Question about Canon PC-940 Black and White Copier
Where are fuser are stand - Canon PC-940 Black and White Copier
  • Canon Master
  • 1,294 Answers
The fuser is located after the paper exit section(hot area).
Posted on May 01, 2013
Xante fuser reset fuse
That fuser is behind the cover of the fuser. Not easy to get to it, I do not recommend taking it apart unless you have a new one standing by, cause you are going to need it. Drum and transfer belt ok not so with the furser assy.
Jun 24, 2014 | Xante Office Equipment & Supplies
How do I replace a fuser for a Xante Accel-a-Writer 4G?
dear please find back cover and open it found big unit of printer called printer fuser assembly.removed it carefully you need one Philips screw driver,losses the two screw after that you removed screws slide it right side if you stand back of the printer,however after remove the fuser assembly you can installed it new in the Xante 4G printer when you install slide fuser to left side and alignment carefully,hope you understand.
thanks.
Jun 19, 2014 | Xante Accel-a-Writer 4G Laser Printer
50.9 FUSER ERROR
The fuser is the part that melts the toner onto the page, the error is thrown by a sensor which monitors the fuser, powering off unplugging and waiting for the fuser to cool (about 25 minutes, dont test it by touching it) before turning back on the printer will fully reset the sensor and may get you going again however this wont fix a fault with the fuser. However the fuser is a consumable which means they can be purchased and fitted by the end user (Not cheap parts), I always recommend that you users buy from the manufacture as they will stand over any item they sell you plus advise on instalation and problems however check prices on-line first and make your own call
http://printertechsdotcom.stores.yahoo.net/hpcola26fune.html
Oct 05, 2009 | HP Color LaserJet 2600n Printer
What does H 4 stand for
An H4-00 code is a low heat indication for the unit's fuser (the device that provides heat and pressure to the paper, to bond the toner). Most likely you have a paper jam in the fuser, blocking the sensor.
Sep 01, 2009 | Sharp AR-5320 Black and White Copier
Hp clj 4700n 59.30 error
The error stands for:
59.XY PRINTER ERROR
X is in your case 3 : FUSER MOTOR STARTUP ERROR.
Y is in your case 0 : NO COLOR
The service manual says:
1. Reconnect the connectors for the fuser motor and on the DC controller PCB. Replace any damged parts.
2. Replace the fuser drive assembly.
3. Replace the DC controller PCB. Calibrate the printer after replacing the DC controller.
Best regards,
mannu_rakesh
Aug 22, 2009 | HP LaserJet 4700 Printer
What does Service code SC548 on a Lanier LD435c stand for
AMCAP VIDEO CAPTURE WILL NOT FUNCTIONPROPERLY
Aug 16, 2009 | Lanier UNKNOWN
I have a small peice of paper stuck in the fuser unit of a samsung CLX 3160- How do I remove the fuser to get it out? I removed the 4 screws holding it in, but it is attached somewhere else, is there a...
open back cover,remove 4 screws of fuser,standing at the back of printer on your lhs on the fuser there is a lock,pull lock towards right and fuser should come out.
Jul 13, 2009 | Samsung CLX-3160 All-In-One Laser Printer
Ricoh Ap2600
Fuser overheat error, Replace the fuser. -Carl
Jun 22, 2009 | Ricoh Aficio AP2600 Laser Printer
Envelopes
Make sure the paper type for the tray from which you print envelope is set to Envelope. If the printer doesn't know that an envelope is being printed, it will not turn on the "Envelope Enhance" feature. The Envelope Enhance feature pumps air out of the envelope before it enters the fuser and can prevent creasing in the envelope. However, keep in mind that any envelopes larger than a US Size 10 will most likely crinkle, with or without the Envelope Enhance
Dec 19, 2008 | Lexmark T644 Laser Printer
Canon PC-940 Black and White Copier Logo
23 people viewed this question
old marine
old marine
