuit Malfunction
P0360 Ignition Coil "J" Primary/Secondary Circuit Malfunction
P0361 Ignition Coil "K" Primary/Secondary Circuit Malfunction
P0362 Ignition Coil "L" Primary/Secondary Circuit Malfunction
P0370 Timing Reference High Resolution Signal "A" Malfunction
P0371 Timing Reference High Resolution Signal "A" Too Many Pulses
P0372 Timing Reference High Resolution Signal "A" Too Few Pulses
P0373 Timing Reference High Resolution Signal "A" Intermittent/Erratic Pulses
P0374 Timing Reference High Resolution Signal "A" No Pulses
P0375 Timing Reference High Resolution Signal "B" Malfunction
P0376 Timing Reference High Resolution Signal "B" Too Many Pulses
P0377 Timing Reference High Resolution Signal "B" Too Few Pulses
P0378 Timing Reference High Resolution Signal "B" Intermittent/Erratic Pulses
P0379 Timing Reference High Resolution Signal "B" No Pulses
P0380 Glow Plug/Heater Circuit "A" Malfunction
P0381 Glow Plug/Heater Indicator Circuit Malfunction
P0382 Glow Plug/Heater Circuit "B" Malfunction
P0385 Crankshaft Position Sensor "B" Circuit Malfunction
P0386 Crankshaft Position Sensor "B" Circuit Range/Performance
P0387 Crankshaft Position Sensor "B" Circuit Low Input
P0388 Crankshaft Position Sensor "B" Circuit High Input
P0389 Crankshaft Position Sensor "B" Circuit Intermittent
P0400 Exhaust Gas Recirculation Flow Malfunction
P0401 Exhaust Gas Recirculation Flow Insufficient Detected
P0402 Exhaust Gas Recirculation Flow Excessive Detected
P0403 Exhaust Gas Recirculation Circuit Malfunction
P0404 Exhaust Gas Recirculation Circuit Range/Performance
P0405 Exhaust Gas Recirculation Sensor "A" Circuit Low
P0406 Exhaust Gas Recirculation Sensor "A" Circuit High
P0407 Exhaust Gas Recirculation Sensor "B" Circuit Low
P0408 Exhaust Gas Recirculation Sensor "B" Circuit High
P0410 Secondary Air Injection System Malfunction
P0411 Secondary Air Injection System Incorrect Flow Detected
P0412 Secondary Air Injection System Switching Valve "A" Circuit Malfunction
P0413 Secondary Air Injection System Switching Valve "A" Circuit Open
P0414 Secondary Air Injection System Switching Valve "A" Circuit Shorted
P0415 Secondary Air Injection System Switching Valve "B" Circuit Malfunction
P0416 Secondary Air Injection System Switching Valve "B" Circuit Open
P0417 Secondary Air Injection System Switching Valve "B" Circuit Shorted
P0418 Secondary Air Injection System Relay "A" Circuit Malfunction
P0419 Secondary Air Injection System Relay "B" Circuit Malfunction
P0420 Catalyst System Efficiency Below Threshold (Bank #1)
P0421 Warm Up Catalyst Efficiency Below Threshold (Bank #1)
P0422 Main Catalyst Efficiency Below Threshold (Bank #1)
P0423 Heated Catalyst Efficiency Below Threshold (Bank #1)
P0424 Heated Catalyst Temperature Below Threshold (Bank #1)
P0430 Catalyst System Efficiency Below Threshold (Bank #2)
P0431 Warm Up Catalyst Efficiency Below Threshold (Bank #2)
P0432 Main Catalyst Efficiency Below Threshold (Bank #2)
P0433 Heated Catalyst Efficiency Below Threshold (Bank #2)
P0434 Heated Catalyst Temperature Below Threshold (Bank #2)
P0440 Evaporative Emission Control System Malfunction
P0441 Evaporative Emission Control System Incorrect Purge Flow
P0442 Evaporative Emission Control System Leak Detected (Small Leak)
P0443 Evaporative Emission Control System Purge Control Valve Circuit Malfunction
P0444 Evaporative Emission Control System Purge Control Valve Circuit Open
P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted
P0446 Evaporative Emission Control System Vent Control Circuit Malfunction P0441 and/or P0446
Apr 02, 2014 | 2000 Toyota Avalon
Diagnosis read fault p336
p0140 - 02 sensor circuit no activity detected, (bank 2 sensor 1)
P0170 - fuel trim malfunction (bank 1) MM6LP - fuel injection fault
P0336 - Crankshaft Position Sensor A Circuit range/performance SID801/4 - Engine speed signal coherence.
P0352 - Ignition coil B Primary/secondary circuit malfunction MM6LP - 2/3 ignition coil control. Open circuit, short circuit to positive, short circuit to earth. ME746 - NO.1 Ignition coil control function. Short circuit to earth. ME746 - NO.2 ign. coil control function. Short circuit to earth.
P0414 - Secondary Air Inj. system switching valve A circuit shorted. MM6LP - Air pump relay control failure.
Mar 21, 2014 | 2008 Peugeot 307cc 1.6
Need codes for UBD2 reader
Try these.
