Question about Kitchen Ranges
Element goes to full heat when knob is only turned to 1/4 or 1/2 temp. It will periodically turn on/off rather than applying a constant temperature.
    Prodigy:
    An expert who has answered 500 questions.
  • 650 Answers
Sounds like you will need a new switch. You will need your model number to get the correct switch. If it differs from the original it can be tricky to wire it correctly without a knowledge of how the wiring should be for the terminals. You may want to consult a service company to replace the switch.
Posted on May 02, 2013
fridgetech
  • 473 Answers
SOURCE: Oven not heating to correct temperature
First thing that should be checked is proper voltage.  Low voltage can cause this problem.  Have that checked by a professional first then let me know what you find.
Posted on Oct 18, 2007
watugot
  • 290 Answers
SOURCE: Element Problem
I believe the range you have has a relay board mounted on the rear of the unit. The element switches tell the relay board when to turn the element on and off. You probably have a stuck relay on this board.
This type of set-up is fairly new and not a whole lot of people have worked on them. They will throw a good repairman for a loop the first time he tries to diagnose one.
(I speak from experience)
Posted on Oct 27, 2007
jsrock516
  • 5911 Answers
SOURCE: bottom element will not turn off
Your BAKE element relay on the Electronic Oven Control (EOC) Board is shorted.  I have experienced this problem before.  The board is not serviceable and (unfornately) you will have to replace it.  The board can run anywhere from $100 to $200 for a new one.  Slightly less for a refurbished one.  Prices will also vary depending on source.  This is a repair you can do yourself if you choose to do so.  If you can provide me with your model number (located inside the lower door panel), I can do some research to get a part number and price for you.  Let me know.  I hope this is helpful.
Posted on Oct 31, 2007
aborcass
  • 2651 Answers
SOURCE: Magic Chef 61EA-3KX oven knob hard to turn
nothing magical here, sounds like the thermostats on its way out, not servicable part needs replacing.
Posted on Feb 26, 2008
  • 26 Answers
SOURCE: Electric Oven not getting hot enough
Sir, I think the top oelement is for broiling ONLY. It should not turn on when baking. The clicking may be the oven heating up.
How far apart were the oven temp instrument and the digital?
Don't expect them to match...they are inaccurate.
1. Heat water until it boils. Place digital therm in boiling water until it comes up to 212deg. If it is not at 212 in boiling water, record the error.(this gives a rough calibration to the digital)
2 Turn on oven, set to 350 deg, place digital therm on rack. Wait until oven reaches 350 (on stove) and read the digital. Note the difference between the two
Posted on Mar 30, 2008
How do I properly operate the Turbo Boil on my new Kenmore range?
Turboboil is a feature offered on a number of Kenmore electric ranges and cooktops. Without you model number it's hard to get into specifics - but turboboil is a special, high wattage heating element that delivers up to 3KW of energy to a specific heater on the cooktop. If I understand correctly, you would only use this setting when you wish to bring water to a boil in the shortest period of time possible - then change to a normal burner heat setting to maintain the temperature of the water in the pot.
Remember, an electric heat element is turned "full on" and "full off" as needed to maintain temperature (unlike a dimmer knob controls a light bulb). The turbo boil turns on a "double heater" to rapidly heat the water - after water reaches 212 degrees, it can not be heated any further (it turns into steam) so you should switch to a normal burner mode from that point forward.
Kenmore com
Apr 07, 2015 | Kenmore Kitchen Ranges
Heating element will not heat , the element is ok
GOD IS STILL GOOD !!!!
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Sep 09, 2014 | Hotpoint Belt for CTD00P, CTD40, CTD80,...
Why would Amana Dryer not heat hot enough after replacing heating element?
overheating.
OR you may have a broken centrifugal switch in the motor because this switch activates the motor and the heater as well. supposed to be if the motor does not run , the heater should not heat in order not to create fire but you said that even the motor is not running, the heater is still heating, then there could be a problem with the motor centrifugal switch that is connected to this interlock switch that should trigger the heater.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
Aug 23, 2014 | Amana NED7200TW Electric Dryer
It seems that the temp more often goes up to 20-30's and that food is not as frozen when I check it. When temp goes up I check it for next couple of minutes and usually within 10 min the temp is back down...
This is normal. All commercfial freezers must defrost 3 to 5 times a day, or they will freeze over at the coil and then stop freezing. A timer in your freezer turns off the compressor and turns a heating element on for 10 to 15 minutes. During that time the coil heats and melts frost from the coil. Usually within 30 minutes the temperature will briefly rise to 20 t0 25 degrees F and then quickly drop down to 0 degrees F. The food rarely defrosts in this short period of time..
