Question about Laser 3115cn All-In-One Printer
Dell printer problem
My Dell 3115cn has just started printing smudgy black marks in rows right across the paper in a regular pattern. The rows are about 3cms apart. I've just changed the fuser and belt unit and it seems slightly better but they're still there. Any answers?
SOURCE: No option to duplex print Dell 3115cn
The duplexer is seperate purchase to my knowledge. If you have purchased the duplexer, you must enable it in the options tab.
Posted on Feb 11, 2010
  • 217 Answers
SOURCE: Dell 3115cn replacement toner
YES.
There are good quality remanufactured cartridges for this prnter. I did the development work on these carridges (and the other printer name versions) for one UK remanufacturer, and do the Qualty control on them. Use a brand with a good reputation, and of course there should be a guarrantee.
There are also some poor ones around (as always some remanufacturers take shortcuts and don't do the job properly).
Unfortunately this is not the place to mention specific remanufacuterers that you can buy a good product from, and it does depend on you location.
Posted on Mar 30, 2010
SOURCE: 3115cn Dell laser Printer
I've had this happen a few times. Each time all it has taken is to clean the ADF scanner glass, located on the far left side, using a lint-free cloth and a glass cleaner. I know it might seem odd because it works fine with black and white copies, however this has always done the trick. I'm surprised this is not listed on Dell's support pages. Hope this helps.
Posted on May 25, 2010
  • 5416 Answers
SOURCE: dell 3115 scan without cartrige
Get a stand-alone scanner or the ink and fuser. The multi-function printer will report a fault to protect itself until the ink system is set up to be able to print.
Since this is a Laser printer, if you do spend the money on the toner cartridges and fuser, it will be a one-time purchase if you do not use it for printing.
I wish that I had better news for you.
Posted on Apr 30, 2012
  • 55 Answers
SOURCE: put ip adress dell 3115cn printer
Here is a link to download a copy of your manual from dellhttp://support.dell.com/support/edocs/systems/prn3115c/en/index.htm
Posted on Jul 05, 2012
My Dell 3115cn MFP prints 3 blank pages between prints or copies if I print more than 1 copy how do I fix this? What is causing it?
I will do first a full printer cleaning, that mean take off all dust and anything can that can be inside the printer (ex.bugs and dirt accumulation).
Second try to locate the printer rollers and check if they are in good condition.Printer rollers need to be in good condition because those are the parts that move the paper inside the printer.
Also when you feed the papers into the feeder make sure you air the paper so they don,t stick together.
May 07, 2013 | Dell Printers:Dell MFP Color Laser 3115cn
When pages are printed they have horizontal black lines across them
you need to clean either your drum or you corona's thes are the little wirespciking up access toner
please clean your drum with a dry tissue
also clean the corona's with a dry tissue
that should get rid of the issue
if not your drum need replacement
cheers
rene
May 28, 2011 | Dell Printers:Dell MFP Color Laser 3115cn
I have a dell mfp 3115cn copier, fax, scanner. Th...
the fault is a mark on the glass over which the paper passes when being copied. it is the rectangular glass that is probably only 1cm wide but the full A4 length across the screen. Clean the mark off this thoroughly and voila, fixed.
Bristolprinters Ltd - with compliments!
May 21, 2010 | Office Equipment & Supplies
White stripe on right as if black toner needs
You probably got a piece of paper or something in the image path or the paper path. If it is a nice clean line it is more likely to be in the image path, if it is smudgy line it something may be scraping the toner off the paper before it gets to the fuser. Check the paper path.
Dec 26, 2009 | Dell 3010cn Laser Printer
Black ink marks on prints from Epson R380!
Hello:
I have been having this problem all day today and believe I resolved it. The photo paper is thicker (I'm using the Ultra Premium Photo Paper by Epson). I have an Epson 1280 photo printer. I opened the lid and moved the lever to adjust for paper thickness, and voila––no more black ink tracks down the one side. Since photo paper is thicker, this may be your problem as well. Check your manual and see if there's an adjustment for things such as printing envelopes and change the setting. Hope this works for you! I wasted about 6 sheets of paper until I thought to adjust for paper thickness. Please let me know!
Susan
York, PA
smfree@comcast.net
Mar 26, 2009 | Epson Stylus R380 InkJet Photo Printer
Repeating wide smudgy horizintal line across my printed pages
I had the same problem, replaced the PCR in the cartridge, the small black drum that pre charges the drum and erase the old image.
After that print was all back ok.
Regards
Dec 11, 2008 | HP Q2613A OEM Genuine Black Laser Toner...
Consistent, faded and streaking vertical lines across entire page, from top to bottom.
Toner issue getting to drum - use gen toner cart.
or Drum blade stuffed (lines are down page fro top to bottom- replace drum assy
Drum has been exposed to light faint or blank across copies repeated 4 times down page - replace drum assy
or upper fuser roller stuffed, down page, smudgy print -  replace fuser
LSU(laser) or boards rarely cause issues
Oct 25, 2007 | Samsung ML 2010 Laser Printer
Laser 3115cn All-In-One Printer Logo
Top Laser Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Alun Cox
Are you a Laser Office Equipment and Supply Expert? Answer questions, earn points and help others
