My Mitsubishi 1080 model 65733 comes on and cuts off after about 20seconds check code with menu and input buttons I got a 34 code help
    Top Expert:
  • Televison & ... Master
  • 75,581 Answers
There should be some fault with its main digital board. Troubleshooting to this board is a skilled work. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electric shock. Instead, contact any experienced service technician, or the nearest service center.If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2400 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name to your device into its search box at the top right of display window.http://electronicshelponline.blogspot.com/
Posted on May 02, 2013
5 Suggested Answers
  • 5 Answers
SOURCE: HDTV CABLE NOT HOOKED UP/WORKING
COMP 1 and 2 are for 480i/p sources. Hook it to the 1080i capable on the back. Also make sure the HD DVR is outputting 1080i not 720p. The Mits can not disply 720p and will show a scrambled screen if you try to.
Posted on Feb 20, 2009
  • 8457 Answers
SOURCE: I have an Mitsubishi HD 1080 big screen tv. When
Ur power ic inverter board is dead.
U need a new one.
Posted on Aug 26, 2009
SOURCE: i have a mitsubishi 1080 series wt-42311 model
i have a mitsubishi 1080 series WS-65315 model i power it on and led light turns off after 2 seconds
Posted on Oct 18, 2009
jdvillanueva
  • 2098 Answers
SOURCE: I have a 2005 Mitsubishi WD62327 62" rear
Yes, this kind of symptoms is not costly to repair. I can assist you which part gone bad on this error code. Click here.
Jdvillanueva
Posted on Oct 03, 2011
Mitsubishi 65733
CONTACT MITSUBISHI TECH SUPPORT, THEY SHOULD BE ABLE TO GIVE YOU AN IDEA OF WHERE THE PROBLEM IS WHEN YOU TELL THEM THE ERROR CODE, THEN LOCATE A HONEST TV TECH FOR A ESTIMATE.
Feb 02, 2014 | Mitsubishi Televison & Video
65" 1080 mitsubishi tv model# WD-65733 wont turn on
It is probably the wiring. Try buying a new power cord.
If not than it is just malfunctioned.
Contact Mistubish
http://www.mitsubishi-tv.com/contact
Nov 25, 2012 | Mitsubishi WD-65733 65" HDTV
My mitsubishi medallion hd 1080 doesn't show content from component cable
Some of the older Mitsubishi with HD 1080 have only one component input for HD---it is marked on rear as DTV----also a model number may allow me to give another suggestion--Some of these sets (ws, wt, vs models) will on occasion lock out or disable the input/s.
Depending on model number most also have 3 hidden menus---one is the option menu----it allows with the Mitsubishi remote via a 4 digit number (by model number) to enter there and do a hard reset of the set----sets every setting back to factory original---seen it "cure" all kinds of odd problems from missing rear inputs, no sound, odd video issues---you name it.
Get me the model number and I will see if can find the code for yours--you can also try hooking first direct a 1080 blue ray or Dvd if you want to see if the input is active or not first.
Apr 14, 2012 | Televison & Video
Screen doesn't appear to be HD even though it is an HD TV. Directtv suggests I check tv set up with you. how do i know if HD feature is working correctly. can u help me with the set up if not?
WD 65733 IS an HD TV.
The signal coming into is the key.
You must use HDMI or Component Input to translate HD to a TV.
Check the output resolution of you DirecTV box in its setup menu.
Apr 13, 2011 | Mitsubishi WD-65733 65" HDTV
I have a Mitsubishi hd 1080 tv and last night it stop working it wont turn on or off please help
IF POWER LIGHT COMES ON AND THEN GOES OFF:
DO THE SELF CHECK THIS SET HAS: ON THE FRONT OF THE SET PRESS AND HOLD BOTH INPUT AND MENU BUTTONS FOR AT LEAST 5 SECONDS AND RELEASE BOTH.
POWER LIGHT WILL BLINK A TWO DIGIT ERROR CODE LIKE: 2 blinks, 2 blinks, a pause and then it will repeat the code 4 more times.
Let me know if you get a blink code and I will tell you what it means.
If this information was helpful, rate this solution as very helpful as I do this here for free.
SD TECH
Aug 17, 2010 | Mitsubishi WS-55807 TV
Power will not stay on
Based on the model number WS65511, this set has a self check.
Turn on and when green power light goes out:
On the front of the set press and hold BOTH the MENU and INPUT buttons for at least 5 seconds and then release both buttons.
Power light will blink a two digit "error" code.
The most common is 2 blinks, a pause and 2 blinks. Set will repeat the error code at least 5 times.
Let me know what error code you find and I will tell you what it means, I hope you find it is 2,2 as that is the most easy to fix.
SD TECH Steve
Jul 14, 2010 | Mitsubishi WS-65511 65" Rear Projection...
Mitsubishi Model # WS 65311 HD 1080 turns on then shuts off.
try holding in the menu and input/device buttons on the front of the set both together and see if it blinks a series of blinks, pause briefly then blinks a second series of blinks, let me know what the blinks were sush as 22 or 24
Mar 12, 2009 | Mitsubishi WS-65311 65" Rear Projection...
Turn on the TV and only Timer light is on , no sound & picture
after holding down the menu and device the led will blink a two digit error code such as 3 blinks pause then 4 blinks then repeat that sequence a couple of times. Need that blink code to help let you know whats going on. The 34 code means lamp abnormality which translates to the power Pwb capacitors have most likely failed.
Jan 23, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Yellow status light on mitsubishi wd-65733 tv
When tv goes out, press the menu and input buttons. The green light will flash with a 2 digit code.
Jul 26, 2008 | Mitsubishi WD-65733 65" HDTV
Televison & Video Logo
Top Televison & Video Experts
