Question about Fujitsu fi-6130z - Document scanner - Duplex - Legal - - PA03630-B055
Fujitsu Will not feed documents without completely stopping and starting over.
My fujitsue fi-6130 stopped automatically scanning both sides
You can try a 'hard reboot' of the unit by unplugging it while it is running, wait a minute or so and then restore the power.
With most electronics this forces a 'self-diagnostic' program which might fix the problem. Another option is to delete and them reinstall the software with a disc or online. Make certain that you have your machine set to automatically check for updates if it is connected to the Internet.
Jul 22, 2014 | Fujitsu fi-6130 Flatbed Scanner
Will not feed 11x17
You probably need to set the user settings to "long doc" mode.
1) When the machine is in the standby state,
press the NEW FILE key and Count Only key
simultaneously. During the user mode, the
LEDs of the NEW FILE key and Count Only
key illuminate and the address (U01-U10)
and data (the last digit) appear on the
counter display.
2) When changing the address, use the NEW
FILE key. Each time NEW FILE is pressed,
the address changes, cycling from U01 to
U10.
3) When changing the data, use the Count Only
key. Each time Count Only is pressed, the
data changes.
4) Pressing the Stop key exits the user mode.
Long document mode =U10; 0=normal and 1=long document mode.
Happy Scanning!
Scan-R-Store
Scan Store provides service and maintenance contracts on all Canon Fujitsu...
Apr 02, 2014 | Canon DR-9080C Path-Through Scanner
Fujitsu fi-5650C Error U1
Hello Ismail,
Error U1 referes to Frequent paper jam in Fujitsu fi-5650c scanner. In order to troubleshoot your scanner issue, you are advised to follow the steps provided below:
1. Do the documents satisfy the paper specification?
2. Have the documents been prepared properly?
- Align the edge of documents for stable paper feeding.
- Remove documents with creases or dog-ear corners.
- Scanning different widths documents may cause skew and result in paper jam.
3. Is the imprinter EXT cable connected to the scanner properly? (only when the imprinter is installed)
4. Clean the Pick roller, the Separation roller, the Brake roller and the Chute roller and see if the error is resolved.
5. Clean the Feed rollers and the Plastic rollers and see if the error is resolved.
6. Replace the Pick roller, the Brake roller and the Chute roller, and see if the error is resolved.
- Check the consumable counter in the software operation panel. When the counter exceeds the values, replace the Pick roller or the Brake roller.
If the above steps do not help, then yuo are recommended to contact the nearest Fujitsu service center for assistance.
Thanks & regads,
ScanCare
Dec 16, 2013 | Fujitsu fi-5750C Flatbed Scanner
Fi-6130z fujitsu scanner jamming repeatedly
Hello Meg,
To troubleshoot your scanner issue, yuo are advised to perform the steps provided below:
1.Remove all documents from the ADF paper chute.
2.Open the ADF while pressing down the ADF open lever. If your has the imprinter option attached, please open the imprinter and then open the ADF.
3.Remove the jammed papers from the ADF.
4.Close the ADF pushing the center part of the ADF carefully.
If document jams occur frequently, then please check the followings:
1. Do the documents satisfy paper specification?
2. Have the documents been jogged?
• Align the edge of documents for stable paper feeding.
• Remove documents with crease or dog-ear.
• Scanning different width of documents may cause skew and result in paper jam.
3. Are Chuter Unit (ADF paper chute),Guide P ASSY (Sheet guide), Feed roller cover (plate guide) and Brake roller cover installed correctly?
4. Clean the Feed rollers, Eject rollers,Plastic rollers, glass surface and paper feeding surface, and see if the error is resolved.
5. Check the consumable counter from the TWAIN driver screen. When the counter exceeds the values, replace Pick roller or Brake roller see if the error is resolved.
6. If the issue still persists, then you are recommended to contact the nearest Fujitsu service center for further assistance.
Hope the above information is helpful.
Thanks & regards,
ScanCare
Nov 26, 2013 | Fujitsu Fi6130z Sheetfed Scanner
We are a medical office that is currently using the fujitsu fi-6110. When scanning documents the feeder is pulling through 2-3 pages at a time and we are not getting all of the documents scanned due to...
Hello Jenny,
Please clean the followings using a cloth/ cleaning paper moistened with iso-propyl alcohol:(Pls refer to page-95 of your scanner getting started guide)
1.Pad Assy 2. Ultrasonic sensor 3. Idler roller 4. Pick roller 5. feed roller 6. Eject roller and 7. Glass surface
If the above doesn't help, then check the Pad Assy & Pick Roller count. If the counts exceeds the suggested replacement cycles, then you you may have to replace the same. Pls refer to page-99 of the getting started guide supplied with your scanner.
Thanks & regards,
ScanCare
Sep 12, 2013 | Fujitsu fi Office Equipment & Supplies
Scan multiple pages
Hello Chris,
Please check the followings:
1. Are the multi-feed conditions and paper quality requirements satisfied? - Please confirm whether the documents satisfy the conditions described in "Multi-feed detection condition" and "Document quality" of Error Recovery Guide.
2. Did you fan the document before setting? Has the document just been printed with copier or laser printer? - Please reduce sheets of the document or fan the document 3 to 4 times to remove static electricity.
3. Is the thickness of the bundle of documents less than 5 mm?-Please reduce the number of sheets of the document to satisfy the condition.
4. Is the Brake Roller dirty? - Clean the same
5. Is the Brake Roller set properly? - Please install the Brake Roller correctly.
6. Is the Brake Roller worn out? - Please check Brake Roller and Pick Roller counters, if the recommended cycle has exceeded or if the Brake roller is worn off, then please replace the Brake Roller.
If the above information doesn't help, please contact an authorized FUJITSU scanner service provider or the dealer where you purchased the scanner.
Thanks & regards,
ScanCare
Aug 21, 2013 | Fujitsu fi-6130 duplex scanner
Error J1
Hello Sharon,
When a document jam occurs, "J" and "1" will display alternately on the function number display panel of the scanner.Please perform the following:
  1. Remove all documents from the ADF paper chute.
  2. Open the ADF while pressing down the ADF open lever. If you are using fi-6130 with the imprinter option attached, please open the imprinter and then open the ADF.
  3. Remove the jammed papers from the ADF.
  4. Close the ADF pushing the center part of the ADF carefully.
If document jams occur frequently, please check the followings:
resolved.
5. Replace Pick roller or Brake roller, and see if the error is resolved.Check the consumable counter from the TWAIN driver screen or from the built-in Maintenance mode. When the counter exceeds the values, replace Pick roller or Brake roller.
Thanks & regards,
ScanCare
May 03, 2013 | Fujitsu Office Equipment & Supplies
Fujitsu fi-5900C jams
there are many optical sensors in the paper path, you need to clean all. if not solved, reply with error code with detail code
May 27, 2009 | Fujitsu fi-5900C Pass-Through Scanner
When using the adf get error message
Advice is terribly difficult without a model number of your machine
Mar 06, 2009 | Canon Office Equipment & Supplies
The document feeder keeps trying to feed
You have a bad Document transfer sensor. Sensor is located under the doc. transfer roller.
Nov 15, 2006 | Sharp FO 6600 Plain Paper Laser Fax
Fujitsu fi-6130z - Document scanner - Duplex - Legal - - PA03630-B055 Logo
124 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Smidler
Level 1 Expert
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
