Question about Weiser Lock Powerbolt 1000 Lock
Bolt extends half way
When I push the lock button the bolt only extends half way. If I push the lock button again it extends fully. Should I have to push the lock button twice?
Interior door lock won't lock with twist
If the bolt extends fully when the door is open, the problem is with the strike hole in the door frame. (If the bolt doesn't extend when the door is open, it's either a bad installation or a bad lock. Read the instructions again and reinstall it or get a new lock.)
If it used to work, open the door and tighten all the hinge screws before you do anything else. They could be loose even if they are covered with paint. This solves about half the problems with doors and locks.
The easiest way to figure out where the strike hole should be is to use the "lipstick trick." Extend the bolt with the door open, and scrap a tiny ridge of lipstick on the top, bottom, and both sides of the bolt so the lipstick will hit the doorframe before the metal of the bolt does. Retract the bolt, close the door, and try to extend the bolt a few times so the lipstick leaves a mark on the edge of the hole or somewhere inside the hole. Retract the bolt all the way before opening the door so you don't smear any marks on the frame. Now you can see where the problem is and what needs to be moved, or filed, or cut deeper.
Every woman who wears makeup has lipstick she bought and cannot return to the store. She will be glad to give you a tube and get some use from that awful color.
Mar 16, 2014 | Kwikset Locks & Locksmithing
The bolt on deadbolt doesn't go all the way in
if it is new the lock could be installed wrong, most latches have a 60mm and 70mm option and when lock install wholes are not right, it trys to self adjust to half way between, measure from centre of big whole to edge of door, also take complete lock off and test with door open, turn lock with screw driver, hope this helps
Mar 11, 2014 | Kwikset Locks & Locksmithing
Bolts on a SentrySafe A3860 are stuck retracted in the door.
Sentry's Customer Service Department is available Monday through Friday, from 8am - 6pm, Eastern Standard time. Our internet Frequently Asked Questions can be accessed on line 24 hours a day, 7 days a week at www.sentrysafe.com
Dec 28, 2013 | Sentry Fireproof Safe
The T-turn is reversed
I my mind the actual lock bolt was assembled wrong. You need to gently twist the length adjusting unit /bolt directly out of its housing and then gentle separate the two pieces though fully separating them and then "flip" the actual little toggling metal piece that has the "U shaped and half circle looking hub that the lock shaft slides into, around from it currently position ... ie. reversing its throw. You may need to also adjust the spring metal piece underneath it as it run in a slot as well.
This worked for me ... when t-turn key is horizontal the dead bolt is extended ie. in locked position.
Apr 27, 2013 | Weiser Lock ED1460X3VKD Powerbolt 1000...
The auto clean was pushed while the door was half open, the lock engaged and will not reset.
If you can open the door since it wasnt fully closed when the lock engaged..open the door,push in and hold the oven light switch, and push the cancel button and the lacth should open
Aug 28, 2011 | Kenmore 95410 Kitchen Range
How do I lock the door with the key pad? I can unlock it fine but I can't get the door to lock. Don't have the manual. what buttons to I press?
Push the Lock button on outside touch pad to extend latch bolt 1" which locks the door when you leave.
Enter your desired personal code to retract the latch bolt completely which unlocks the door when you return home.
The T-turn on the inside of the door is used to extend (lock) or retract (unlock) the latch bolt when you are inside.
Using the key from the outside will also extend (lock) or retract (unlock) the latch bolt.
This Touchpad Electronic Deadbolt should be accompanied by a Kwikset Knobset, Leverset, or Handleset.
I cut & pasted the above from the installation instruction sheet.
Here is the link to the entire installation instructions sheet (manual):
http://s7d5.scene7.com/is/content/BDHHI/40486-02
It is a .PDF file, so if you aren't able to view it, download and install Adobe Reader from this site first:
http://get.adobe.com/reader/
If you are not able to lock the door using the outside touch pad's lock button, you may need to reprogram the door's "handedness", which gives the lockset the ability to be used on doors that have their hinges on either the right or left side of the door (right-hand or left-hand door).
The instructions for that are found on Step 4.9. This is also an excellent time to change the batteries, which is recommended yearly.
Aug 01, 2011 | Kwikset 907 907-15 Satin Nickel Powerbolt...
To unlock the bolt no code is needed... just by pushing the lock button it unlocks what do i have to do to make it function proporly
You need to reset the lock, so it will be set to the correct handing (left or right hand door).
Open the door and extend the lock bolt. Remove the battery. Press the reset button three times and wait 20 seconds. Push and hold the lock button, while inserting the batteries. Hold the lock button until the bolt starts to move. Allow the lock to complete it's learning cycle.
Program a new code and test.
Jan 09, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
The lock is installed need to know how to program
First make sure you have the door handing set properly. Retract the bolt manually if extended. Now press the lock button... If the unit extends the bolt, then you're good. If not, switch the jumper position on the control board. If it's covering pins 1&2, move it to cover 2&3 or vice versa.
To program code #1..
Push the program button on the control board once. Enter your 4-8 digit code. Push the lock button to end the entry. The unit will emit a 2-second long beep. If it doesn't beep, you were too slow. Try again.
To program code #2, press the program button on the control board TWICE. Enter your 4-8 digit code. Push the lock button to end the entry. As before, the unit will emit a 2-second long beep when a successful entry is made.
Test your codes with the door open just to be sure.
Dec 16, 2009 | Weiser Lock Powerbolt 1000 Lock
The rear doors do not lock when i push the lock button on the remote.
push the button. wait like half a second, then push it again. most cars lock only the driver door for the first push, then all the others for the second.
Oct 07, 2009 | 2003 Chevrolet Avalanche
Cannon G7 need help
Hi
Had the same problem a few months ago.There was a high pitchedwhisltle and I think the screen said "lens fault.turn off camera" or something similar.Bought a G9 to replace as the 7 was out of guarantee but sent the 9 back to the e-bay reseller as it was obviously secondhand with grit around the lens ring and the viewfinder.Ebay never again!.So 3 months ago ago I tried the G7 again with a fresh charged battery before I consigned the camera to the loft.I noticed that each time i switched on the whistle and message was there but the lens extended slightly further each timeso I kept rebooting until the lens was fully extended.Turned the camera off and on again and everything was back to normal.It seems that this may be Canons protocol when a camera goes back.Its been absolutely fine until today.It wont boot up at all.I have tried 2 fresh charged batteries and its dead.Any ideas anyone?
Nov 06, 2008 | Canon PowerShot G7 Digital Camera
Weiser Lock Powerbolt 1000 Lock Logo
50 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
john h
ray gallant
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
