Why can I NOT get T.V?
Cannot access cable
    Top Expert:
  • Televison & ... Master
  • 74,630 Answers
If tuner is faulty you can't access cable or on-air programs.
Posted on May 02, 2013
How do i adjust handbreak as cables have stretched
often times like on mazda3 you can find a small tab near the hand brake that can be popped open to access the adjustment nut. Tightening the nut will tighten the cables. Alternatively on models with out this added accessibility, the hand brake cables can be adjusted with greater ease at the rear wheels as opposed to removing the center column to gain access for cable adjustment. For more information check out http://autoabsolute.ca Auto Absolute Home Page
Mar 14, 2016 | Cars & Trucks
What kinds of ADSL access way divided into?
ADSL access namely use parallel twisted-pair cable access user home, using M connected PC, whether it's special line, virtual, routing, all leave twisted-pair and MODEM.White said again is to run the business broadband signal through the circuit access user home, using computer dial-up MODEM connection.As for the access network equipment, PON, connection cable trunk, wiring, equal twisted-pair, client PC, router, such as TV all need to slowly in the actual operation experience.
Oct 30, 2015 | Computers & Internet
Internet setup
It should work "out-of-the-box".
Be sure to connect using "straight-through" (not "cross-over") Ethernet cables.
Connect from the 'WAN' port on the router to your DSL-modem (or cable-modem).
Power-off the DSL/Cable modem.
Power-on the DSL/Cable modem.
Power-off the D-Link.
Power-on the D-Link.
Reboot your computer.
You should be good.
Mar 09, 2014 | D-Link DAP-1522 Xtreme N Duo Wireless...
Check connections
The connection of the USB cable
Verify that the USB cable is connected between your Brother machine and your PC.
The connection of the LAN cable (if applicable)
Verify that the network cable is connected between your Brother machine and access point and the machine is powered on.
1.Access point/router
2.Wired Network machine (your machine)
3.Wireless capable computer connected to the access point/router
4.Wired computer connected to the access point/router
The connection of the Wireless network
2.Wireless Network machine (your machine)
Still having Problem Then follow Us For
Brother Printer Support
Feb 20, 2014 | Brother MFC 7840W Printer
Can't access cable on new television
If the TV is new, contact the nearest authorised service center. Before contact them, read the manual carefully and follow the steps to access cable signal.
May 07, 2012 | Televison & Video
How do i hook up a wireless router to a cable router
If you already have a cable router, then you don't want to use a wireless router. You will want to use a wireless access point instead.
The reason for this is that anything plugged-in to your cable router will not be able to access anything connected to the wireless router due to the NAT firewall in the wireless router.
If the wireless router has the option to make it a "Gateway", then that will fix this issue; otherwise, take the router back and buy a wireless access point instead.
As for how you hook up the wireless router to the cable router, you have to unplug the power cord of the cable router for about 15 minutes before hooking the Ethernet jack from it to the wireless router.
Once the 15 minutes have passed, you then can plug the Ethernet cable from the wireless router "WAN" port into an Ethernet port on the cable router and then plug-in the power cord of the cable router.
Once the cable router is finished syncing-up, the cable router should provide an IP address to the wireless router.
If you really have a cable modem instead of a cable router, then you won't have to put the wireless router into gateway mode.
Dec 30, 2010 | Linksys Wireless-G WRT54G Router
Using WRTS4GS2 Cisco Router and could not access the internet. Remobed router and had instant access to the internet.
Contact your ISP. Some ISPs limit the number of computers that can simultaneously connect to your cable-modem. If you change computers, you have to tell your ISP.
Or, power-off your cable-modem, to "reset" it.
Connect the Cisco Router to the cable-modem.
Power-on your cable-modem.
Power-on your router.
Connect your computer to your router, and see if you get Internet access.
Dec 20, 2010 | Computers & Internet
I don't know how to reinstall the linksys access point!!! Our wireless network that we made simply disappeared, so I'm trying to re-make one. However, when I tried that with a flash drive, it couldn't work...
T
o access the Access Points Setup, and the LAN IP address has not changed, then computer must have an IP address of 192.168.1.XXX. If the Access Point is plugged in via Ethernet to a Linksys Router and the computer is also connected a Linksys router via Ethernet, then the PC should already have a correct IP address (unless the LAN IP Address of the Router has been changed). If unsure, please assign the computer a Static IP Address so it will have an IP address in the same range as the Access Points IP Address.
If the Access Point is being connected to a hub/switch/router via Ethernet, then use the cable that was provided with Access Point. If the Access Point is being connected to the computer directly, then a Cross Over cable must be used. Cross over cables can be purchased at most electronic stores.
    Remember: When ever a change is made in the Setup of the Access Point, the Apply button must be used to save the settings to the Access Point.
  1. Open a web browser (such as Internet Explorer or Netscape)
  2. When the browser opens, go to the "Address" bar and input the IP address of the Access Point.
      Default IP addresses:
    • WAP11 v2.8 - 192.168.1.251
    • WAP54G v1.1 - 192.168.1.245
  3. A "User Name" and "Password" prompt will appear, leave the "User Name" field blank and input the Access Points password (The default password of a Linksys Access Point is admin) into the "Password" field.
May 14, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
I have the ethernet cable plugged into a netgear wireless n router but when I run setup it says I don't have an ethernet adapter
ethernet cable and adapter are different!
1st see if you have internet access with the cable- if you have access then the cable is working
Aug 10, 2009 | Gateway Computers & Internet
SGH-E250 internet access via data cable or blue tooth to PC
You have to buy a data cable or use bluetooth.Create a dialer which dials *99# using your samsung modem over bluetooth
Dec 11, 2008 | O2 Samsung SGH-E250 Cellular Phone
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
