Width high correction high no varition mos.9n20 replace mos20nm60 replace then same problem
  • 7,627 Answers
What are you on about? A Laptop?
Posted on May 02, 2013
How many players are there in Mahjong?
They are 4 players. However if you have only 3 players you can play a varition of the regular game. This version is played in Japan as well as Korea.
Jan 17, 2013 | Games
Mk40vn no beep no powerled some hdd led some cd led after reset cmos jumper in right position no other jumpers are set on board i have no manual for jumper settings please help me susanne
in some motherboard when you change the c mos jumper the motherboard doesn't switch on change the pin to 1 and 2 normally which is c mos normal and 2 and 3 is to clear c mos you will see marking of all the jumpers in the motherboard set the pin correct to normal and also remove the power connector from the motherboard and short the green and the black wire and see whether the smps works if not working change them
Oct 01, 2011 | Shuttle MK40VN Motherboard
What does "Text too high"
When you push the print button, "TEXT TOO HIGH!" error message appears on the LCD display, why? Description: This message appears if the size of the text is larger than the width of the installed tape.
Please reduce the character size or install a wider tape.
Aug 12, 2011 | Brother P-Touch 1180 Label Printer
How would you fix an onboard video card
Basically there are 3 possibilities for on board video card failure
1.Hardware,
2.Software and
3.BIOS control
To fix the problem please follow the below steps
1.First of all unplug the power cord to avoid any shocks
2.First reset C MOS , to reset C MOS. Remove the case side panel and using the instructions provided in the motherboard manual, locate the three jumpers used to clear C MOS. Your motherboard will have a jumper shorting two pins usually labeled normal operation. Remove jumper shorting pins one and two, and replace that same jumper on pins two and three
4.Then plug the power and
Your system will not power up. Remove the Clear C MOS jumper from pins two and three, and replace it on pins one and two. Power up System. The system will require you to enter setup and correct the default settings. If clearing C MOS had no effect, you will not see anything on your screen when you power is back up.
If the above did not work then proceed further,
Enter setup, fix the date and time, and you should be in good shape, as most newer computer systems will automatically detect the rest of your setting.
While software driver errors can be fixed, this is something that can only be dealt with if you have some form of video function. If the screen is black, try clearing C MOS, as described above, and otherwise proceed to the next step.
Now the last step is to replace the video card.
Thanks.
Have great day.
Sep 07, 2010 | Acer Aspire™ T180 PC Desktop
What is the width of the drive v belt.
Hello. here is the link to a free downloadable owner manual and parts list http://www.swisherinc.com/customer_support.asp
This will answer your questions and much more. J
Jun 01, 2010 | Swisher Trailmower 44" Cutting Width, 11.5...
Need specs and wiring options
  • 105W x 4 Channel Max. Power Output at 2o.gif Stereo
  • 60W x 4 Channel 0.1% THD at 2o.gif Stereo @13.8V (RMS Continuous Power)
  • 40W x 4 Channel 0.1% THD at 4o.gif Stereo @13.8V (RMS Continuous Power)
  • ChannelFlex Crossover
  • Adjustable High-Pass Frequency (50-200Hz, L/R Independent)
  • Low-Pass Frequency (120Hz)
  • Adjustable Bass-Boost Level (45Hz, 0-9dB, F/R Separate)
  • High-Current, High-Speed Output Devices
  • High-Efficiency, High-Energy MOS-FET Power Supply
  • Audiophile Grade Component Selection
  • Intelligent 7-Way Discrete Protection Circuitry
  • Noise Reduction with Low Distortion & Ultra-Low Negative Feedback
  • High-Level Input - Add on Capability
  • Epoxy Composite PCB
  • 2o.gif Stable Design
Each 6 1/2" speaker will see 40 Watts
Each 6"x9" will see 521/2 Watts
Yes your solution is correct. Front wired in stereo, bridge rear.
Dec 29, 2008 | Eclipse Car Audio & Video
Time or Clock changes
check with antivirus software. same problem came again battery only problem!
Jul 01, 2008 | IBM ThinkPad T43 Notebook
Insufficient width
You can goto www.wa6ati.com and search for your model and it may tell you.
Dec 06, 2007 | RCA P61310 TV
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