P1000OBD-II Monitor Testing Incomplete
P1001KOER Test Cannot Be Completed
P1039Vehicle Speed Signal Missing or Improper
P1051Brake Switch Signal Missing or Improper
P1100Mass Air Flow Sensor Intermittent
P1101Mass Air Flow Sensor out of Self-Test Range
P1112Intake Air Temperature Sensor Intermittent
P1114Intake Air Temperature 2 Circuit Low Input
P1115Intake Air Temperature 2 Circuit High Input
P1116Engine Coolant Temperature Sensor is out of Self-Test Range
P1117Engine Coolant Temperature Sensor Intermittent
P1120Throttle Position Sensor out of range
P1121Throttle Position Sensor Inconsistent with Mass Air Flow Sensor
P1124Throttle Position Sensor out of Self-Test Range
P1125Throttle Position Sensor Intermittent
P1127Heated Oxygen Sensor Heater not on During KOER Test - Exhaust Not Warm Enough
P1129Upstream O2 Sensors Swapped Bank To Bank (HO2S-11-21)
P1130Lack of Upstream Heated Oxygen Sensor Switch - Adaptive Fuel Limit - Bank No. 1
P1131Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 1
P1132Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 1
P1135Ignition Switch Signal Missing or Improper
P1137Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 1
P1138Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 1
P1150Lack of Upstream Heated Oxygen Sensor Switch - Adaptive Fuel Limit - Bank No. 2
P1151Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 2
P1152Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 2
P1157Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 2
P1158Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 2
P1168FRP Sensor In Range But Low
P1169FRP Sensor In Range But High
P1180Fuel Delivery System Low
P1181Fuel Delivery System High
P1183EOT Sensor Circuit Malfunction
P1184EOT Sensor Out Of Range
P1220Series Throttle Control fault
P1224Throttle Position Sensor B out of Self-Test Range
P1229Supercharger Intercooler Pump Not Working
P1230Open Power to Fuel Pump circuit
P1231High Speed Fuel Pump Relay activated
P1232Low Speed Fuel Pump Primary circuit failure
P1233Fuel Pump Driver Module off-line
P1234Fuel Pump Driver Module off-line
P1235Fuel Pump Control out of range
P1236Fuel Pump Control out of range
P1237Fuel Pump Secondary circuit fault
P1238Fuel Pump Secondary circuit fault
P1244Generator Load Input Low
P1245Generator Load Input High
P1246Generator Load Input Failed
P1250Lack of Power to FPRC Solenoid
P1260Theft Detected - Engine Disabled
P1270Engine RPM or Vehicle Speed Limiter Reached
P1285Cylinder Head Over Temperature Sensed
P1288Cylinder Head Temperature Sensor out of Self-Test Range
P1289Cylinder Head Temperature Sensor Signal Greater Than Self-Test Range
P1290Cylinder Head Temperature Sensor Signal Less Than Self-Test Range
P1299Cylinder Head Temperature Sensor Detected Engine Overheating Condition
P1309Misfire Detection Monitor not enabled
P1336CKP and/or CMP Input Signal to PCM Concerns
P1351Ignition Diagnostic Monitor circuit Input fault
P1352Ignition Coil A - Primary circuit fault
P1353Ignition Coil B - Primary circuit fault
P1354Ignition Coil C - Primary circuit fault
P1355Ignition Coil D - Primary circuit fault
P1356Loss of Ignition Diagnostic Module Input to PCM
P1358Ignition Diagnostic Monitor Signal out of Self-Test Range
P1359Spark Output circuit fault
P1364Ignition Coil Primary circuit fault
P1380Variable Cam Timing Solenoid A Circuit Malfunction
P1381Variable Cam Timing Over-advanced (Bank 1)
P1383Variable Cam Timing Over-retarded (Bank 1)
P1390Octane Adjust out of Self-Test Range
P1400Differential Pressure Feedback Electronic Sensor circuit Low Voltage
P1401Differential Pressure Feedback Electronic Sensor circuit High Voltage
P1403Differential Pressure Feedback Electronic Sensor Hoses Reversed
P1405Differential Pressure Feedback Electronic Sensor circuit Upstream Hose
P1406Differential Pressure Feedback Electronic Sensor circuit Downstream Hose
P1407EGR No Flow Detected
P1408EGR Flow out of Self-Test Range
P1409EGR Vacuum Regulator circuit malfunction
P1410EGR Barometric Pressure Sensor VREF Voltage
P1411Secondary Air is not being diverted
P1413Secondary Air Injection System Monitor circuit Low Voltage
P1414Secondary Air Injection System Monitor circuit High Voltage
P1432THTRC Circuit Failure
P1436A/C Evaporator Temperature Circuit Low Input
P1437A/C Evaporator Temperature Circuit High Input
P1442Secondary Air Injection System Monitor circuit High Voltage
P1443Evaporative Emission Control System - Vacuum System - Purge Control Solenoid or Purge Control Valve fault
P1444Purge Flow Sensor circuit Input Low
P1445Purge Flow Sensor circuit Input High
P1450Inability of Evaporative Emission Control System to Bleed Fuel Tank
P1451EVAP Control System Canister Vent Solenoid Circuit Malfunction
P1452Inability of Evaporative Emission Control System to Bleed Fuel Tank
P1455Substantial Leak or Blockage in Evaporative Emission Control System
