Question about Minolta DiALTA DI2510F All-In-One Laser Printer
Dialta di 2510 errore c0000 - Minolta DiALTA DI2510F All-In-One Laser Printer
  • Minolta Master
  • 6,674 Answers
Main Motor failure. Try first removing the image unit and reseat it. Then check behind each paper draw for paper. Then you might have a bad main motor or the control board that controls the motor is bad. I would have a Konicminolta Tech look at it. Drum been replaced lately?
Posted on Jan 31, 2015
3 Suggested Answers
wheatlandsvc
  • 1110 Answers
SOURCE: an error code occur ed
C0500 is a fuser warm up failure code. The procedure to reset is simple. First look at the right side edge of your control panel. This is where the meter count is and the "slide" that controls how dark/bright your display screen is. Now just to the left or front side of where the slide is you will see a small hole in the panel. You need a small paper clip or a tooth pick to insert into the hole. Next with the machine turned on and showing the code, insert something into the hole until the screen goes blank and begins to restart. You should see something that resembles the copier sitting on top of the globe. Keep watching the screen and at the far left side of the screen there will appear a small dot. As soon as the dot appears press the 3 key. You should now see a screen with several boxes. At the lower left is "Trouble Reset" - Press this box to reset the code. Do this reset procedure ONLY 1 time for every 10 minutes. If the code comes back you can try again in 10 miutes. If the fuser is heating and the machine just can not "see" it then you can do further damage to the machine if you try to reset several times very quickly. If the machine warms up and makes copies you are all set. If the code comes back you have a failure in the fusing unit and will need it repaired.
This procedure works on the Di250 Di250F Di251 Di251F Di350 Di350F Di351 Di351F.
Please provide positive feedback if I was helpful.
Good Luck and Thank You for using Fixya.
Posted on Jan 06, 2011
SOURCE: c1300 error code
minolta dialta di250 makes a light copy not a dark copy i also fill the toner power but it make print light what we do? kindly solve this porblem.
Posted on Mar 11, 2011
How to install Minolta dialta Di2510
Go to Konica Minolta Web site can use only windows 95 best is XP. If there is Windows 7 Go for it. This a legacy Minolta machine
Aug 24, 2014 | Konica Minolta di-2510 AFR-19 AFR19 ADF...
Dialta di 2510
1. Press the COUNTER.
2. Press the following keys in this order:
STOP 0 0 STOP 0 1
3. Enter the code number corresponding to the function to be used from the KEYPAD.
4. Press the START.
<Exiting the Mode>
• Press the AUTO RESET until the initial screen reappears.
Apr 23, 2014 | Minolta Office Equipment & Supplies
Di450 Minolta Code 2510 erreur C0000
The C0000 code is that the Fusing Unit (The HOT Part) has a motor and it can not turn or is burned out do jam or gear problems. Could not find anything about 2510
Jan 22, 2014 | Minolta DiALTA Di183 Copier
Error code c0-f24
Konica Minolta MINOLTA BRAND DIALTA... - Fixya
www.fixya.com/.../p4705803-konica_minolta_minolta_brand_dialta_89...
Konica Minolta MINOLTA BRAND DIALTA 8935-902 BLACK TONER TYPE 603AFOR USE IN MINOLTA DI-520 / MPN:8935902 SKU:1745166 - Recent Questions, Troubleshooting & Support. Recent; Popular · Answered ... Error code c0-f24.
Code c0510 in dialta 520 how to reset - Fixya
www.fixya.com/support/t16313340-code_c0510_in_dialta_520_reset
Feb 2, 2013 - Code c0510 in dialta 520 how to reset - Konica Minolta MINOLTA ...Home · Forum · Fax Machines · Konica Minolta · MINOLTA BRAND DIALTA 8935-902 BLACK TONER TYPE 603A FOR USE. ... BLACK TONER TYPE 603A FOR USE INMINOLTA DI-520 ... My minolta dialta copier has a c-of24 error code,.
C-0600 there is a code shown in my di520C-0600 tell me ...
www.fixya.com/support/t16673596-c_0600
Feb 14, 2013 | Konica Minolta MINOLTA BRAND DIALTA...
COPIE AVEC FOND NOIR KONICA DI 2510
Clean the glass ,mirror,lens or change the starter/developer.
Jan 25, 2013 | Konica Minolta DiALTA Di200 Copier
Di minolta 2510 error code c0000
Main Motor failure I try first replace the image unit which houses the drum and developer unit. also check the paper draws behind them for paper jammed in side. mite check the transfer section that area with the sponge looking roller. That or you have a burned out main drive motor worse case the control board for the motor is bad.
Jan 19, 2012 | Minolta Office Equipment & Supplies
MISFEED ERROR AFTER POWERING DI 2510 PHOTOCOPIER
look for small black levers, and see if they have a piece of paper on it, or if stuck
Jan 22, 2009 | Minolta DiALTA DI2510F All-In-One Laser...
Minolta di 2510 code c0500
lo ke pasa es ke mi copiadora ya no responde mas y me sale este error una averia "a sido detectada avice a su servisio tecnio y digalke el codigo c0500" ya no se ke hacer... ayuda por favor..
Jun 24, 2008 | Minolta Di2510 All-In-One Laser Printer
Minolta Dialta620 copier error code c-0000
Code C0000 if a fuser motor failure.
Check to see if anything is damaged in the fuser (the thing that gets hot).
Also, check for a jammed transparency (if you use them).
Feb 10, 2008 | Minolta DiALTA Di620 All-In-One Laser...
Minolta DiALTA DI2510F All-In-One Laser Printer Logo
134 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
