Question about Plumbing
What size "O" rings (need two)
Takes 2 "O" what size?
  • 15,995 Answers
What is the model of the faucet?
Posted on May 19, 2013
Need return address lable for ring
Take it back and exchange it for the correct size.
May 09, 2014 | Cameras
Tip
How To Potty Train Your Dog To Use A Dog Bell
If your puppy doesn't have a way to easily get out of the house, you will need to train her to ask to be let out to go to the toilet. It's best to do this when your puppy is young and easy to train. Once dogs get into bad habits they can be hard to change and you might find yourself cleaning up 'accidents' all over the house.<br><br> <span>1.<span> </span></span>The best idea is to buy a dog bell/ poochie bell. You can attach this to string which you should hang from your back door so that it hangs at your dog's nose level.<br><br> <span>2.<span> </span></span>Every time you go to your back door, you should shake the bell and say out loud 'go potty time' and then take your puppy outside to the toilet.<br><br> <span>3.<span> </span></span>If you keep doing this, your puppy should start to make the association between the bells and going to the toilet.<br><br> <span>4.<span> </span></span>After a week or so of doing the above steps, you can say 'go potty' but don't ring the bell. Hopefully your dog will touch the bell herself. If she does, give huge amounts of praise and hugs.<br><br> <span>5.<span> </span></span>If she doesn't touch the bell, then gently shake it yourself and repeat the phrase 'go potty time'.<br><br> <span>6.<span> </span></span>It might take a while - don't give up! Just keep repeating the steps until your dog figures out that if she wants to be let out she needs to ring the bell.<br><br> Good Luck and stay positive. Hopefully within a few days you will have a nice clean house and a well-trained puppy.
on Aug 26, 2012 | Pets - Others
How do I determine if I need the 7.5 or 8.8 size rear wheel bearings for my 1988 Ranger custom 2.9L Ford 2 WD?
The rear cover gasket is different for the two differentials.
Both are 10 bolt but a slightly different shape.
You should be able to look at the two gaskets and tell which one fits your cover and then know which size ring gear you have.
You can look in the parts store or online.
Feb 12, 2013 | 1988 Ford Ranger
My power steering pump is leaking, need to know what size o-rings go on it?
Normally buy a box of orings all sizes sure too get suitable o rings in it
Nov 01, 2017 | 2000 Dodge Durango
Hi , i have a delta pull down spout that leaks half of the water that should go out from the head shower. I dissembled the spout and noticed what i think is the "O" ring has an hole and part of...
You can take the part to your local Ace or True Value hardware store or Home depot or Lowe's and find something close that will work. Bring the whole part with you. Buy a few sizes that or close just in case, they are very inexpensive.
Thanks for using FixYa
Jun 22, 2011 | Delta Faucet Delta RP17453 Pull-Down...
Coleman Powermate pressure washer. Model PW0751310 A lot of water leaks out in the handle where you squeeze for the unit to work, thus the power spray is weak at best. Took handle/arm apart and didn't...
There may be orings in gun but usually not available as a repair kit. Replace the gun with a 5000 to 6000 psi. You will get a much longer life by over sizing gun. If you like to tinker, you can by orings at Lowes in the plumbing department. Lube the orings with silicone paste (also sold at lowes). Good luck
Mar 17, 2011 | Caterpillar Cat Pump Pressure Washer Pump...
How much to repair 1994 oldsmobile oil pump drive shaft o-ring
Need to know engine size. Also need to know if this "o-ring" is causing an external oil leak.
If this is a 3.1 or 3.4 engine the o-ring is a common problem. The cost should be 1-2 hours shop time. The o-ring should be minor.
Apr 26, 2009 | 1994 Oldsmobile Cutlass Supreme
Piston rings
First, be sure they actually do fit the bore. Take a ring and insert it in the bore. push the ring halfway into the bore using the piston. There should be about a 1/32" gap in the ring. Anything more than 1/16" and you need rings the next size up. If the ring won't go into the cylinder because the gap fully closes, the rings need to be a smaller size.
With the correct size rings, put them on the piston. Some pistons have an index pin in the ring groove Fit the gap to the pin. Put the piston mid-stroke and place the cylinder over the top of the piston. Squeeze the rings closed as you gently tap the cylinder downward and over the rings.
Please rate this solution. Thanks garethholleb!
Apr 04, 2009 | Gilera Runner VX 125 Motorcycles
Toll saver does not work. Ring count set to 4 rings
"2 rings" or "4 rings" (the default) are not "toll saver". You need to set the ring count to “toll saver”.
On the handset
1) Press Menu
2) Scroll down to Answering Device then press menu
3) Scroll down to Settings press menu
4) Scroll down to Ring Count press menu
5) Scroll up to “toll saver” and then press menu
Feb 05, 2009 | Panasonic (KX-TG1032S) Phone
Plumbing Logo
19 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
