Question about Go Software Inc. PCCharge Pro (100PROL0000SER)
PC Charge pass word reset
Our PC charge 5.9.3 has shutdown because of password failure on both the MANAGER and SYSTEM. How can we reset it??
Kindle will not shut off-goes to shut off or cancel but wont move. doesnt charge well-doesnt always hold charge
Patricia, Using the power switch, you can forcibly reset your Kindle device. This reset will shut down the Kindle without accessing the shutdown command from within the Kindle's operating system, a particularly useful tool when dealing with a frozen Kindle. To initiate a hard shutdown, Kindle disconnect from its charger, slide and hold the power switch for about 20 seconds. This will force the Kindle to shut down, now it can be restarted normally.
Check links below for charging problems.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Reset Kindle Fire When it Won Turn on or Charge
Troubleshooting Kindle Fire That Won Charge
Kindle Fire not charging
9 common problems with the Kindle Fire HD and how to fix them
Feb 25, 2016 | Amazon Kindle Fire HD
Cant log in forgot pass word need new pass word
You need someone else with a computer. Download NT Password deleter here:
http://pogostick.net/~pnh/ntpasswd/
Press F12 on startup to get the boot options, select yr DVD/CD drive and this will reset your password.
Alternatively find a local PC repair guy. If they're any good they can do it in 5 minutes for a nominal charge. If they try to charge lots of money walk away. It's an easy fix if you know what you're doing.
Sep 09, 2013 | Computers & Internet
How to reset bios lenovo z360
There usually a button cell battery on the motherboard. Remove this and wait for system to discharge there usually somewhere you can short out to remove residual charge but without details I recommend just giving 5-10 mins. Replace battery BIOS should be reset.
Jan 10, 2013 | Lenovo IdeaPad Z360 Laptop Computer...
Is there a software that is associated with my sonny battery that will make it charge again
If you plug in your AC adapter to your laptop to charge the battery and get the "plugged in, not charging" message then try the following solution:
  • Disconnect AC adapter
  • Shutdown laptop
  • Remove laptop battery
  • Connect AC adapter
  • Power on laptop
  • Click the Startup Menu
  • Type Device and select Device Manager
  • Under the Batteries category, right-click Microsoft ACPI Compliant Control Method Battery and select Uninstall.
  • Shutdown laptop
  • Insert laptop battery
  • Power on laptop
    If you follow these steps and find that your laptop still does not charge then consider replacing the laptop battery itself.
    Hope to have been of assistance,
    Thanks.
  • Sep 14, 2011 | Sony VAIO PCG-K23 Notebook
    I have a acer 5741. I have tried many times to charge it but it wont charge no matter how long i leave it plugged in. It is stuck on 10%. When I plug it in it says its charging but nothing actually...
    1. Unplug AC adapter. Shutdown
    2. Remove battery, Connect AC Adapter
    3. Start windows7. Remove Microsoft ACPI-Compliant Control Method Battery under device manager , battery
    4. Shutdown, Remove AC Adapter, Install battery, Reattach AC Adapter.
    5. Power up -
    Now Plugged in and Charging.
    Aug 04, 2011 | Acer Aspire 5520-5908 Notebook
    Shutdown suddenly and it cant turn on
    This problem can be with the battery charging in your laptop.
    Try charging the battery whether it is charging or not. Try to charge it for 3 hours & then try to start the system.
    Jan 24, 2011 | Computers & Internet
    Hi BIOS password fogoten
    you will have to contact Toshiba. desktop units are fairly easy to reset bios passwords. laptops are very difficult if not impossible to do this with. if you are the original owner of the laptop they will assist you with walking through the reset process. if this is out of warranty they will charge you. good luck !
    ruben
    Jul 13, 2009 | Toshiba Satellite Pro L300 Notebook
    Dont know password to my 119900 bushnell camera
    Hello, Brian Artz here,
    I have received hundreds of e-mails on this password problem. to many to reply to so i will post how to gear up all of us
    trophy takers..
    1. TURN ON UNIT AND WAIT FOR THE SCREEN TO SAY PASSWORD
    2. PRESS AND HOLD THE ENTER BUTTON UNTIL THE CAMERA SWITCHES INTO THE 5 DIGIT PASSWORD MODE,
    ##NOTE## SENTRY CAMERAS WILL NOT INDICATE A 5TH DIGIT MODE ON THE SCREEN BUT WILL SHOW
    "_ _ _ _"
    3. NOW PRESS ENTER TO CONFIRM 5 DIGIT MODE
    3A. THE CODE IS "66214" FOLLOW THE PASSWORD ENTRY PROCEDURE AND PRESS ENTER AFTER THE LAST DIGIT "4"
    4. CAMERA SHOULD NOW SAY PASS AND YOU CAN NOW CONTINUE TO PROGRAM A NEW PASSWORD YOU WONT FORGET THIS TIME
    Oct 25, 2008 | Bushnell Trail Sentry 11-9200 Digital...
    Purchased new battery, now NOTEBOOK won't work on battery after full charge
    Better you first charge the battery for 16 to 17 hours and recheck the same. If problem persists, change the battery from where you bought it. that battery is faulty. And yes there is no need to install the battery from device manager. Just open the battery compartment and replace the battery with new one.
    Feb 13, 2008 | Toshiba Satellite A45-S250 Notebook
    "Battery Is Too Low System Shutdown"
    The battery has come loose from the contacts on the inside.
    Remove the back (4 screws), remove the battery and put it back in securely.
    Then charge it for a couple hours.
    Best of Luck.
    Nov 14, 2007 | SanDisk Sansa e260 MP3 Player
    Go Software Inc. PCCharge Pro (100PROL0000SER) Logo
    24 people viewed this question
    Top Go Software Inc. Computers & Internet Experts
    Cosma Papouis
    Cosma Papouis
    Avishek Samaddar
    Avishek Samaddar
    Are you a Go Software Inc. Computer and Internet Expert? Answer questions, earn points and help others