P1460Wide Open Throttle Air Conditioning Cutoff circuit malfunction
P1461Air Conditioning Pressure Sensor circuit Low Input
P1462Air Conditioning Pressure Sensor circuit high Input
P1463Air Conditioning Pressure Sensor Insufficient Pressure change
P1464ACCS to PCM High During Self-Test
P1469Low Air Conditioning Cycling Period
P1473Fan Secondary High with Fans Off
P1474Low Fan Control Primary circuit
P1477MFC Primary Circuit Failure
P1479High Fan Control Primary circuit
P1480Fan Secondary Low with Low Fans On
P1481Fan Secondary Low with High Fans On
P1483Power to Cooling Fan Exceeded Normal Draw
P1484Variable Load Control Module Pin 1 Open
P1500Vehicle Speed Sensor (VSS) Intermittent
P1501Programmable Speedometer & Odometer Module/Vehicle Speed Sensor (VSS) Intermittent circuit-failure
P1502Invalid or Missing Vehicle Speed Message or Brake Data
P1504Intake Air Control circuit malfunction
P1505Idle Air Control System at Adaptive Clip
P1506Idle Air Control Over Speed Error
P1507Idle Air Control Under Speed Error
P1512Intake Manifold Runner Control Stuck Closed
P1513Intake Manifold Runner Control Stuck Closed
P1516Intake Manifold Runner Control Input Error
P1517Intake Manifold Runner Control Input Error
P1518Intake Manifold Runner Control fault - Stuck Open
P1519Intake Manifold Runner Control fault - Stuck Closed
P1520Intake Manifold Runner Control circuit fault
P1530Open or Short to A/C Compressor Clutch circuit
P1537Intake Manifold Runner Control Stuck Open
P1538Intake Manifold Runner Control Stuck Open
P1539Power to A/C Compressor Clutch circuit Exceeded Normal Current Draw
P1549Intake Manifold Temperature Valve Vacuum Actuator Connection
P1550Power Steering Pressure Sensor out of Self-Test Range
P1572Brake Pedal Switch Circuit
P1605PCM Keep Alive Memory Test Error
P1625Voltage to Vehicle Load Control Module Fan circuit not detected
P1626Voltage to Vehicle Load Control Module circuit not detected
P1633Keep Alive Power Voltage Too Low
P1635Tire/Axle Out Of Acceptable Range
P1636Inductive Signiture Chip Communication Error
P1639Vehicle ID Block Not Programmed Or Corrupt
P1640DTC\'s Available In Another Module
P1650Power Steering Pressure Switch out of Self-Test Range
P1651Power Steering Pressure Switch Signal Malfunction
P1700Transmission system problems
P1701Reverse Engagement Error
P1702Transmission system problems
P1703Brake On/Off Switch out of Self-Test Range
P1704Transmission system problems
P1705Transmission Range Sensor out of Self-Test Range
P1709Park or Neutral Position Switch out of Self-Test Range
P1710Transmission system problems
P1711Transmission Fluid Temperature Sensor out of Self-Test Range
P1713Transmission system problems
P1714Transmission system problems
P1715Transmission system problems
P1716Transmission system problems
P1717Transmission system problems
P1718Transmission system problems
P1719Transmission system problems
P1720Transmission system problems
P17294x4 Low Switch Error
P1740Transmission system problems
P1741Torque Converter Clutch Control Error
P1742Torque Converter Clutch Solenoid Faulty
P1743Torque Converter Clutch Solenoid Faulty
P1744Torque Converter Clutch System Stuck in Off Position
P1745Transmission system problems
P1746Electronic Pressure Control Solenoid - Open circuit
P1747Electronic Pressure Control Solenoid - Short circuit
P1749Electronic Pressure Control Solenoid Failed Low
P1751Shift Solenoid No. 1 Performance
P1754Coast Clutch Solenoid circuit malfunction
P1756Shift Solenoid No. 2 Performance
P1760Transmission system problems
P1761Shift Solenoid No. 3 Performance
P1762Transmission system problems
P1767Transmission system problems
P1780Transmission Control Switch circuit is out of Self-Test Range
P17814x4 Low Switch is out of Self-Test Range
P1783Transmission Over-Temperature Condition
P1784Transmission system problems
P1785Transmission system problems
P1786Transmission system problems
P1787Transmission system problems
P1788Transmission system problems
P1789Transmission system problems
P1900Transmission system problems
Mar 25, 2013 | Ford Vehicle Parts & Accessories
My x type 3.0 has fault readingP1647 could you tell me what this means please
OBDII DTC
P1001 Key on engine running unable to complete; key on engine running aborted
P1100 Mass air flow sensor intermittent
P1101 Mass air flow sensor out of self test range
P1104 Mass Airflow (MAF) Sensor Ground Circuit Malfunction
P1107 Left MAP Sensor Circuit
P1108 Right MAP Sensor Circuit
P1112 IATS Circuit High Voltage
P1113 IATS Circuit Low Voltage
P1121 Pedal Position Sensor Circuit A Range/Performance
P1122 Pedal Position Sensor Circuit A Low Voltage
P1123 Pedal Position Sensor Circuit A High Voltage
P1137 No Rear HO2S Response
P1138 No Rear HO3S Response
P1157 No Rear HO2S Response
P1158 No Rear HO3S Response
P1171 All Cylinders Too Lean
P1172 All Cylinders Too Rich
P1176 Adaptive Fuel Metering Trim Too Lean
P1177 Adaptive Fuel Metering Trim Too Rich
