Question about Garmin nuvi 1450 GPS Receiver
Stuck on select locale - Garmin nuvi 1450 GPS Receiver
Automatic gear box problem
I would get the transmission fluid and filter changed .unless you want to rebuild it or replace it .
Oct 16, 2015 | 2005 SsangYong Musso Sports
Machine is stuck on reverse mode
Try this,Go back to straight stitch, zero your stitch length,zero your stitch width, turn your hand wheel towards you for few rounds then select a stitch length and see if the reverse lever will work normal after this. Otherwise get it fix by a local technician.
Nov 08, 2013 | Singer 4423 Electric Sewing Machine
03,YZ250- Wont select gears stuck in neutral shifts to 1st(i think) sometimes
Hi, Www_105eya for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary, transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your problem. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
YZ80 Tranny Stuck in Neutral Yamaha 2 Stroke
Bike won shift stuck in one of the upper gears
YAMAHA YZ250 LC Owner Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
May 16, 2011 | 2003 Yamaha YZ 250
Short Version: My Dell Inspiron 530 continues to get stuck on the Dell start up screen. Long Version: For 3 years my Dell Inspiron 530 had worked flawlessly, then all of a sudden it would continue to...
Try starting in SAFE MODE.
Restart the computer and push the F8 button repeatedly (before anything shows on screen).
(if you miss it just restart and try again)
When the options come up select START IN SAFE MODE NORMAL.
Wait for windows to start then:
RIGHT CLICK the MY COMPUTER icon on your desktop.
Then selct PROPERTIES
Then HARDWARE
Then DEVICE MANAGER
This will list all the hardware connected to your pc. If you see any red X 's or yellow ! 's next to their names then that means there's a problem with that piece of hardware and you can click on it to see what it is. Try RIGHT CLICKING on it and selecting PROPERTIES then DISABLE it if it's got a red X and then try rebooting normally.
If you still have problems booting normally, try booting into safe mode again...
Then LEFT CLICK on the MY COMPUTER icon on your desktop.
Then RIGHT CLICK on the LOCAL DISK C icon.
Select PROPERTIES.
Select the TOOLS tab.
Then select CHECK NOW in the ERROR CHECKING box.
This will check your C drive for physical errors and fix them if possible.
Once complete, restart and see if it will boot normally.
If you still can't boot then you either have a dead / dying hard drive or maybe just some bad RAM memory or maybe even a bad or loose cable connecting the hard drive to the motherboard. Either way more troubleshooting will be required.
Good luck and comment back if this was helpful and with how you make out.
Feb 02, 2011 | Computers & Internet
How i can change the language on my phone?
To set the phone language:
From the Home screen, tap the applications bar.
Tap Settings > Locale & text > Select locale.
Select an option.
Note: The chosen phone language is also the writing language, if not selecting a specific writing language.
To set the writing language:
Tap Settings > Locale & text > Standard keyboard > Select language.
Select an option.
Dec 09, 2010 | Sony Ericsson XPERIA X10 Cell Phone
Sir/madam, i have formated accer-aspire 4736Z laptop. there is an pre install window 7 ultimate but it give problem, so i jst formated with window xp-sp2. but the thing is tat it gives same problem as...
delete the partition and then formate it and reinstal the windows, after this run registry cleaner reg in out and a gud antvirus, i hope this will help u
Sep 16, 2010 | Computers & Internet
I was downloading windows automatic update and it updated to 83% and now if stuck there I have windows vista basic on a acer laptop anyone know how to fix this thank you
Please start the Computer and keep tapping the F8 key to access the Windows Advanced options.
Select Safemode.
Once you are in Safemode, follow the below procedure:
  1. Click Start, click Run, type services.msc, and then click OK.
    Note On a Windows Vista-based computer, click Start, type services.msc in the Start Search box, right-click services.msc, and then click Run as administrator.
  2. In the Services (Local) pane, right-click Automatic Updates, and then click Stop.
  3. Minimize the Services (local) window.
  4. Select all the contents of the Windows distribution folder, and then delete them.
    Note By default, the Windows distribution folder is located in the drive:\Windows\SoftwareDistribution folder. In this location, drive is a placeholder for the drive where Windows is installed.
  5. Make sure that the Windows distribution folder is empty, and then maximize the Services (local) window.
  6. In the Services (Local) pane, right-click Automatic Updates, and then click Start.
  7. Restart the computer, and then run Windows Update again.
  8. That should resolve the issue.
Mar 14, 2010 | Acer Aspire 5315 Notebook
Remote Desktop printing with TCP/IP printer
Go to the control panel on the remote server. Then go to the printers screen. From there "add a printer". Once there, select "local printer attached to this computer" and make sure to un-check the "automatically detect and install ... " option.
Then click next and select the second option of "create a new port" with the type of port being "standard TCP/IP port"
Enter the IP address of the printer. The name could also be entered, but the IP address would be better. Leave the port name as the default which will populate as you enter the IP address.
Once through there, go through the process of adding the drivers just as you've done before. The screen to do this will pop up automaticall, though it may take a moment. You might be able to just select the printer drivers from the list. But if you have the drivers saved on your server, it is best to click "have disk" and manually install the drivers.
Dec 07, 2009 | Microsoft Windows XP Professional
Laptop ip stuck on same nr
You can release and renew the IP.
Go to command prompt and enter ipconfig /release, press enter
and then type ipconfig /renew, press enter
see if it works.
(note:there is a space between ipconfig and the /)
Jan 27, 2009 | Sun 501-4366 X1034A PCI Quad FastEthernet...
Garmin nuvi 1450 GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
