Question about Zebra 105SL Thermal Label Printer
Text is mis-ailigned on labels between two printers both of which are 105SL I'm using seagull drivers, text is fine on one printer and totally off on another
    Problem Solver:
  • 7 Answers
First Step: Do a configuration print on both units. If you encounter differences, correct it and/or do a hardware reset on both unit.
Second Step: Give it a try. If there are still differences ...
Third Step: Save the "print data" in a file -> you can do it in the drivers option. Then do again a hardware reset and take the file and send it to the printer (you have to get the same printout with this methode!). If yes you can search backwards ...
Posted on May 14, 2013
4 Suggested Answers
SOURCE: ZEBRA 105SL : PRINTING PROBLEM
Thanks your the solution. This helped me a lot.
Greetings
Thomas
Posted on May 05, 2008
SOURCE: Zebra 105 SE Printing Blank Labels
Seagull Scientific has drivers. Their Zebra driver is recommended by many.
http://www.seagullscientific.com/aspx/drvrmain.aspx
That's the link for their printer drivers page. Go to the bottom and click on 'Download a printer driver'. Then scroll the list to find the one you need.
Posted on Jun 10, 2008
jwr1914
  • 31 Answers
SOURCE: Zebra 105SL label issues
I am surprised that you are using that sequence of buttons to solve this problem. I am pretty sure that they want you to go into the "Media Sensor Calibration" setup in the config menu. It is a bit more complicated than what you have described. I also believe that the size of the gap on two of your labels might be out of tolerance (they are usually 1/8" gaps between the labels). The black marks are a problem for the transmissive sensors. You may need to move the transmissive media gap sensor (remember it has two parts: upper and lower). I would usually setup mine for a place beyond the black mark so that you are looking at just the white paper.
To start out:
1. Load the backing of a 6" strip of media (no label attached).
2. Remove a ribbon (if you usually use one).
3. Close the printhead.
4. Press SETUP/EXIT and then NEXT/SAVE until "Media and Ribbon Calibrate" appears.
5. Press "+" to start the calibration procedure. You should see the "Load Backing" in the LCD Display. You already have the backing loaded so continue to the next step.
6. Press "+" to answer the message and the next screen should say, "Remove Ribbon". You have also removed the ribbon.
7. Press the "+" to continue. You should see the screen say, "Calibrating Please Wait". After the sensors are setup by the machine a new screen should appear, "Reload All".
8. Open the printhead, and move the labels until they are loaded correctly to print. Smooth out the ribbon and load it correctly.
9. Withe media and ribbon now loaded, press "+" to continue and the machine should say, "Media and Ribbon Calibrate".
10. Press the Setup/Exit button once. It should say, "Save Changes Permanent". Press Next/Save to finish the process.
11. Do a normal calibration of your stock and print a label.
You are done. The machine will run for the labels you have setup the sensors for. Unfortunately, you must do this for each of the media types. To automate this, you could run a Configuration listing, capture the settings you just created for each type of label. Take these to a programmer to have them send the setup to the machine before the job. This is beyond the scope of this type support to really help you.
Posted on May 29, 2009
My Zebra 105Se printer keeps printing blank labels
There are several reasons why this could be happening. If the computer accessing the printer changed then I assume the new computer was recently set up with software to send print information to the printer. I would start with simple calibration and move from there. Zebra Technologies 105SL Printer Calibrating the Printer With Video
Jun 04, 2014 | Zebra 105Se Thermal Printer
How to print label on b-sx4 label printer
You must use the option send file to printer in the seagull driver not print else it is converted to graphics and sent to the printer.
May 16, 2012 | Toshiba TEC B-SX4 Thermal Label Printer
Hi there, I am printing on Zebra S600 using Seagull Scientific Driver, The printer only prints every alternate label that is prints one label and prints a blank. Thank you for your help
Skipping labels is usually a printer driver issue. You should use Seagull Scientific printer driver only if you are using the corresponding Seagull Scientific label design software. It is important to have the printer driver and label design software be from the same manufacturer.
Jul 01, 2011 | Zebra Stripe S600 Thermal Label Printer
Can we make 300 dpi Zebra 105 SL printer to print on label expecting 203 DPI, Any configuration setting?