P1178 Adaptive Fuel Metering Trim Too Lean
P1179 Adaptive Fuel Metering Trim Too Rich
P1187 Both Front HO2S Heater Circuits (High Resistance)
P1188 Both Front HO2S Heater Circuits (Open Short to Ground High Resistance)
P1190 Both Front HO2S Heater Circuits (High Battery Voltage Short to Voltage)
P1193 Both Front HO2S Heater Circuits (High Resistance MAF Sensor Fault)
P1194 Both Front HO2S Heater Circuits (Open Short to Ground High Resistance)
P1196 Both Front HO2S Heater Circuits (High Battery Voltage Short to Ground)
P1198 Fuel Level Sensor (High Voltage)
P1199 Fuel Level Sensor (Low Voltage)
P1201 No. 1 Fuel Injector
P1202 No. 2 Fuel Injector
P1203 No. 3 Fuel Injector
P1204 No. 4 Fuel Injector
P1205 No. 5 Fuel Injector
P1206 No. 6 Fuel Injector
P1221 Pedal Position Sensor Circuit B Range/Performance
P1222 Pedal Position Sensor Circuit B Low Voltage
P1223 Pedal Position Sensor Circuit B High Voltage
P1224 Electronic Throttle Control Position Error
P1226 Mechanical Guard Circuit Range Performance
P1227 Mechanical Guard Circuit Low Input
P1228 Mechanical Guard Circuit High Input
P1229 Throttle Control Circuit Malfunction
P1230 Fuel Pump Relay Malfunction
P1235 VSV 1 Circuit Range/Performance
P1236 VSV 1 Vacuum Circuit Failure
P1237 VSV 2 Atmosphere Circuit Failure
P1238 VSV 3 Release Circuit Failure
P1240 Throttle Position Sensor Voltage Malfunction//Sensor Reference Voltage Low (Throttle
Fuel Tank Pressure)
P1241 Throttle Position Sensor Voltage Low Input//Reference Voltage Low (Throttle Fuel
Tank Pressure)
P1242 Throttle Position Sensor Voltage High Input
P1243 Throttle Position Sensor Ground Malfunction
P1245 Crank Signal Low Input
P1246 Crank Signal High Input
P1313 Misfire Catalyst Damage Bank No. 1
P1314 Misfire Catalyst Damage Bank No. 2
P1315 Misfire Excess Emissions
P1316 Misfire Rate Above Limit
P1335 Crankshaft Position Sensor Circuit
P1336 Camshaft Position Sensor (CMP) Circuit Performance
P1361 Ignition Coil Primary Circuit (Cylinder No. 1)
P1362 Ignition Coil Primary Circuit (Cylinder No. 2)
P1363 Ignition Coil Primary Circuit (Cylinder No. 3)
P1364 Ignition Coil Primary Circuit (Cylinder No. 4)
P1365 Ignition Coil Primary Circuit (Cylinder No. 5)
P1366 Ignition Coil Primary Circuit (Cylinder No. 6)
P1367 Ignition Monitor (Bank A)//Ignition System Failure Group 1
P1368 Ignition Monitor (Bank B)//Ignition System Failure Group 2
P1371 Early Activation Ignition Coil (Cylinder No. 1)
P1372 Early Activation Ignition Coil (Cylinder No. 2)
P1373 Early Activation Ignition Coil (Cylinder No. 3)
P1374 Early Activation Ignition Coil (Cylinder No. 4)
P1375 Early Activation Ignition Coil (Cylinder No. 5)
P1376 Early Activation Ignition Coil (Cylinder No. 6)
P1392 Variable Valve Timing Solenoid A Low Input
P1393 Variable Valve Timing Solenoid A High Input
P1396 Variable Valve Timing Solenoid B Malfunction
P1397 Variable Valve Timing Solenoid B Low Input
P1398 Variable Valve Timing Solenoid B High Input
P1400 EGR Valve Position Circuit (Valve Sticking Open or Short)
P1401 EGR Valve Position Circuit (Open Short to Ground)
P1408 EGR Temperature Sensor Circuit
P1409 EGR Valve Circuit
P1440 EVAP Purge Valve Open
P1441 EVAP Valve Circuit
P1443 EVAP Valve Circuit
P1447 EVAP Valve Circuit
P1448 EVAP Valve Circuit
P1454 EVAP System
P1474 Charge Air Coolant Pump Relay
P1475 Radiator Fans Slow Malfunction
P1476 Radiator Fans Fast Parallel Circuit Malfunction
P1506 Idle Speed Control Circuit (Low RPM; Bank B)
P1507 Idle Speed Control Circuit (High RPM; Bank B)
P1508 Idle Speed Control Circuit
P1509 Idle Speed Control Circuit
P1512 Throttle Position Sensor Idle Switch Sense Circuit
P1513 Throttle Position Sensor Idle Switch Sense Circuit
P1514 Park/Neutral Position Switch High Load Neutral/Drive
P1516 Gear Change Park/Neutral Malfunction
P1517 Engine Cranking Park/Neutral Malfunction
P1607 MIL Output Circuit
P1608 Automatic Transmission
P1609 Internal ECM Error
P1641 Fuel Pump Relay No. 1
P1646 Fuel Pump Relay No. 2
P1739 Automatic Transmission
P1775 Transmission Control Module MIL Circuit
P1776 Torque Reduction Request Signal
P1777 Torque Reduction Circuit
P1780 Automatic Transmission
P1781 Automatic Transmission
P1782 Automatic Transmission
P1783 Automatic Transmission
P1785 Automatic Transmission
P1790 Automatic Transmission
P1791 Automatic Transmission
P1792 Automatic Transmission
P1794 Automatic Transmission
Mar 22, 2013 | Jaguar Cars & Trucks
P0446
P0109 Intake Air Temperature Circuit Malfunction
P0120 Throttle/Petal Position Sensor/Switch A Circuit Malfunction
P0121 Throttle/Petal Position Sensor/Switch A Circuit Range/Performance Problem
P0122 Throttle/Petal Position Sensor/Switch A Circuit Low Input
P0123 Throttle/Petal Position Sensor/Switch A Circuit High Input
P0124 Throttle/Petal Position Sensor/Switch A Circuit Intermittent
P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control
P0126 Insufficient Coolant Temperature for Stable Operation
