Question about Kitchen Ranges
Kenmore 97273100 72731 gas dryer
I need a new ignitor
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
Please check that model number again. I don't get any results with the number you posted.
Posted on May 03, 2013
  • Richard Roth
    Richard Roth May 03, 2013
    Is that the number listed on the inside of the door area? I get nothing with that number. Sorry.
Kenmore 90 series gas dryer no heat
The gas ignitor most likley is not functioning. They do not have a pilot light like appliances in the oold days. They must ignite a new flame each use. if you don't smell gas when you try and use, then it is the ignitor and the computerized sensor tells the gas not to turn on because the initial flame has not been created.
Oct 08, 2012 | Kenmore 63942 Dryer
Kenmore elite gas dryer he3 model 110.95862402 won't heat
Since it is gas, you need to find out if the ignitor is coming on to ignite the gas (if you have gas getting to the burners). If you have gas, but the ignitor is not coming on, then you have to determine if the electronic contol is sending a signal for the ignitor to ignite. The most likely cause is the ignitor
Jan 16, 2012 | Kenmore Dryers
You have answered this question before but does the ignitor stay on during the drying cycle? Kenmore series 80, model 110 72822101 gas, It starts correctly, ignitor glows, gas ignites,run for 5 to 6 min....
yes..
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 07, 2011 | Kenmore 72802 Gas Dryer
Just replaced the ignitor in a kenmore gas dryer model 110.76652500. After reassembly I turned on the dryer and it worked for about 20 minutes then quit. The ignitor still works (it cyles no and off every...
you have bad gas coils or a bad gas valve but most of the time it's the coils.if you just installed a new ignitor and it's glowing most likely it's the coils
Oct 07, 2010 | Kenmore Dryers
Will not dry clothes
How old is the dryer? The ceramic ignitor piece may have partially broken off. It gets very brittle over the years. Look for a broken piece laying below where it sits. If you replace it, do not touch the ceramic part of the ignitor or it will not work right. Sometimes it's just as simple as a corroded wire connection. I once worked on a 25 year old Kenmore gas dryer that would not ignite. With the power cord unplugged, I disconnected and reconnected all the wire terminals inside and tried it again it worked perfectly like it was new.
May 14, 2010 | Kenmore 73952 Gas Dryer
Kenmore propane dryer 70 series does not lite
Assuming the gas is on. The most likely problem is a bad ignitor. Remove the bottom front panel(pop 2 clips at the top of lower panel with a flat screwdriver) and turn the dryer on Look for the ignitor to glow. If the ignitor does not glow test leads to ignitor for power if you have power replace it. If the ignitor glows then you are not getting gas check to make sure the gas supply is on.
I hope this helps if you need further assistance please let me know.
Apr 14, 2010 | Kenmore Dryers
Kenmore dryer not heating
you'll need a meter,check the ignitor, and the sensor,if these are good you have bad gas coils or gas valve,come back with full model number and check to see if ignitor is glowing
Nov 07, 2009 | Kenmore 73952 Gas Dryer
Kenmore dryer tumbles,don't here any clicking,ignitor not getting hot, installed new ignitor last year along with 2 magnetic cylinders
read out the sensor,if that is good try tapping the gas valve sometime if the valve is sticking tapping it will get it to work,make sure gas is on
Nov 03, 2009 | Kenmore Dryers
Gas dryer ignitor not activating
You have to use a voltmeter to test the circuit. You must connect a voltmeter to the leads that go to the ignitor, and then start the dryer. If the ignitor is getting 120 volts, but not lighting, then you need a new ignitor.
If you do not feel comfortable doing this test, you could simply replace the ignitor and hope its the problem
Jun 10, 2009 | Kenmore 63942 Dryer
How do i change the ignitor in my dryer
First, why do you think ignitor. In all the dryers I fix only 1 dryer in 999 need the ignitor replaced.... Hit me back before midnight for more help........
Dec 12, 2007 | Kenmore 74832 Gas Dryer
Kitchen Ranges Logo
51 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
