Question about Honda Garden
Honda HRX537 Hydrostatic drive
The hydrostatic drive on my HRX537 is giving trouble. It will work for about 20 minutes then I have to push the mower to get it moving. I've stripped the gearbox and have now rebuilt it with parts from an old one that was working but still have the same problem. Before I fork out for a new gearbox any ideas? I guess the pistons must be worn and when the gearbox gets hot the oil is no longer getting to the required pressure, though everything inside the box looked OK.
2 Suggested Answers
SOURCE: Broken rear axle on my Honda hydrostatic drive push mower
The last time I had a Honda mower in my repair shop I noticed that Honda doesnt do individual parts on its transmissions for mowers OR tillers.
You can fix this mower...but the transaxles are a bit expensive. Honda mowers do tend to be worth it though.
If the axle broke cleanly maybe someone would weld it back together?
I mean, the wheels dont turn that fast that balance would be an issue right? And I am sure the axle metal is cold rolled steel....which is to say it isnt thin cast material that would resist welding. If you take the transmission out of your mower and just take the parts to a good jobber maybe they would give it a try for 10-20 bucks? Dont expect a guarantee...but, for 20 bucks most shops wont even pick up a mower let alone try to fix it.
If this gives you another couple of years of service that would give you time to consider a replacement mower when the unit needs service again.
Good luck and be careful!
Posted on Jul 02, 2010
Why is my Series 1000 LT1024 Hydrostatic Drive Cub Cadet not pulling?
In most cases the hydrostatic drives are not made by the company tractor or lawnmower.
This is in the owners manual.
Hydrostatic Transmission
The hydrostatic transmission is sealed at the factory
and is maintenance free. The fluid level cannot be
checked nor can the oil be changed. Always keep the
area around the transmission cooling fan free of grass
and debris at all times
Cub Cadet LT1024 Operator Manual
How to Change the Hydrostatic Fluid in Cub Cadet Lawn Mower
https://www.google.com/webhp?sourceid=chrome-instant&rlz=1C1GGGE_enUS385US385&ion=1&espv=2&ie=UTF-8#q=cub%20cadet%20hydrostatic%20fluid%20change
I hope that this can help. Tom
Aug 22, 2014 | Cub Cadet Garden
Mower won't go forward or backward
Is the hydrostatic drive disengaged? On some mowers there is a lever on the hydrostatic drive you can flip to disengage so the mower can be pushed or towed. Other possibility is a broken hydrostatic drive belt.
Jul 22, 2014 | Yard Machines Garden
My johnb deere L120 engine runs fine, but after about 20 minutes the tractor slowly stops moving, i dont know if this is a drive belt problem or something wrong with the hydrostatic?
Hi, most likely the hydrostatic is over heating. Remove the battery and battery carrier. From here clean any grass and debris from the hydro and cooling fins, also check the cooling fan condition. Under the mower check the idler pulley on the hydro drive belt is travelling freely. Hope this helps, regards Phil.
May 08, 2011 | John Deere Garden
My MTD 12.5 hp briggs and stratton ride on mower is losing forward speed as though a clutch is slipping especially going up hills or slopes. MIKE
You didn't indicate what model so I don't know if it is hydrostatic drive or not. If it is not hydrostatic drive, it is most likely a worn belt or clutch adjustment. If you don't have your manual you can download one here:http://www.mtdlawnmowerparts.com/manuals.php
If it is hydrostatic drive it stil could be the drive belt or low water in hydrostatic transmission, or even water in the oil in the hydrostatic transmission. Always list model number when asking questions.
Oct 03, 2010 | Mtd Garden
Hydrostatic drive not working
The drive belt probably needs replacing.
Thank you for asking and I hope this helps you.Please leave me a 4 thumbs up.
Jul 18, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Jun 22, 2010 | Honda Garden
John deere 300 garden tractor hydrostatic drive will not work
check two things, make sure the by-pass rod is pushed all the way in and the drive belt from the engine to the rear end (tranaxle). If both check out ok do not attempt to service the tranaxle at home. have thet serviced by a dealer.
Jun 02, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Wont move forward or reverse-- transmission??
Does it have gears or a hydrostatic (automatic) transmission?
If it's a gear model, sounds like a loose drive belt.
If it's hydrostatic, it could be a belt problem or a problem inside the transmission. If it's a tranmission problem, this is not good. Many of the transmissions on riding lawn mowers are not serviceable - they are just replaced.
Oct 10, 2009 | Garden
Garden Logo
91 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