P0130 O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)
P0131 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)
P0132 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)
P0133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
P0134 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1)
P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P0136 O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)
P0137 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2)
P0138 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2)
P0139 O2 Sensor Circuit Slow Response (Bank 1 Sensor 2)
P0140 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
P0141 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
P0150 O2 Sensor Circuit Malfunction (Bank 2 Sensor 1)
P0151 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 1)
P0152 O2 Sensor Circuit High Voltage (Bank 2 Sensor 1)
P0153 O2 Sensor Circuit Slow Response (Bank 2 Sensor 1)
P0154 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
P0155 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
P0156 O2 Sensor Circuit Malfunction (Bank 2 Sensor 2)
P0157 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
P0158 O2 Sensor Circuit High Voltage (Bank 2 Sensor 2)
P0159 O2 Sensor Circuit Slow Response (Bank 2 Sensor 2)
P0160 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
P0161 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
P0162 O2 Sensor Circuit Malfunction (Bank 2 Sensor 3)
P0163 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
P0164 O2 Sensor Circuit High Voltage (Bank 2 Sensor 3)
P0165 O2 Sensor Circuit Slow Response (Bank 2 Sensor 3)
P0166 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 3)
P0167 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
P0170 Fuel Trim Malfunction (Bank 1)
P0171 System too Lean (Bank 1)
P0172 System too Rich (Bank 1)
P0173 Fuel Trim Malfunction (Bank 2)
P0174 System too Lean (Bank 2)
P0175 System too Rich (Bank 2)
P0180 Fuel Temperature Sensor A Circuit Malfunction
P0181 Fuel Temperature Sensor A Circuit Range/Performance
P0182 Fuel Temperature Sensor A Circuit Low Input
P0183 Fuel Temperature Sensor A Circuit High Input
P0184 Fuel Temperature Sensor A Circuit Intermittent
P0185 Fuel Temperature Sensor B Circuit Malfunction
P0186 Fuel Temperature Sensor B Circuit Range/Performance
P0187 Fuel Temperature Sensor B Circuit Low Input
P0188 Fuel Temperature Sensor B Circuit High Input
P0189 Fuel Temperature Sensor B Circuit Intermittent
P0201 Injector Circuit Malfunction - Cylinder 1
P0202 Injector Circuit Malfunction - Cylinder 2
P0203 Injector Circuit Malfunction - Cylinder 3
P0204 Injector Circuit Malfunction - Cylinder 4
P0205 Injector Circuit Malfunction - Cylinder 5
P0206 Injector Circuit Malfunction - Cylinder 6
P0213 Cold Start Injector 1 Malfunction
P0214 Cold Start Injector 2 Malfunction
P0217 Engine Overtemp Condition
P0219 Engine Overspeed Condition
P0220 Throttle/Petal Position Sensor/Switch B Circuit Malfunction
P0221 Throttle/Petal Position Sensor/Switch B Circuit Range/Performance Problem
P0222 Throttle/Petal Position Sensor/Switch B Circuit Low Input
P0223 Throttle/Petal Position Sensor/Switch B Circuit High Input
P0224 Throttle/Petal Position Sensor/Switch B Circuit Intermittent
P0225 Throttle/Petal Position Sensor/Switch C Circuit Malfunction
P0226 Throttle/Petal Position Sensor/Switch C Circuit Range/Performance Problem
P0227 Throttle/Petal Position Sensor/Switch C Circuit Low Input
P0228 Throttle/Petal Position Sensor/Switch C Circuit High Input
P0229 Throttle/Petal Position Sensor/Switch C Circuit Intermittent
P0234 Engine Overboost Condition
P0251 Injection Pump Fuel Metering Control "A" Malfunction (Cam/Rotor/Injector)
P0252 Injection Pump Fuel Metering Control "A" Range/Performance (Cam/Rotor/Injector)
P0253 Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector)
P0254 Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector)
P0255 Injection Pump Fuel Metering Control "A" Intermittent (Cam/Rotor/Injector)
P0256 Injection Pump Fuel Metering Control "B" Malfunction (Cam/Rotor/Injector)
P0257 Injection Pump Fuel Metering Control "B" Range/Performance (Cam/Rotor/Injector)
P0258 Injection Pump Fuel Metering Control "B" Low (Cam/Rotor/Injector)
P0259 Injection Pump Fuel Metering Control "B" High (Cam/Rotor/Injector)
P0260 Injection Pump Fuel Metering Control "B" Intermittent (Cam/Rotor/Injector)
P0261 Cylinder 1 Injector Circuit Low
P0262 Cylinder 1 Injector Circuit High
P0263 Cylinder 1 Contribution/Balance Fault
P0264 Cylinder 2 Injector Circuit Low
P0265 Cylinder 2 Injector Circuit High
P0266 Cylinder 2 Contribution/Balance Fault
P0267 Cylinder 3 Injector Circuit Low
P0268 Cylinder 3 Injector Circuit High
P0269 Cylinder 3 Contribution/Balance Fault
P0270 Cylinder 4 Injector Circuit Low
P0271 Cylinder 4 Injector Circuit High
P0272 Cylinder 4 Contribution/Balance Fault