Sep 01, 2010 | Turbo Air 23 cu. ft. / 651 liter...
2005 RX8 heater is blowing cold air. Fluids are topped up.
You need to repair the heater core with a soldering gun.
If you do not have heat, or only have heat, IMHO it is most likey the AC/heater control unit. This is the part which has the AC/heat control buttons and knobs.
Easy Diagnosis:
The easiest way to verify this is to turn on the radio, press and hold the power on/off button and press and hold the scan-up button for a second (full second). The word "A/C TEMP" should appear on the left of the display and a number from 0 to 16 on the right. I suspect yours will have the number 0 (or 16 if heating only problem) displayed no matter where you turn the temperature control knob. If this is the case you could turn the temp. knob to full heat and see if it goes to 16 after pushing down or to the right on the knob.
In a working system, the number moves evenly in increments of 1, from 0 to 16 as you turn the temperature knob.
Easy Fix:
I was able to take mine out and solder 3 loose connections to fix it.
The beginning steps are the same as for any radio removal procedure and check for loose connections.
Dec 14, 2009 | 2005 Mazda RX-8
2005 highlander heater problem
I'm glad I could help. I'm reposting the solution below in case anyone needs it in the future. Please be sure to rate it for me!
Pull the temperature knob off and verify the thin 12mm nut is installed and tight behind it. I have seen several of these loosen up allowing the knob to turn but intermittently have no effect on temperature.
Sep 11, 2009 | 2005 Toyota Highlander
Weller WMRP soldering iron faling prematurely.
I suggest that you set the "Auto Time Off" much longer or turn it off by setting it to 0, and use a standby of 400 degrees after 10 minutes instead.
The reason is that every time this soldering iron has to turn on, it's trying to heat up in about 5-10 seconds. When it does that, it applies full wattage to the heating element, and putting full wattage on them a lot of times is what's burning them out. If the soldering iron maintains the same temperature while not soldering, it only uses 20-30% of the full wattage to keep it at the set temp. This isn't nearly as hard on the heating element.
Aug 04, 2009 | Welding Tools
Temperature never reaches 375
Pull the temp knob off and you should see a small screw in the middle of the stem. This is your calibration screw. Turn it about 1/4 turn to increase the temp. If you don't have one, then you may have an element that is out. Can you take the bottom off to see it. Also, there may be a wire that is not making good connection.
Jan 10, 2009 | Rival CZF530 Deep Fryer
INSTRUCTION BOOKLET
Chances are that both elements should energize when starting up in bake mode. Since bake is by the very nature of the principle "constant heat" then the job of the control on the unit is to maintain an stable temperature for a specific period of time. Sooo... when starting up, both elements would be available to quickly raise the temperature. Once that temperature is reached then the bottom element would be all that is required to maintain the set temperature. Watch the elements for a period of time, until the "bake" temp is met and see if the bottom element is the only one energizing for the remainder of the time alloted.
Mar 27, 2008 | Kitchen Appliances - Others
Cooler wont cool below 48 degrees.
Keep a thermometer handy. (adjust temperature control knob accordingly)
Periodically monitor temperatures inside your cooler. (adjust as necessary)
Keep the refrigerator door closed as much as possible to avoid temperature fluctuations
The temperature of the refrigerator compartment is
controlled by adjusting/setting the thermostat control
knob, located on the ceiling of the refrigerator
cabinet.
To start the refrigerator, and achieve maximum
cooling quickly;
• Turn the temperature control knob (using a coin
or screwdriver) clockwise to the furthest
(maximum) setting on the darker blue section of
the graduated control dial.
• Allow the refrigerator to run at this setting for 3~4
hours.
• When maximum cooling is achieved, turn back
the temperature control knob setting to the 2:00
o'clock position on the graduated blue control
dial.
• Correct cooling temperature is a key factor to
consider in storing and dispensing draught beer.
• Optimum temperature for serving draught beer is
between 34ºF ~ 38ºF.(1ºC ~ 3ºC)
• To maintain temperatures ranging between
34ºF ~ 38ºF.(1ºC ~ 3ºC) We recommend the
thermostat knob be positioned at the "2:00
o'clock" setting on the graduated blue control dial.
• To turn off the refrigerator, (no cooling) rotate the
control knob to the "0" position.
Jan 31, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
Kitchen Ranges Logo
44 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
