Question about Canon DR9050C
Failed to load Scanner
Accessing Scanner from EMC ApplicationXtender product (Image Capture Solution) After selecting scanner driver from the scanner configuration and Error comes up "PIXPACK" lower left corner of the task bar. followed by FAILED TO LOAD SCANNER. Working fine when accessing without ApplicationXtender.
mohanchennai
  • 490 Answers
SOURCE: Scanner command invalid in current state
I have not used CapturePerfect 3.0. Hope the scanner is just fine. Try count only mode to check if it is okay.
Uninstall Captureperfect. Run chkdsk/scandisk to check if OS is ok. Reinstall Captureperfect again and it should work.
S. Mohan
Posted on Feb 21, 2008
jackboy
  • 2985 Answers
SOURCE: CANON 3000F
If you are runnnig XP or Vista this will happen
Go to Start/Programs/Accessoris/System Tools/Compatability Wizard
Reset the machine for Win 98
Posted on Mar 20, 2008
Pterocarpous
  • 202 Answers
SOURCE: Tvichw32 Driver Open Error
Hello Aunt Pat
(01) Is this scanner "new" to the computer it is installed on now (where you're experiencing these issues)?
(02) Did this problem show up w/out apparent cause or relation to any recent changes on your system (e.g. New hardware or software installed, updated, upgraded or removed; system crash; computer repair; etc.)?
(03) Did the problem appear soon after a change to your system? (see above examples)
There are many references to this issue on the Internet. I've listed a few here. You can find many more, if you like, by performing search engine queries.
THIS links to a Roxio forum thread regarding this issue. (Even if you aren't using Roxio software, the information here could be relevant to your issue.)
THIS link will explain a bit about what TVICHW32 driver is.
I'd reinstall the ASPI drivers. A driver file may have become corrupted. (Assuming you'd been using this scanner successfully on this system until recently.)
You can find links for Adaptec's ASPI drivers on their web site HERE. They also have an ASPI version checker you can run to find out what verison is installed on your computer.
** Please, post back here w/ answers to
** these questions and the results of what
** you've tried. We may need to go back
** and forth a few times. We WILL continue
** to work w/ you until your problem is re-
** solved.
** Just be sure to not rate the experts' "sol-
** utions" until that time. Once you do,
** the problem will be closed and we'll no
** longer be able to assist you.
** Thank you @:)
Posted on Apr 10, 2008
  • 111 Answers
SOURCE: error 201
Which scanner is this? Error (201) usually indicates some sort of power issue...such as the scanner is not getting enough power. If this is a USB powered scanner you may try connecting to different USB ports on the computer.
Posted on May 08, 2008
  • 111 Answers
SOURCE: CanoScan LiDE 50 error code: 2,7,0
Has your scanner been working before?
If so, has anything changed since then such as new printers or other devices added to the computer, or upgraded to a new OS?
Which OS are you using?
When exactly does the error occur?
Does ScanGear open?
Are you able to preview?
Try connecting the USB cable to another port on the computer (directly to the computer...not through a HUB or any other device). Bypassing a hub, which would have to be a powered HUB, or other devices would rule out any issues with those devices.
Ultimately trying the scanner on another computer would rule out issues with the scanner as well.
Posted on May 10, 2008
What scanner drivers do I need for scannerCS5600F .Just had new hard drive in iMac running OSX Lion 10.7.5
No additional drivers are necessary. Your CanonScan 5600F is listed in "Printer and Scanner software available for download," http://support.apple.com/kb/HT3669 .
To add your scanner, simply plug it in. If it does not appear in Apple Menu > System Preferences > Print & Scan, you may need to run Software Update (also from the Apple Menu, second item down), and then click the plus ( + ) button in the lower-left of Print & Scan, select your scanner, and then add the printer.
The default scanning application in OS X is Image Capture. After completing the above steps, open Applications > Image Capture and you should see your scanner listed on the left.
Sep 11, 2013 | Computers & Internet
We would like to connect our Epson GT-15000 scanner to our new Imac 29inch. Although we do have the scanner connected to a G5, we seem not to have any sfotware for Mac, only the Windows CD. Where can we...
No additional drivers are necessary. Your Epson GT-15000 is listed in "Printer and Scanner software available for download,"http://support.apple.com/kb/HT3669 .