P0273 Cylinder 5 Injector Circuit Low
P0274 Cylinder 5 Injector Circuit High
P0275 Cylinder 5 Contribution/Balance Fault
P0276 Cylinder 6 Injector Circuit Low
P0277 Cylinder 6 Injector Circuit High
P0278 Cylinder 6 Contribution/Balance Fault
P0301 Cylinder 1 Misfire Detected
P0302 Cylinder 2 Misfire Detected
P0303 Cylinder 3 Misfire Detected
P0304 Cylinder 4 Misfire Detected
P0305 Cylinder 5 Misfire Detected
P0306 Cylinder 6 Misfire Detected
P0325 Knock Sensor 1 Circuit Malfunction (Bank 1 or Single Sensor)
P0326 Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)
P0327 Knock Sensor 1 Circuit Low Input (Bank 1 or Single Sensor)
P0328 Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor)
P0329 Knock Sensor 1 Circuit Intermittent (Bank 1 or Single Sensor)
P0330 Knock Sensor 2 Circuit Malfunction (Bank 2)
P0331 Knock Sensor 2 Circuit Range/Performance (Bank 2)
P0332 Knock Sensor 2 Circuit Low Input (Bank 2)
P0333 Knock Sensor 2 Circuit High Input (Bank 2)
P0334 Knock Sensor 2 Circuit Intermittent (Bank 2)
P0335 Crankshaft Position Sensor A Circuit Malfunction
P0336 Crankshaft Position Sensor A Circuit Range/Performance
P0337 Crankshaft Position Sensor A Circuit Low Input
P0338 Crankshaft Position Sensor A Circuit High Input
P0339 Crankshaft Position Sensor A Circuit Intermittent
P0351 Ignition Coil A Primary/Secondary Circuit Malfunction
P0352 Ignition Coil B Primary/Secondary Circuit Malfunction
P0353 Ignition Coil C Primary/Secondary Circuit Malfunction
P0354 Ignition Coil D Primary/Secondary Circuit Malfunction
P0355 Ignition Coil E Primary/Secondary Circuit Malfunction
P0356 Ignition Coil F Primary/Secondary Circuit Malfunction
P0357 Ignition Coil G Primary/Secondary Circuit Malfunction
P0358 Ignition Coil H Primary/Secondary Circuit Malfunction
P0359 Ignition Coil I Primary/Secondary Circuit Malfunction
P0360 Ignition Coil J Primary/Secondary Circuit Malfunction
P0361 Ignition Coil K Primary/Secondary Circuit Malfunction
P0362 Ignition Coil L Primary/Secondary Circuit Malfunction
P0370 Timing Reference High Resolution Signal A Malfunction
P0371 Timing Reference High Resolution Signal A Too Many Pulses
P0372 Timing Reference High Resolution Signal A Too Few Pulses
P0373 Timing Reference High Resolution Signal A Intermittent/Erratic Pulses
P0374 Timing Reference High Resolution Signal A No Pulses
P0375 Timing Reference High Resolution Signal B Malfunction
P0376 Timing Reference High Resolution Signal B Too Many Pulses
P0377 Timing Reference High Resolution Signal B Too Few Pulses
P0378 Timing Reference High Resolution Signal B Intermittent/Erratic Pulses
P0379 Timing Reference High Resolution Signal B No Pulses
P0382 Exhaust Gas Recirculation Flow Malfunction
P0385 Crankshaft Position Sensor B Circuit Malfunction
P0386 Crankshaft Position Sensor B Circuit Range/Performance
P0387 Crankshaft Position Sensor B Circuit Low Input
P0388 Crankshaft Position Sensor B Circuit High Input
P0389 Crankshaft Position Sensor B Circuit Intermittent
P0405 Exhaust Gas Recirculation Sensor A Circuit Low
P0406 Exhaust Gas Recirculation Sensor A Circuit High
P0407 Exhaust Gas Recirculation Sensor B Circuit Low
P0408 Exhaust Gas Recirculation Sensor B Circuit High
P0412 Secondary Air Injection System Switching Valve A Circuit Malfunction
P0413 Secondary Air Injection System Switching Valve A Circuit Open
P0414 Secondary Air Injection System Switching Valve A Circuit Shorted
P0415 Secondary Air Injection System Switching Valve B Circuit Malfunction
P0416 Secondary Air Injection System Switching Valve B Circuit Open
P0417 Secondary Air Injection System Switching Valve B Circuit Shorted
P0420 Catalyst System Efficiency Below Threshold (Bank 1)
P0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1)
P0422 Main Catalyst Efficiency Below Threshold (Bank 1)
P0423 Heated Catalyst Efficiency Below Threshold (Bank 1)
P0424 Heated Catalyst Temperature Below Threshold (Bank 1)
P0430 Catalyst System Efficiency Below Threshold (Bank 2)
P0431 Warm Up Catalyst Efficiency Below Threshold (Bank 2)
P0432 Main Catalyst Efficiency Below Threshold (Bank 2)
P0433 Heated Catalyst Efficiency Below Threshold (Bank 2)
P0434 Heated Catalyst Temperature Below Threshold (Bank 2)
P0442 Evaporative Emission Control System Leak Detected (small leak)
P0447 Evaporative Emission Control System Vent Control Circuit Open
P0448 Evaporative Emission Control System Vent Control Circuit Shorted
P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction
P0450 Evaporative Emission Control System Pressure Sensor Malfunction
P0451 Evaporative Emission Control System Pressure Sensor Range/Performance
P0452 Evaporative Emission Control System Pressure Sensor Low Input
P0453 Evaporative Emission Control System Pressure Sensor High Input
P0454 Evaporative Emission Control System Pressure Sensor Intermittent
P0455 Evaporative Emission Control System Leak Detected (gross leak)
