Question about Toro Garden
Crank pulley removal
On a toro LX420 is the crank shaft pulley bolt right hand thread
SOURCE: need to replace pulley for serpentine belt on a 2000 Eclipse
left need to use a air tool most likely
Posted on Dec 06, 2008
  • 22 Answers
SOURCE: I am trying to get the 11 hp Briggs & Stratton
On the end of the shaft that comes from the motor there should be a bolt that holds the pulley in place. You will need to remove the bolt in order to get the pulley off. If you can lift the front end onto a couple of blocks it will make the job easier to do. You may have to place a screw drive in between the belt and the pulley. A wood wedge the width of the belt would be better as it would be less likely to damage the pulley. Depending on how old the tractor is, you may have to spray the bolt with a penetrating oil first to help loosen the bolt.
Hatter1
Posted on Mar 14, 2009
  • 6 Answers
SOURCE: drive pulley won't come off engine shaft
put the nut back on were it is even with the stud and hit with a hammer while pulling on the pulley
Posted on May 27, 2009
  • 167 Answers
SOURCE: crank shaft pulley
Should be a right hand thread . Only left hand threads I have come across are Honda's and some Mitsubishi's.
It will be very tight!
Hope this helps
Posted on Aug 01, 2009
moretons
  • 155 Answers
SOURCE: Is the bolt that holds the electric clutch on a
These are a normal rh thread
Posted on Sep 12, 2009
Crankcase bolt
which one, there are many bolts,
do you mean the end of the crank shaft, front , damper pulley bolt
are you test spinning engine? or taking the bolt off or on.>?
the treads on all bolts this engine are RHT, right hand thread
bar stool: righty tighty; lefty loosy
no engine, size stated, but this works.
crank case? pan, bell, crank, head bolts. fly wheel? lots.
Jan 06, 2014 | 2006 Suzuki Grand Vitara
Is the crank shaft pulley on a renault 1.5 megane left/ or right hand thread
They'd be right hand threads-regular threads-to loosen, turn counter clockwise. An air impact wrench is best for removing the crank bolt. Or a long breaker bar and socket on the bolt, if you can hold the crankshaft stable so it doesn't turn backward with pressure on the bolt. You can pull the starter off, and wedge a big screwdriver or prybar against the flywheel's ring gear teeth, then turn the bolt with the breaker bar.
Jul 13, 2012 | Renault Megane Cars & Trucks
Can't get the crank pulley loose. is it left our right threads. i am replacing the water pump.
TURN CRANKSHAFT BOLT COUNTERCLOCKWISE TO LOOSEN. YOU HAVE RIGHT HAND THREADS.ENGINE TURNING CLOCKWISE.YOU NEED A STRAP WRENCH HOLD CRANKSHAFT PULLEY WHILE LOOSEN IT.BUT YOU NEED A CRANKSHAFT DAMPER REMOVAL TOOL.OR HARMONIC BALANCER REMOVAL TOOL.YOU NEED STRAP WRENCH TO HOLD CRANKSHAFT PULLEY WHEN TIGHTEN IT.TORQUE CRANKSHAFT PULLEY BOLT 90 - 98 FT LBS. MAKE JOB EASIER.HAVE A HELPER HOLD STRAP WRENCH WHEN YOU LOOSEN OR TIGHTEN CRANKSHAFT PULLEY.
Sep 19, 2010 | 1995 Mercury Villager
I have a Toro LX466 riding mower. The drive belt
How to replace the drive belt on a Toro LX466 Lawn Tractor
1. Jack up the front of the mower-place a couple of blocks under the front wheels (retaining wall blocks from your flower bed work great). Block the back wheels so the mower won't roll off the front blocks.
  1. Remove the battery and battery compartment from under the seat. You can now see the cooling fan blade under the seat. The belt runs from the pulley directly under the fan to the front of the tractor.
  2. Lower the mower deck to its lowest position. Remove the deck hanger rod from the slots in the front of the mower deck.
  3. Remove the metal rod guard below the engine pulley. It's held in place on one side with a bolt, and the other side with a cotter pin.
  4. Take a large pair of channel lock pliers (about 18 in long work great) and clamp them down directly on the engine pulley, but not so tightly you distort the pulley.
  5. Remove the bolt from the pulley. It's a right-handed bolt, so turn it counter-clockwise to remove.
  6. Slide the pulley down the shaft until you can work the belt off. If the belt is too tight, then remove the spring from the idler pulley under the tractor. It's hooked on a bolt near the side of the tractor. You can remove it by grabbing the end of the spring with a pair of needle-nose vise-grips and slipping the end off the bolt. Then remove the old belt from the tractor.
  7. Take a new belt (preferably Kevlar) and start at the back of the tractor (with the pulley under the cooling fan) and thread it through to the front of the tractor. The flat side of the belt rests against the idler pulley with the flat sides.
  8. Work the belt over the engine pulley and slide it back on the shaft. Tighten the bolt on the engine pulley hand tight. Then check the belt to make sure it hasn't slipped out of the groove on the cooling fan pulley.
  9. Clamp the engine pulley with the channel lock pliers and tighten the bolt.
  10. Make sure the belt is routed correctly on the idler pulleys. If you had to remove the spring on the idler pulley, replace it. You can do this by grabbing it with the needle-nose vise-grips and placing it on the bolt-make sure it's above the washer. Then remove the vise-grips and gently pry it over with a small screwdriver until it slips into place.
  11. Replace the metal guard below the engine pulley. Hook the mower deck back onto the deck hanger. Replace the battery compartment and battery. Unblock the mower.
Jun 15, 2010 | Toro LX466 22HP Lawn Tractor 13RT61RH244
Removeing the bolt from the crank pully
right put the starter motor back in,then re connect .put the right size socket on the pulley bolt and use a long snap on bar jammed into the suspension then crank the engine with the starter motor and it will undo itself ,dont forget to put some contact sdhesive back on the pulley bolt thread when rebuilding
Apr 12, 2010 | 1997 Volkswagen Jetta
Daewoo Matiz crankshaft pulley
remove the outer small bolts to remove balancer(pulley) the big centre bolt holds crankshaft gear for timming belt which slides off with timming belt removed.
Sep 10, 2009 | Daewoo Nubira Cars & Trucks
Crank shaft pulley
Hope this helps
Aug 01, 2009 | 1995 Isuzu Rodeo
Garden Logo
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
