Question about McCulloch Garden
Oil mix for ght 30 titan hedge trimmer - McCulloch Garden
    Top Expert:
  • McCulloch Master
  • 2,931 Answers
Use the links below to determine your oil mix ratio:
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
oil mix for ght 30 titan hedge trimmer - helpful-rwwceix4simen0bu2pand4lt-2-0.png
Posted on Feb 21, 2018
boscia
  • 163 Answers
SOURCE: Black and Decker 16 in Hedge Trimmer
I use a dremel with a sharpening stone, if u don't have one you can also use a power drill with a small sanding disk (1 inch) and course sand paper (30 or 40 grit). or you can use a bastard file. its too tight to use any kind of angle guide so just take your time and do it by eye. it shouldn't take much to get them sharp enough to do the job, over-sharpening is unnecessary and dangerous, and will make the blades dull faster. sharpen all the free blades, top and bottom, then start the trimmers to advance the blades to free up the sides you couldn't get. i use a light penetrating oil to clean the blades first, then lithium grease spray to lubricate.
Posted on Nov 28, 2008
trippssmengi
  • 76 Answers
SOURCE: oil ratio
you can use a 40:1 mix if it smokes then cut it back to 32:1 but a little more oil is better than not enough so start with the 40:1
Posted on Jan 18, 2009
SOURCE: Ryobi 18V Hedge Trimmer Blade Question
Just buy a file and push 3 or 4 down strokes down the same slope of the cutter toward the sharp edge. Never file on the flat top of the cutter, only on the slope. Support the frame using a saw horse or pick-up bed. The support makes the file cut the metal better. You can do the same thing with chain saws. You just need the file that fits the cutter. You just hold a consistant angle and count out the same number of strokes. Also, clean out junk between the moving parts, tighten any loose screws, and drop a few drops of 3 in 1 oil between the moving parts. Having things sharpened at a shop is inconvenient and expensive.
Posted on May 24, 2009
SOURCE: sharpen hedge trimmer blade??
My trick is to make sure that I always lube the blades after each session with a 3/4 engine oil + 1/4 kerosene mix - making sure that every tooth gets a drops or 2, then run it for a seconds to spread the oil & leave the blades overlapping. Doing this allows the blades to self sharpen I've found. 2 stroke oil , unmixed is about the perfect viscosity aswell.
Posted on Feb 18, 2010
  • 5 Answers
SOURCE: homelite hedge trimmer , motor runs but blades do
Had the same problem: when I turn on the trimmer, the motor would hum but the blades won't move.
What I did:
1. Sprayed a ton of wd40 between the blades
2. Took a screwdriver and kinda wedged it between the blades to get them unstuck. Also removed some guck between the blades.
And it worked!
Posted on Jun 09, 2010
Hedge trimmer
possible problem with dirt or blockage in the main jet of the carby
remove carby and blow out all holes and jets
fit new diaphragm
ensure that the oil / fuel mixture has not excessive oil in the mix
do not use e-mix fuel
Aug 10, 2016 | Tanaka Hedge Trimmer Tht-2100 Trimmers...
Gas mixture for Echo 1500 hedge trimmer
Kathy, Gas mixture 50:1, with mid or premium gas.
Check the attached links,manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.echo-usa.com/getattachment/f9348047-25e4-468f-b298-f5927ec23249 2 Cycle Oil Mix Chart
Small Engine Repair How to Calculate or Mix 2 Stroke Oil with Gasoline or...
Jun 23, 2016 | Echo Hedge Trimmer Throttle Cable...
Not getting spark because i loosened the adgustment screws
GAP ON THE COIL ? USE A MATCH BOOK COVER. SPARK PLUG FOLD THE MATCH BOOK
May 25, 2010 | Poulan WeedEater Hedge Trimmer 25cc Engine
Fuel mix for ALKO RT250 strimmer
Mix one ounce of 2 cycle oil per quart or 4 ounces of oil per gallon of unleaded gasoline. Hope this helps and best wishes.
Aug 28, 2009 | McCulloch Lawn Care: Trimmer Plus...
Poulan Weedeater GHT-22 Hedge Trimmer Leaks Fuel Near Handle
Either the fuel lines that were replaced are a poor fit in the tank ( wrong diameter pipe ) or the pipes have been connected incorrectly to the fuel primer bulb.
Dec 13, 2017 | Poulan Garden
GHT-22 Hedge Trimmer Fuel Line Replaced and Still Won't Crank
to solve your problem i am sure you can solve your problem just visit at the link given http://toolsnyou.com/
Aug 09, 2017 | Poulan Garden
Oil ratio
Jan 17, 2009 | Homelite Factory Reconditioned 26cc...
Garden Logo
54 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