Krishan, sorry there are no settings that will allow you to do this on the 105SL. If the printer code expecting a 203 DPI printhead and you have a 300 DPI Printer then your label will print out much smaller then normal.
If you are printing labels with a label printing package (such as Seagull Bartender for Windows) then all you need to do is to install the proper printer driver. If you have your printer attached to a system that is sending "straight" ZPL (Zebra Printing Language Code) then your out of luck.
Hope this helps
Mikeo@acebarcode.com
Feb 28, 2011 | Zebra 105SL Thermal Label Printer
Is it possible to import data from excel into the labelprinter Zebra S4M?
You can print a text from XL, but you owuld have to use a page set up that is the same as the label size, through a Zebra or Seagull driver.
Feb 10, 2011 | Zebra S4M Thermal Label Printer
I loaded the windows update driver and connected my PSC 2115 all in one printer. It prints text documents and the test page without any issues. It displays images in print prieview but won't print them.
You need to get the manual for this printer, it has a printing language all it's own. The encoded text tells it where to put the bar code on the label, how to encode it, what text to put under it, etc. It's looking for a specially designed print file that's plain text. There may be a way to turn that off and turn it into a bitmap printer, but you would need the manual for that.
Nov 23, 2010 | Zebra 105SL Thermal Label Printer
I am trying to print a label on the zebra 105SL but the font and the "text boxes" are printing too large like it is zoomed out - how do I resolve this issue?
I am trying to print a label on the zebra 105SL but the font ...
www.fixya.com/support/t5406223-am_trying_print_label_zebra_105sl
Jul 11, 2010 - I am trying to print a label on the zebra 105SL but the font and the "text boxes" are printing too large like it is zoomed out - how do I resolve this ...
db:: 4.67::Crystal Report Label Won't Send To Zebra k9
www.hivmr.com/db/k99xad9dfspspddfs1scm9fzxxkdz9dj
My routine can print the label to any other laser printer, but the Zebra. ... I am tryingto find a way to print actual time a smartform label gets printed out on a zebra ... In this i want to changeCross Tab expert Row Label Font,Cross Tab expert ..... And labelpaper too. ..... DB:2.73:Zebra 105sl And Crystal Report Label Issues 1d.
db:: 5.16::Help My printer is printing in 3x5 documents and I ...
www.hivmr.com/db/xkzpajp81937ap7zdf87sdmsxmcm179m
DB:4.06:Printing 3x5 Continuous Feed Labels On Hp Officejet 6100 d8 ... Are they toosmall? ... I want to help you but I am not sure I can be of much help until I know what kind ... If the paper size is 3.5x5 but you are trying to print a 3x5 photo (which seems to be ...... I have a label format issue on a Zebra 105SL label printer.
db:: 4.15::Custom label sizes md - Hivmr
Jul 11, 2010 | Office Equipment & Supplies
Zebra 105SL Prints fine through Zebra Setup Utility, but prints plain text when file copied to port. Win XP. The setup utility can never get Version Info from the printer, but Windows shows the printer...
possible fonts issue. try to change the font from the text, check setings from the driver.
try to print from the driver (test print)
Try to print from Word (need to ajust the page) with diferents text fonts.
you can check the correct firmware ( be ware with the information about the serial number) ATENTION!!! wrong firmware can cause PRINTER DEAD!!!
Install lates firmware to the printer.
Oct 12, 2009 | Zebra 105SL Thermal Label Printer
3 Model 2746's - 2 print custom label perfectly - the other does not.
could be the printer speed but, you may want to reinstall driver and reset configuration, sometimes it is just one thing unchecked that will make the diference.
May 20, 2009 | Zebra 105SL Thermal Label Printer
You need the correct driver for the 105Se. The 300 dpi SL driver is not compatible.
Unfortunately, Zebra does not make it's older drivers available online. You will need to locacte someone with the correct driver for whichever version of Windows you are using.
Steve
Feb 13, 2008 | Zebra 105Se Thermal Printer
Zebra 105SL Thermal Label Printer Logo
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
