Question about Alesis Music
Alesis q25 Hi. I have been using an Alesis Q25 midi keyboard controller for a couple of months and its worked fine up until recently. All of a sudden I receive an error message everytime I plug it in. "USB device not recognized". I tried it out on another PC but with the same result. Is there any way I can get it to work again? I'd appreciate any ideas. Thank you in advance
  • Sima Miyanda May 01, 2013
    @debgreffe I'v already had a look through the manuals and documentation. Unfortunately, the answer to my problem isnt listed anywhere in them. Any other suggestions?
How to program drum beats from one alesis sr16to another alesis sr16 drum machines
5.4J Copy a Song to Another SR-16 Via MIDI
The SR-16 can send Song system exclusive information to another SR-16 via MIDI. If you have only one SR-16, you can skip this section.
1. The source SR-16 should be in Song mode and stopped. Connect the source SR-16 MIDI out to the destination SR-16 MIDI in.
2. Select the Song to be copied.
3. Press and hold the COPY button, and keep holding it down until step (5). The display says COPY TO SONG.
4. Do not enter any destination Song number-just press PLAY to send the data out over MIDI. It will end up in whatever Song number had been selected at the receiver. If the Song was not empty, the new Song steps will be appended to the existing Song steps.
5. Release the COPY and PLAY buttons.
Caution: This does not transfer Pattern information, only the song steps. To transfer Patterns to another SR-16, see section 3.3D and 3.3E.
Hopefully this helps, it comes out of the SR16 Manual, page 40 I think
Cheers Pete
Sep 25, 2014 | Alesis Sr 16 Stereo Drum Machine
Manual,I need manual for Alesis Q25
Go to : http://www.alesis.com/q25?tt=5 and click on the docs and downloads as shown in picture below. There you will find the pdf documents you are looking for.
Go to website address:
Apr 04, 2013 | Alesis Q25 25Key Keyboard Midi Controller
Keys working explanation or user guide
You need to load software on your computer that contains midi sounds - sampletank, Reaktor, etc. Make sure everything is set to Midi channel 1.
Jan 20, 2013 | Alesis Q49 USB/MIDI Keyboard Controller
Alesis dm6 bass pedal
There's a tiny switch on the back of the module "kick type" try switching that
Sep 22, 2012 | Alesis DM6 Electronic Drum Set
Hello guys, i have a problem with my midi keyboard. My PC doesn't recognize the USB connection and i can't find any solution.
Well first start by verifying USB port works by plugging in a hard drive or something thus proving you have a good port and USB Cable. At which point hook the keyboard up ( and make sure to properly install drivers provided on cd with purchase) being a pc this may take several attempts to install. What software are you trying to control? Reason? Logic? Fruityloops?
Oct 07, 2011 | Alesis Q49 USB/MIDI Keyboard Controller
How do you get sound coming from the keyboard without an amplifier?
You don't... in two words... this unit is NOT intended to generate sound without and external generator and amplifier... or you can use the puny sound generation in a connected PC.
Aug 09, 2011 | ALESIS 25 NOTE USB MIDI KEYBOARD CONTROL
How do i dump midi user patterns from alesis sr 16 to alesis sr18 drum machine thru midi cable
you may well have to go via a third unit, a computer or laptop to store the data then send it back to the other machine.
Dec 27, 2009 | Alesis Sr 16 Stereo Drum Machine
Cannot transfer beats from alesis sr16 to alesis sr 18 thru midi cable. Please advise.
The sync signal that is sent on the MIDI cable is actually a "clock" of something like 96 ticks per measure. This is the "MIDI sync clock". This is a single byte FF hex.
The beats themselves are not sent. The firing of the individual percussions should be.
My Alesis Sr-16 will suddenly start playing without being being commanded and it will also stop playing during a performance.Is this common and can it be fixed?
These will USUALLY stop playing if in a song mode that runs so many cycles and terminates.
The random starts CAN be caused if you have a MIDI input cable connected and ANY device sends a rhythm start command or starts sending rhythm clocks to the unit. You can usually disable receiving commands via MIDI and SHOULD do this unless you are actually using MIDI.
Other things would be electrical transients that could trigger the device. MAKE SURE ALL of your equipment that this is connected to is power from the SAME electrical outlet to avoid ground loops which can also damage your equipment as well as cause intermittent operation.
Nov 09, 2009 | Alesis Sr 16 Stereo Drum Machine
Music Logo
37 people viewed this question
Top Alesis Music Experts
drivealot
Lawrence Oravetz
Robert Graf
Are you an Alesis Music Expert? Answer questions, earn points and help others