P0460 Fuel Level Sensor Circuit Malfunction
P0461 Fuel Level Sensor Circuit Range/Performance
P0462 Fuel Level Sensor Circuit Low Input
P0463 Fuel Level Sensor Circuit High Input
P0464 Fuel Level Sensor Circuit Intermittent
P0465 Purge Flow Sensor Circuit Malfunction
P0466 Purge Flow Sensor Circuit Range/Performance
P0467 Purge Flow Sensor Circuit Low Input
P0468 Purge Flow Sensor Circuit High Input
P0469 Purge Flow Sensor Circuit Intermittent
P0470 Exhaust Pressure Sensor Malfunction
P0471 Exhaust Pressure Sensor Range/Performance
P0472 Exhaust Pressure Sensor Low
P0473 Exhaust Pressure Sensor High
P0474 Exhaust Pressure Sensor Intermittent
P0475 Exhaust Pressure Control Valve Malfunction
P0476 Exhaust Pressure Control Valve Range/Performance
P0477 Exhaust Pressure Control Valve Low
P0478 Exhaust Pressure Control Valve High
P0479 Exhaust Pressure Control Valve Intermittent
P0480 Cooling Fan 1 Control Circuit Malfunction
P0481 Cooling Fan 2 Control Circuit Malfunction
P0482 Cooling Fan 3 Control Circuit Malfunction
P0483 Cooling Fan Rationality Check Malfunction
P0484 Cooling Fan Circuit Over Current
P0485 Cooling Fan Power/Ground Circuit Malfunction
P0500 Vehicle Speed Sensor Malfunction
P0501 Vehicle Speed Sensor Range/Performance
P0502 Vehicle Speed Sensor Low Input
P0503 Vehicle Speed Sensor Intermittent/Erratic/High
P0505 Idle Control System Malfunction
P0506 Idle Control System RPM Lower Than Expected
P0507 Idle Control System RPM Higher Than Expected
P0510 Closed Throttle Position Switch Malfunction
P0520 Engine Oil Pressure Sensor/Switch Circuit Malfunction
P0521 Engine Oil Pressure Sensor/Switch Circuit Range/Performance
P0522 Engine Oil Pressure Sensor/Switch Circuit Low Voltage
P0523 Engine Oil Pressure Sensor/Switch Circuit High Voltage
P0530 A/C Refrigerant Pressure Sensor Circuit Malfunction
P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance
P0532 A/C Refrigerant Pressure Sensor Circuit Low Input
P0533 A/C Refrigerant Pressure Sensor Circuit High Input
P0534 Air Conditioner Refrigerant Charge Loss
P0550 Power Steering Pressure Sensor Circuit Malfunction
P0551 Power Steering Pressure Sensor Circuit Range/Performance
P0552 Power Steering Pressure Sensor Circuit Low Input
P0553 Power Steering Pressure Sensor Circuit High Input
P0554 Power Steering Pressure Sensor Circuit Intermittent
P0560 System Voltage Malfunction
P0561 System Voltage Unstable
P0562 System Voltage Low
P0563 System Voltage High
P0565 Cruise Control On Signal Malfunction
P0566 Cruise Control Off Signal Malfunction
P0567 Cruise Control Resume Signal Malfunction
P0568 Cruise Control Set Signal Malfunction
P0569 Cruise Control Coast Signal Malfunction
P0570 Cruise Control Accel Signal Malfunction
P0571 Cruise Control/Brake Switch A Circuit Malfunction
P0572 Cruise Control/Brake Switch A Circuit Low
P0573 Cruise Control/Brake Switch A Circuit High
P0574 Cruise Control Related Malfunction
P0575 Cruise Control Related Malfunction
P0576 Cruise Control Related Malfunction
P0578 Cruise Control Related Malfunction
P0579 Cruise Control Related Malfunction
P0580 Cruise Control Related Malfunction
P0600 Serial Communication Link Malfunction
P0601 Internal Control Module Memory Check Sum Error
P0602 Control Module Programming Error
P0603 Internal Control Module Keep Alive Memory (KAM) Error
P0604 Internal Control Module Random Access Memory (RAM) Error
P0605 Internal Control Module Read Only Memory (ROM) Error
P0606 PCM Processor Fault
P0608 Control Module VSS Output "A" Malfunction
P0609 Control Module VSS Output "B" Malfunction
P0620 Generator Control Circuit Malfunction
P0621 Generator Lamp "L" Control Circuit Malfunction
P0622 Generator Field "F" Control Circuit Malfunction
P0650 Malfunction Indicator Lamp (MIL) Control Circuit Malfunction
P0654 Engine RPM Output Circuit Malfunction
P0655 Engine Hot Lamp Output Control Circuit Malfucntion
P0656 Fuel Level Output Circuit Malfunction
P0700 Transmission Control System Malfunction
P0701 Transmission Control System Range/Performance
P0702 Transmission Control System Electrical
P0703 Torque Converter/Brake Switch B Circuit Malfunction
P0704 Clutch Switch Input Circuit Malfunction
P0705 Transmission Range Sensor Circuit malfunction (PRNDL Input)
P0706 Transmission Range Sensor Circuit Range/Performance
P0707 Transmission Range Sensor Circuit Low Input
P0708 Transmission Range Sensor Circuit High Input
P0709 Transmission Range Sensor Circuit Intermittent
P0710 Transmission Fluid Temperature Sensor Circuit Malfunction
P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance
P0712 Transmission Fluid Temperature Sensor Circuit Low Input
P0713 Transmission Fluid Temperature Sensor Circuit High Input
P0714 Transmission Fluid Temperature Sensor Circuit Intermittent
P0715 Input/Turbine Speed Sensor Circuit Malfunction
P0716 Input/Turbine Speed Sensor Circuit Range/Performance
P0717 Input/Turbine Speed Sensor Circuit No Signal
