Question about Cycling
Rear brake is detached on my bicycle
Somehow the rear brake got detached on my bike (specialized rockhopper) and I can't figure out how to fix it.
  • 3 Answers
Something doesn't look right, like something is missing. You may want to look at a similar bike to get a better visual as to proper configuration.
Posted on May 01, 2013
SOURCE: Bicycle Rear Wheel Problem
You may have buckled your wheel if its a spoked type ! If you have buy a spoke key and tighten the spokes opposite the buckle .............ie if the buckle goes over to the left stop wheel and tighten spoke that lie on the right of the rim ..........it fairly easy if your rim is not to badly damaged..... you will have to keep on tinkering to true the wheel up.......ps also check your spoke are tight before starting as i have seen spokes just loosen for no reason.......hope this helps.
Posted on Nov 02, 2008
  • 71 Answers
SOURCE: rear bicycle wheel won't turn. Brakes are siezed.
Find the arm that hold the cable. Loosen it to the desired tension.please comment if it does not work for you! I can help! Good Luck!
Posted on Jun 11, 2009
  • 1137 Answers
SOURCE: adjust rear hand brake on Mongoose 20 inch bicycle
Here is the perfect site for you:http://www.bikeguide.org/how-to/brakes/brakes.php They're called gyro brakes by the way.
Posted on Aug 28, 2009
  • 1137 Answers
SOURCE: i have an ironhorse freestyle bmx bike and I am
Here is a great site with more than just brake info:http://www.bikeguide.org/how-to/brakes/brakes.php Please let me know if this helps.
Posted on Dec 04, 2009
  • 21 Answers
SOURCE: Men Mountain Bike (26"): How to adjust tention on the rear brakes...
Your bike likely has linear pull brakes so you will need to a. loosen the pinch bolt that holds the brake cable to the noodle (down at the wheel). You then pinch the brake in towards the rim with your hand until it's almost touching and then retighten the cable. You can then do some fine adjustment on how close the brake pads are the rim with the adjusting nuts up at the levers.
Posted on May 20, 2010
Brake is sticking. how do you fix. is rear brake
The web is rich in resources for 'how to' do just about anything on a bicycle.
"adjust rear brake on bicycle"
One resource...
http://www.parktool.com/blog/repair-help/linear-pull-brake-service-v-brake-type
Aug 23, 2011 | Mongoose Spear 26 Inch Men's Bike
I have rockhopper sl, just taken the front wheel off for the first time, and accidently pressed the brake lever now the pads have locked and i cant get the wheel back in, please help, is it safe to use a...
Don't use a screw driver. That means you have hydrolic brakes. Take it to a bike shop. It is relatively difficult to open w/o damage it is easy to damage. Also, pick up some disk brake spacers that you put in when you remove the wheel to prevent just this problem.
Jul 14, 2011 | Specialized Bicycle Components Specialized...
I am looking for an owners manual for my specialized rockhopper fsr - 2004 or 05. Where can I find one?
um, specialized.com - look under support
It is the rare bike indeed that has a unique manual.
Jul 11, 2011 | Cycling
I have a ironhorse bmx bike and i cant figure out how the rear brake goes together. how can i fix my bike?
There are few variations on these brakes but this Youtube clip will give you the idea. http://www.youtube.com/watch?v=waX3p7oFTmM
Jun 09, 2010 | Iron Horse LZ1 20 Boys' BMX Bicycle
I would like a Specialized Mountain Bike Manual
you can download it from specialized.com they have a really good site, i ride a stumpy myself and have used the site regularly
Jan 15, 2010 | Specialized Bicycle Components Specialized...
I have an ironhorse freestyle bmx bike and I am having some issues with the rear brake. The rear brake was detached so the bike would perform more freestyle tricks and i cannot get it reattached so that...
Dec 03, 2009 | Cycling
Dont know how to put the rear shock back onto bike
Diagrams are available in the website under the support tab. Just note the you have to remove the crank on the right side to get to the nut that holds the lower eyelet into the frame (torque nut (not the bolt) to 120in/lbs with a torque wrench.... yes you have to use the torque wrench.... Push the bottm bolt in first then the top one then tighten both to 120in/lbs. The brain hose should bend under the main pivot nut and then inside the rear triangle and brake hose. Torque the bolts to 70in/lbs. Go ride!
Sep 23, 2009 | Specialized Bicycle Components Specialized...
Cycling Logo
200 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
