Sony tv Locked
Dear Reader I Have Sony Wega 34'' without original remote controller, I Have Universal remote controller to operate it but now it shows Key sign on screen (right upper corner)and i cannot access to any option like volume up & down, channel changing etc except standby option. If any body knows the solution about that particular problem. Please Let me Know i Shall be grateful to you
    Top Expert:
  • Televison & ... Master
  • 75,571 Answers
Download its user manual by internet. Check this site. www;retrevo.com. The manual will have all details.
Posted on May 02, 2013
SOURCE: TV suddenly doesn't respond to Sony remote & power button on Satellite remote.
I am having the same problem with the "initial setup" screen flashing repeatedly/ intermittently. It's not a problem with the remote. In the research I have done online, it seems as though this is a common/known problem with the Wegas that will require a service visit. Apparently the problem is a defective receiver chip. The best thread I found is at: http://www.agoraquest.com/viewtopic.php?topic=15393&forum=34&start=0&select_page_number=1 I've seen some speculation that it is caused by windex or cleaning fluid dripping down when the screen is cleaned and corroding one of the internal components. That's not applicable in my case, since I always just clean the screen with a microfiber dusting cloth. So, I guess I will be calling a repairman and spending $$$ to fix as it is now flashing up so often as to be unwatchable. Ridiculous, I think, given that my TV is only 3 years old!!
Posted on Jan 11, 2007
  • 22 Answers
SOURCE: Can't access AV Channel on Sony KV-C27TD
If the TV has no RCA inputs, then there is no "AV channel" option for it on any remote, just channel selection.
The purpose of a RCA to SCART converter (aka RF modulator) is to convert one of your channels to an A/V input. They operate (standard) on either channel 3 or 4 as selected by a switch on the converter.
If your converter is unpowered, it's entirely possible that the signal coming out is not good enough to overpower your antenna signal. In this case, you may need a powered unit (such as this one http://www.bestbuy.com/site/olspage.jsp?skuId=5806345&productCategoryId=abcat0107025&type=product&tab=7&id=1067388827858#productdetail) which can actively "shut off" the antenna input when signal is received from the auxiliary device.
Posted on Nov 13, 2007
crazy larry
  • 6 Answers
SOURCE: how to access AV channel on Toshiba TV model 2125RA
some sets auto-go av when you plug a rca jackin the set, others have a switch in front or back , others you might set your channel to 00 or 99 or 100 forget and work different , I the owners manual of course would tell you. but I assume u dont have it . try hooking it and letting the dvd run now find it using the remote.
good luck.
Posted on Feb 23, 2008
SOURCE: PIP won't turn off
I pressed "Demo" on the front of my TV and it worked, I have an old Sony KP-53XBR35 VIDEOSCOPE XBR - no original remote and the Universal remote has PIP button but would not shut it off.
Finally it's off!!!!
Posted on Mar 16, 2009
SOURCE: Verizon FIOS remote buttons all work except
I had the same problem with a Sony Trinitron KV-32FS320 32" TV. I reset the remote to factory default.
  • Press and hold STB
  • While holding STB, press OK
  • Release both keys, wait for device keys to blink twice
  • Press 9-0-0. The STB key will blink three times
Then I reprogrammed the TV control.
  • Turn your television on
  • Press STB to enter Set Top Box mode
  • Press and hold TV
  • While holding TV, press OK
  • Press 1-1-2-7. This is one of the Sony TV codes
After this, the volume + and - worked to control the TV.
  • Program any other devices, such as DVD using procedure similar to above.
I hope this works for you.
Posted on Jun 29, 2009
How do I turn on cc without remote control?
Unfortunately, you can't reach the CC (Caption Vision) sub menu without a remote control. You need to find another RM-Y121 remote or a Universal remote that supports the Menu feature of the original remote. (Some universal remotes do not include a Menu button. Avoid those cheaper models. You may have to search all Sony TV codes to get the needed button to work.)
A replacement original remote is available from EMT Company at http://www.emtcompany.com/sony-rm-y121-remote-control/101317789.html . The remote costs ~$12. Amazon has a vendor with a used version of the remote.
I wish that I had better news for you.
Sep 19, 2015 | Sony KV-32V16 TV
Sony manuals
http://remotes.com/
You can with a good universal remote control that have the feature in it. But above the webpage to get your own original remote control for your tv. Good luck
Dec 18, 2013 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Remote control issues
If you whsh to get all functions operated with your TV, you must have its original remote control, and it is no doubt. No universal remote control will operate with all functions, that are supposed to be, especially to Sony Brands. You can buy the original remote control from the authorized service center for Sony, or from any authorized dealer for Sony. Then why do you go for an experiment
May 14, 2013 | Sony Bravia KDL-32V4000 32 in. LCD TV
Sony trinitron number is kv20fv12 what is the number for a remote controller for this tv
The original remote control number to this set is {RM - Y198}. If you buy its original one, contact the nearest authorized service center for Sony. The universal remote control codes for Sony Brand Tvs are: 0128 0013 0002 0071 0380
If you wish to buy a universal remote control, check whether there is these codes with its code list. The code list will be attached with every universal remote control pack. Make sure there are these codes with it.
In my opinion, it will be best to buy its original one. Original is Original, and Universal is Universal!!
Oct 27, 2012 | Sony FD Trinitron WEGA KV-34HS420 34" TV
My tuning menu is locked and i've no remote. how do i do this manually?
To unlock it you must have its remote control. Contact the nearest authorized service center for Sony, to buy an original remote control to your set.
Sep 27, 2012 | Sony FD Trinitron WEGA KV-24FS120 24" TV
No remote sony wega
You can simpley fix this problem!
Just buy a universal remote!
BTW: Don't buy a new kind but on older kind of universal remote!
It's just 10 bucks in a electric store!
Sep 08, 2012 | Sony Grand WEGA KDF-55WF655 36" Rear...
Don't have original remote control. Somehow, a window for PIP opened, and I can't get it to turn off. Have a new sony remote RM-V310A, but the PIP button won't activate the remote. Any...
Many TV functions can be controlled from the on-screen menus using buttons on the TV itself. These include all kinds of settings however Sony did not include PIP in these menus. Therefore a valid remote is required to operate PIP. One thing you could try is removing the cable from the secondary input on the TV which provides the signal for the other picture. Without an input signal PIP may be disabled. Also, try buying a universal remote and setting the proper code for your TV. Original remote could be hard to find but remotes.com may have one.
Aug 05, 2010 | Sony KV-27S45 27" TV
Remote sensor is not working
TRY GETTING A SKY REMOTE THEY ARE PRE-PROGRAMED TO ALL SONY TV'S
Nov 11, 2009 | Sony FD Trinitron WEGA KV-32FS320 32" TV
Video input permanently displayed
If there is no "input video" button on the control panel of this series of set, as like the older Sony sets had, you need to order the original remote from the Sony service center, or Sony parts directly. Universal remotes (any that I know of) will not access this menu in your Sony set.
Jerry G.
Jul 06, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Tv remote codes
I have a Zenith universal remote that i want to program to a sony 27 inch Trinitron, what are the codes?
Nov 03, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Televison & Video Logo
Top Televison & Video Experts
