Question about Husqvarna Lawn Tractor Yth2148 Owners Manual
Engine misfire I have a Husqvarna YTH2148 that has a very cyclic misfire (about every 3 or 4 seconds). during the misfire it blows black smoke. As a result it fouls plugs very quickly. I change the oil, oil filter, gas filter, and air filter regularly. Any suggestions on where to start looking?
  • Husqvarna Master
  • 1,807 Answers
Mowers aren't my forte but it sounds likt the valve clearances need checking. Here is a link to a description of how to correct the valve gaps.
Posted on May 02, 2013
steve_lima
  • 181 Answers
SOURCE: Husqvarna chain saw starts and runs for 20 minutes then stops.
two things could be happening.......first is vapor lock......make sure you breather tube is clear and working........next is ....it could have a bad ignition coil on it.....after the coil gets hot the spark can become irratic or just not work any more.....
Posted on Feb 23, 2009
  • 597 Answers
SOURCE: Husqvarna 223l trimmer shuts off
See if air cleaner is plugged or needs changed or cleaned
Posted on Jun 05, 2009
dontbother10
  • 2220 Answers
SOURCE: 353 husqvarna chainsaw, floods during start process
Husqvarna says the initial carburetor needle valve settings are from lightly seated 1 turn CCW for both H & L.
Your Operator's Manual can be downloaded here:
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2004/HOUS2004_1140204-95.pdf
Once flooded Huskys are very hard to start. This works well on my 359.
Start Procedure
Cold:
  1. Ignition on/off to on
  2. Set compression release – optional step even if saw is equipped with a compression release
  3. Pull (close - sets fast idle) pull starter and listen for an attempt to start. once heard (usually two pulls)
  4. Set compression release – optional step even if saw is equipped with a compression release
  5. Push (open) choke pull starter until it starts. (usually the next pull)
Warm:
  3. Pull (close - sets fast idle) choke, - Don’t pull with choke closed.
  4. Push (open - fast idle maintained) choke, pull starter until it starts. (usually first pull)
Hope this helps
Lou
Posted on Oct 03, 2009
nova2nv
  • 197 Answers
SOURCE: I have a husqvarna 55. I put in a new carb, coil,
If you are still having problems I would check or replace white grommet inserted into cylinder and connected to manifold,they have issues with breaking or blowing out.This model also has problems with the black intake boot not sealing around cylinder and manifold,an easy check by spraying a LITTLE carb cleaner around problem area.
Posted on Nov 18, 2009
  • 27 Answers
SOURCE: I have a Husqvarna 36 air injection gas chainsaw
it usually gives the ratio on the oil container
Posted on Jun 17, 2010
Truck starts but only chuggs and blows out black gas smoke as engine lite flashes no throttle response
black smoke is too much fuel
check for leaking injector and injector seals
check for excessive fuel pressure
run the fault codes as you will have some from the engine light on
Jul 02, 2015 | Cars & Trucks
Why does My Husqvarna YTH2148 lose power when I switch on the blade?
Most likely you have either a partially plugged main jet as engine normally run off the idle mixture when not loaded or you have a blown head gasket.
Oct 12, 2014 | Husqvarna Garden
I have a 2002 LW200 that for the past week and a half has been randomly going into misfire fits for about 30 seconds when under load. The 'Check Engine' light starts blinking and it blows one big puff of...
I would say you need to take your cat off and check to see if the monolith is blocked/broken up. The big puff and black smoke tell me you are getting a pressure build up, a blocked/broken up cat is the most likely cause of that.
Sep 13, 2013 | Cars & Trucks
Misfire and blowing black smoke
Hi Rick,
There is a number of problems,
1. You need to give the car a proper service. Change plugs, filters, brakes, all the oils.
2. clean the valve body with the flow sensors
The black smoke is most properly from the engine oil that is combusting. This will stop as soon as you have change the air filter.
3. make sure that the spark plug wires are in a good condition as well.
Aug 06, 2013 | 1999 Toyota Camry Solara
Husqvarna with Kawasaki 21hp engine misfiring when revved
We had big problems with the Kawasaki engine doing this, the early engine has an external vented carb, you can try extening the pipe from the carb and get it away from the draught from the flywheel, the later engine has an internally vented carb which cured this issue, the carb is retro fittable but expensive, it was offered as a re build kit when fitted to Husqvarna tractors, try taking it up with Kawasaki.
May 29, 2013 | Garden
Husqvarna yth1848xpt with a kawaskie 20 hp puffs black smoke
I had the same problem with my YTH1848XPT . Believe it or not it is simply a dirty air filter....you must remove the filter and blow it out with an air compressor...or better yet replace it. you can not clean it well enough without the force of the air compressor. Mine works great now.
Jun 08, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna Lawn Tractor Yth2148 Owners Manual Logo
173 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