P0718 Input/Turbine Speed Sensor Circuit Intermittent
P0719 Torque Converter/Brake Switch B Circuit Low
P0720 Output Speed Sensor Circuit Malfunction
P0721 Output Speed Sensor Range/Performance
P0722 Output Speed Sensor No Signal
P0723 Output Speed Sensor Intermittent
P0724 Torque Converter/Brake Switch B Circuit High
P0725 Engine Speed input Circuit Malfunction
P0726 Engine Speed Input Circuit Range/Performance
P0727 Engine Speed Input Circuit No Signal
P0728 Engine Speed Input Circuit Intermittent
P0730 Incorrect Gear Ratio
P0731 Gear 1 Incorrect ratio
P0732 Gear 2 Incorrect ratio
P0733 Gear 3 Incorrect ratio
P0734 Gear 4 Incorrect ratio
P0735 Gear 5 Incorrect ratio
P0736 Reverse incorrect gear ratio
P0740 Torque Converter Clutch Circuit Malfuction
P0741 Torque Converter Clutch Circuit Performance or Stuck Off
P0742 Torque Converter Clutch Circuit Stuck On
P0743 Torque Converter Clutch Circuit Electrical
P0744 Torque Converter Clutch Circuit Intermittent
P0745 Pressure Control Solenoid Malfunction
P0746 Pressure Control Solenoid Performance or Stuck Off
P0747 Pressure Control Solenoid Stuck On
P0748 Pressure Control Solenoid Electrical
P0749 Pressure Control Solenoid Intermittent
P0750 Shift Solenoid A Malfunction
P0751 Shift Solenoid A Performance or Stuck Off
P0752 Shift Solenoid A Stuck On
P0753 Shift Solenoid A Electrical
P0754 Shift Solenoid A Intermittent
P0755 Shift Solenoid B Malfunction
P0756 Shift Solenoid B Performance or Stuck Off
P0757 Shift Solenoid B Stuck On
P0758 Shift Solenoid B Electrical
P0759 Shift Solenoid B Intermittent
P0760 Shift Solenoid C Malfunction
P0761 Shift Solenoid C Performance or Stuck Off
P0762 Shift Solenoid C Stuck On
P0763 Shift Solenoid C Electrical
P0764 Shift Solenoid C Intermittent
P0765 Shift Solenoid D Malfunction
P0766 Shift Solenoid D Performance or Stuck Off
P0767 Shift Solenoid D Stuck On
P0768 Shift Solenoid D Electrical
P0769 Shift Solenoid D Intermittent
P0770 Shift Solenoid E Malfunction
P0771 Shift Solenoid E Performance or Stuck Off
P0772 Shift Solenoid E Stuck On
P0773 Shift Solenoid E Electrical
P0774 Shift Solenoid E Intermittent
P0780 Shift Malfunction
P0781 1-2 Shift Malfunction
P0782 2-3 Shift Malfunction
P0783 3-4 Shift Malfunction
P0784 4-5 Shift Malfunction
P0785 Shift/Timing Solenoid Malfunction
P0786 Shift/Timing Solenoid Range/Performance
P0787 Shift/Timing Solenoid Low
P0788 Shift/Timing Solenoid High
P0789 Shift/Timing Solenoid Intermittent
P0790 Normal/Performance Switch Circuit Malfunction
P0801 Reverse Inhibit Control Circuit Malfunction
P0803 1-4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction
P0804 1-4 Upshift (Skip Shift) Lamp Control Circuit Malfunction
May 05, 2012 | 1997 Toyota Camry
Code P02300
you have two many numbers in your code i assume u mean one of this two codes
P0230= Fuel Pump Primary Circuit
P2300= Ignition Coil "A" Primary Control Circuit Low
Feb 27, 2011 | 2004 Jeep Grand Cherokee
Kia 03 Spectra fuel OBD code P0230 primary circuit failure. Relay does not pick up Fuse is good. No spark on the ignition - relay does not pick up fuse is good. What is in the primary circuit and where...
Unfortunately there are no mechanical fixes available because that trouble code indicates a malfunction somewhere in the electrical circuit for the fuel pump and that would include wiring from the battery to the pump, the fuel pump control module and the and the car's brain, the ECM. It can be a loose connection, but if one is not easily found, then the problem has to be tested with special electrical testing equipment. More information is available but I can't post an illustration of the troubleshooting for this Diagnostic Trouble Code.
There is, however, an illustration that describes that troubleshooting at this location currently:
http://www.iwsti.com/forums/2-5-liter-litre-factory-motor/145319-p0230-fuel-pump-primary-circuit-malfunction-2.html
Jan 03, 2011 | 2003 Kia Spectra
Po230 406 hdi 2001
P0230 - Fuel Pump Primary Circuit Malfunction
Check the wiring to these components first, power and earth etc, if wiring is ok you may have faulty components, especially the primary lift pump in the fuel tank, these are famous for failing.
Keep us updated.
Dec 22, 2010 | Peugeot Liberte Cars & Trucks
HELLO I HAVE THIS CODES PCU P1693,ECU P1689.P0126. P230
CODE PO126 - INSUFFICIENT COOLANT TEMPERATURE FOR STABLE OPERATION. CHECK FOR LOW COOLANT LEVEL.FAULTY THERMOSTAT STUCK OPEN.OR MISSING THERMOSTAT.FAUTY COOLANT TEMPERATURE SENSOR. CODE PO230 - FUEL PUMP PRIMARY CIRCUIT MALFUNCTION.POSSIBLE CAUSE FAULTY FUEL PUMP RELAY.OR PCM CIRCUIT FAILURE TO FUEL PUMP RELAY. DID NOT SEE CODES P1693 AND P1689.
Sep 28, 2010 | 2005 Dodge Ram
Porsche 2004 Cayenne S Logo
56 people viewed this question
Top Porsche Car Audio & Video Experts
xxxxxx xxx
Are you a Porsche Car Audio and Video Expert? Answer questions, earn points and help others
