Question about Trust GXT 26 5.1 Surround USB Gamer Headset
PC Static Problems. Mic gives away static, is there a way to solve this issue ?
How do I get rid of the static sound in my 4PR908?
There causes varies from types of headset to another. In respect of a wireless headset, the static sound is caused by interference. Whereas in a cord headset, a loose wire somewhere in your headset or cord is responsible for the static sound or crackle. It might also emanate from the mic in respect of a one calling, or from the ear-piece.
The solution with a wireless headset is to move away from any device e.g computer which might have cause the static sound. Resetting the wireless headset is also a solution measure.
In the case of a cord headset; Get the cord wiggled at the plug and at the headset; and then move the mic to locate the loose connection. Where the problem occurs, loop the wire, taping it down at the point. soldering the affected wire is best than taping.
Finally, if the static sound persist;which it should not after all the treatments; check on the volume of the device. Reduction of the device volume can go a long way to bringing the longed solution. Similar problem occured with my headset;and was solved via the same recommended possibility.
Jan 30, 2015 | Wireless Gear 4PR908 Bluetooth v2.0 EDR...
I have the AKG wms 40 dual mini mic set with two wireless mics. When mic on ch 2 is in the off position, I get lots of static. Works perfectly fine when on. What do you think is the issue?
Channel 2 mic's receiver needs the Squelch adjusted. The squelch control mutes the receiver so that when the transmitter stops transmitting, erroneous noises are not picked up and amplified.
Jan 23, 2013 | AKG WMS 40 Professional Microphone
Mic has static and popping sound. not working
Give Shure Tech Support a call at 800-516-2525. They can help you troubleshoot the problem. Have the mic nearby when you call them.
Oct 22, 2012 | Shure KSM27 Professional Microphone
Having problems obtaining addresses from dhcp. Can I use static addresses instead?
This link shows how to set static IPs on the 2Wire:
http://www.server-servers.com/att-static-ip-2wire-setup/
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 18, 2011 | 2wire 2700HG-B Router (2700HGB)
There is too much static using the Logitech mic with my powerpoint to record narration.
You may have the gain turned up too high causing distortion or static, try to back away from the mic when you are talking.
Hope this helps.
Sep 08, 2010 | Computers & Internet
Mic static noise comming and going
i know someone who can solve this a solution
Feb 24, 2009 | Logitech QuickCam Messenger Web Camera
Msi starcam 370i integred mic not working
Normal 0 Two things can cause static.
First, If you have your speakers turned up to high it will give you feedback causing distortion and static.
Second reason is, if you are using a laptop and have added an external microphone between the two it will cause distortion and static.
Not knowing the configuration of your computer makes it harder to analyze the problem.
So hope this is of some help. Bud
Nov 19, 2008 | MSI Starcam 370i Webcam
Buzzing/humming sound when mic is inserted while on AC power
if its not usb mic you will have the humming
if it is a usb mic the port that you connected to needs a mic to be further away from comp your picking up a static charge from comp to mic
May 26, 2008 | IBM ThinkPad T30 2366 Notebook
Static in the ear piece and mic
Sounds like a repair/warranty problem... This is one of the clearest phone's Ive ever had
Dec 27, 2007 | Motorola Mobility MOTORIZR Z3 Cellular...
Trust GXT 26 5.1 Surround USB Gamer Headset Logo
19 people viewed this question
Top Trust Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Trust Radio Communication Expert? Answer questions, earn points and help others