Aug 28, 2013 | Epson Office Equipment & Supplies
I have an Agfa snapscan e20 and would like to use it from my Macbook. The scanner is an old thing. Is this possible and can you give me software to download? Thanks
First thing you should do is after you have connected the scanner to your computer, go to Finder, navigate to Applications and then double-click on the "Image Capture" icon. Press the "Scan" button on your scanner. The Image Capture application will recognize the connected scanner and will display a preview of the picture. Select any special options you want for the scanned picture and click "Scan" in the lower-right corner of the preview window. A scanned image of the picture will now be saved to the "Pictures" section of your user folder. I am advising you to try this as your MAC OS might recognize the scanner without the drivers.
If that doesn't work, try the drivers from Agfa website for SnapScan E20. Website doesn't specify for which MAC OS version they are. In addition, here's a link to th manual.
Dec 16, 2010 | Agfa SnapScan E20 Flatbed Scanner
Trying to load CanonScan N124OU onto Windows 7 and get error message "there is no application registered for this event"
canon scan n1240u will work on Win7
here's how:
go to this site: http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_n1240u#DriversAndSoftware
click "Drivers and Software" then select OS "Windows XP" then download "WIAdriverN670UN676UN1240U.EXE"
Install the WIA driver on your Windows 7 OS and used only mspaint to capture image on the scanner
TWAIN doesn't work on Win7 but WIA still doesGood Luck!
Dec 06, 2010 | Canon CanoScan N1240U Flatbed Scanner
How to scan using an imac
  • Connect a USB or FireWire scanner to the iMac using the scanner cord and the ports on the back of the iMac. Turn the scanner on.
  • Use the CD or DVD that came with the scanner to install any required software drivers. If the manufacturer's instructions indicate the scanner does not require additional drivers, you can skip this step.
  • Put the object you want to scan face-down on the bed of the scanner.
  • Scan the object by pressing the "Scan" button on the scanner. Image Capture will launch automatically and display a low-resolution preview scan.
  • Set up the scan using Image Capture. The settings available will vary depending on the scanner you are using. With most scanners, you can select a specific area of the object to scan, choose a scan profile based on the type of object you are scanning, adjust the color options and set the resolution.
  • Click the "Scan" or "Scan to Folder" button to scan the object. The image will save to the "Pictures" of your home directory if you press "Scan." The image will save to whatever folder you specify if you press "Scan to Folder."
  • Oct 25, 2010 | Computers & Internet
    How to scan slides to photos to hard drive using canon canoscan 8400f
    Your scanner came with some software inside the box. If this is a second hand scanner with no additional software download the drivers from www.canon.com and run the software accordingly.
    Mac os X does not require this process. connect the scanner to your machine and simply load the slides in the tray scanner and use the application "IMAGE CAPTURE" located in local_disk/applications/
    The pictures automatically load and you select to crop or scan as is.
    Later the image will appear on the desktop upon completion of scan.
    For windows: I made you a link for your convenience: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=10242
    Nov 07, 2009 | Electronics - Others
    How to scan with mac
      1. Connect a compatible scanner to your computer. A list of compatible scanners is available in technical document 107203 "Mac OS X 10.2: Scanners Compatible With Image Capture "
      2. Install any necessary software drivers that came with the scanner.
      Note: Not all scanners require the installation of additional software drivers.
      3. Turn on the scanner.
      4. Press the scan button on the scanner. See the documentation that came with the scanner for specific instructions. Image Capture opens automatically and a preview scan appears.
      5. Select the area of the image you want to scan.
      Figure 1 Preview image with area to be scanned selected
      6. Click Options in the toolbar to adjust settings specific to your scanner.
      Figure 2 Options icon
      7. Adjust any settings in the drawer that appears.
      8. Click Scan.
    The scanned image is saved in your Pictures folder in your home directory and opened in Preview.
    Note: These are the default options. They can be changed in the Image Capture toolbar.
    Jul 16, 2009 | HP Photosmart C6280 Printer
    Installing Acer Scan 2 web 3300 flatbed scanner on to vista
    Dear Redlikedrum,
    The ONLY way I was able to find ANY scanner drivers for ACER products was via their European FTP site: ftp://ftp.work.acer-euro.com/scanner/drivers/ I suggest you try accessing that site and getting the latest drivers they have (which seem to be for their SCSI scanners). They have both an ISO image file and a Nero image file (.nrg) either of which you'll have to burn to a CD to check out.
    Cheerup and Be Happy Always
    Mar 26, 2008 | Acer Scan to Web 3300U Flatbed Scanner
    ACER 620 P SCANNER
    I Want Mercury Scanner 620P windows xp Driver
    Aug 16, 2007 | AcerScan 620PT Flatbed Scanner
    Canon DR9050C Logo
    321 people viewed this question
    old marine
    old marine
