SOURCE: we have samsung 50 inch plasma tv, we have only half a screen
I have a Phillips 50 inch Plasma. About two months out of warranty the top half of the screen would go black. Sometimes when we tapped on the back behind the upper right hand corner the picture would return. I did some research online and found that there is a Main Y sustain board (much like a mother board in a computer) and connected to that board is a upper Y Buffer board and a Lower Y buffer board. According to my research these boards seem to be the source of the problem. I am assuming that the upper buffer controls the top half of my screen and the lower controls the bottom. I removed the back of my TV (about 50 small screws) and searched for these parts by part number. Surprisingly all of the parts in my Phillips are made by Samsung. I found the parts on ebay at shopjimmy.com. I decided to try replacing the upper Y buffer first. I ordered it from shopjimmy for about 100.00. When I received the part I started to remove my upper Y buffer and realized that the new part was slightly different. The part number was the same but the REV. number was slightly different. The new part was missing a small white connector that connects the upper buffer to the lower buffer. I sent it back for an exchange for the right part with no problem. Ok so here is the interesting piece of this little adventure. When I started to remove my upper Y buffer I removed the screws and started to pull on it to loosen it. When I noticed that I had the wrong part I pushed it back into place and put the screws back . My TV has worked perfectly since I did that, with my original part. It has only been about two months, but if you are in the same situation it might be worth a try.
SOURCE: 50 inch samsung tv clicks on and off when turn on
the Fuse needs to be Replaces, contact nearest samsung service center. would cost just $1 trust me
email me if you need any assistance ... [email protected]
SOURCE: my 50 inch samsung plasma tv turns off and on by
My Samsung 52" plasma TV will shut off while watching TV. It will do it repeatedly and we have to turn it back on. Is it overheating and shuts down? How can this be fixed?
SOURCE: my vizio 50 inch plasma tv will not turn on. what
Tries unplug,replug about an hour,see if it reset itself.Not than must replaced the signal tuner board.Plasma have this problems alot.
SOURCE: I have a 50 inch Samsung, Model FPT5084X/XAA that won't turn on.
Seems to be a chronic problem for this model. My list of service calls with Samsung is quite lengthy.
