Question about KitchenAid KUDC10IXBL Builtin Dishwasher
Heat dry will not come on the blue ligh on switch dose not come
My dry has no flame , the ligh lite up but no flame
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 10, 2011 | Washing Machines
Half red ligh starts blinking then shuts off
Two possibility , first the 1of the heat sinks may have lost it's thermal seal
to the chips ie G.P.U. or C.P.U. this is more common when consoles
are played vertically . Second but less common the G.P.U. temp feed
connection has become intermittent and tripping a thermal shut down.
Remedy's are
Remove heat sinks for G.P.U. and the C.P.U clean off the old heat sink
compound and replace with new ( articsilver 5 ).
If the console still over heats ( two red lights) then the G.P.U C.P.U
will need to be re-flowed back to the board that normally corrects
the problem in 90% of over heating problems.
If you have any questions feel free to ask.
Rob
May 02, 2010 | Microsoft Xbox 360 Console
My Dry runs, how ever it dose not heat up and dry
To be sure, you need to test the element with a meter, and also check the thermal fuses and or thermostats for continuity.
Jan 18, 2010 | GE Dryers
WHERE DOSE THE BLUE WIRE GO IT WAS FOR
Blue wire is the Remote power switch. Supply this wire with posive power and it turns the amp on. Its only a "Switch" not the main power feed. There is usual a blue amp remote wire on the back of most aftermarket head units.
Oct 01, 2009 | Jl Audio 300/4 Car Audio Amplifier
Auto dry not working
I hope this video will help.
 http://www.youtube.com/watch?v=rQV-z4f7fvA
Also Need a good meter to check all of this.
Was  this helpful?
Mar 30, 2009 | Kenmore 73932 Gas Dryer
Clean ligh is blinking
youll need to remove the bottom acess panel of d/w there should be an extensive trouble shooting guide tapedto back of panel in a sleeve, lotsa good stuff in there. depending on buttons its going to repuire pushing a sequence. "
sani-rinse---heated dry--sani rinse--heated dry.
it will enter a diag mode "all lights will light up" wait a few secs and then cancel cycle .. if happens a again or with frequency, then call a servicer, you have a problem, first time chaulk up to a fluke
Mar 22, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Prima lpr 600 dishwahser
Control Lock means that the entire dishwasher is locked, for child safety purposes.  It's normally cleared by holding the "No Heat Dry" button in for 4 seconds or more.  It is locked again by the same procedure -- holding the "No Heat Dry" button for 4 seconds (or more.  I'd suggest trying this on yours...
Oct 14, 2007 | Whirlpool 24 in. DU1100XTP Built-in...
KitchenAid KUDC10IXBL Builtin Dishwasher Logo
18 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
