Question about Philips Televison & Video
What is the replacement ic of STV8172A - Philips Televison & Video
Why my proel. flash12a hi frequency ic does not work even when I replace the ic Tda7293
Replace with an other one. And then an other; till one IC works for you.
"Just contact any service technician. It is best for you"
Aug 16, 2016 | Televison & Video
I ve a nokia n72 phone the IC of which is damaged. As a result I am not getting a proper display. what is the cost of getting IC replaced?
Hello SD,
If you have diagnosed that IC is damaged. Then please visit any Nokia service center near by you.They will check it properly and replace the IC with original IC spare part. You will get the IC replacing quote from Nokia service center itself only.
May 10, 2011 | Nokia N70 Cellular Phone
How do you adjust the vertical lines going across my screen?
The vertical deflection circuit of your tv has a problem.
First, try to replace the vertical ic. This ic can be found near the plyback or horizontal section. It is a linear ic with heatsink.
If nothing happens after replacing the ic, replace all the polarized capacitor near the ic and resolder the components at the vertical section.
Jan 18, 2011 | Durabrand BH1304D 13" TV
Had convergence problem; replaced 2 stk392;
100% Ur 2 STK convergence ICS are still dead.Ur ICS soldering some how,u got the ICS shorted.Or ur ICS not right kind of STK ICS,u replacing in ur convergence board.
Apr 07, 2010 | Panasonic PT-56WXF95 56" Rear Projection...
Convergence
Panasonics will usually need the 2.2 ohm 2watt resistors replaced with the ICs , as usually at least one will blow possibly two when the ICs fail. If you didnt replace the resistors you will also most likely need to replace the ICs again as a bad resistor will ruin new ICs usually
Jan 05, 2010 | Televison & Video
HD52W59
Did you chane your ICs recently? If so did you replace the resistor near the ics? These resistors often fail and if you replace the convergence ICs without replacing them they will take out the new ICs quickly.
Jan 27, 2008 | RCA HD52W59 HDTV Projection Television
Kv-36xbr800
Hiii...
My version is :
For safety reason you should replaced them ( Horizontal ic,Vertical ic, Deflection ic) and olso all the big capasitor nearest the ic....that's my version....if you have big budget for it....he..he....
Thank's
[Vrya]
Dec 27, 2007 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Convergence adjustments
did you use the proper STK IC's Do the replacement IC's have SANYO on the face of them? If they do not, this could be your problem. You must use the IC that the manufacturer recommends. All IC's are not alike. Go to MCM electronics and enter your IC number and they sell original SANYO IC's. Good Luck
Jul 18, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Televison & Video Logo
217 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
