Question about Garden
Help me fix my mower
Craftsman 5.0- Model #917.377522 Serial #030399M 009445 there is a gas leak
    Problem Solver:
  • 5 Answers
Go to the repair shop for more help
Posted on May 01, 2013
  • 10865 Answers
SOURCE: My Mower won't start.
the problem is that your carbeurator is gummed from from sitting idle all winter with gas in it. Get an aerosol can of carbeurator cleaner, remove the air filter and give the air intake two squirts of carb. cleaner. Then start the mower. When it stalls again let it sit for an hour while the carbeurator cleaner works at dissolving some of that gum. Repeat the process until the mower runs again. Sometimes there is so much junk in the carb. that you have to remove it and soak it in cleaner for about three hours, and then rebuild the carb. with the proper little kit. hopefully you won't have to take this step.
Next fall let the mower run out of gas and stall then you won't have the gum in the carbeurator in the spring.
Posted on May 23, 2009
  • 3 Answers
SOURCE: My Mower won't stay started after it uses the gas that has been pushing into the mower via the primer bulb
either the magneto or the governor is damaged check them
Posted on May 30, 2009
SOURCE: Craftsman 5HP Mower does not start
try changing your primer bulb
Posted on May 31, 2009
  • 127 Answers
SOURCE: Craftsman 5.5 Gold mower will not start
YOUR PROBLEM IS SIMPLE.
FIRST OF ALL THE HOLE IN THE PRIMER BUTTON MUST BE THERE TO POP BACK OUT EACH TIME YOU PRESS IT NOW AS TO THE GAS COMING OUT OF THERE
THE FLOAT IN THE CARB IS STUCK IN THE FILL POSITION AND WILL NOT LIFT ONCE THE BOWL IS FULL TO STOP THE GAS FROM FILLING OR YOU HAVE A PIN HOLE IN THE FLOAT ITSELF.UNDO THE NOT ON THE BOOTM OF THE BOWL WITH THE LAWN MOWER TILTED ON A 45 DEGREE ANGLE SEE IF YOU CAN MOVE THE FLOAT UP AND DOWN IF IT IS FREE MOVING SPRAY THE WHOLE AREA CLEAN WITH CARB CLEANER AND REASSEMBLE TRY TO START ,IF STILL THE SAME PROBLEM YOU WILL NEED TO REBUILD THE CARB AND INSTALL A NEW FLOAT
Posted on Jun 26, 2009
hunter19_46m
  • 7482 Answers
SOURCE: craftsman mower, model # 917374150. Not ran for 6
Hi r s jensen
Check/Clean/Replace your fuel filter if you have one.
If the mower/weedeater is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Apr 27, 2011
Craftsman riding mower what year was it made model#cv14s
First find the Model Number and Serial number. Next go to Craftsman.com follow menu to Manuals. Enter the model and serial numbers. This should bring up the Manual with the manufacturing Date.
Dec 12, 2014 | Craftsman Garden
I have a 7 year Craftsman 17.5 HP 42 in. lawn tractor. It starts to leak gas recently and stops frequently after running over 30-40 minutes. I can not identified where is the gas leak from but I saw gas on...
I have a Craftsman mower. Last year I had a similar problem with the mower stopping after running awhile. I noticed that the plastic gas tank was collapsing. The next time it began to stall, I immediately loosened the gas cap and it didn't stall. The vent holes in the cap had plugged up. Check this out.
I can't help you locate the fuel leak, although it sounds like the carburetor float is not stopping gas from flowing into the carburetor.
Dec 02, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman riding mower clicking noise - wont start
RIDING MOWERE JUST CLICKS AND WON'T START HOWEVER IT WAS RUNNING FIND JUST 5 MIN. BEFORE I TURNED OFF.
May 22, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Craftsman Riding Mower
When you replace the needle valve you always need to replace the seat. You also may have a bad float in the carburetor.
Sep 24, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
May 31, 2009 | Craftsman Garden
This sounds too easy of a solution but I had a like ptroblem with my Craftsman. I loosed the gas cap a bit and the rough running and stalling stopped. he vent on the gas cap that contains a turn over interrupt valve was plugged causing the gas not to flow. I took the cap apart and cleaned out the vent hole though cleaning the holewith a paper clip would have worked as well. Anyway..it fixed my problem. I think my dirty hands of deris deposited the matera in the vent hole when filling with gas.
May 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
