Question about Samsung NV10 Digital Camera
Camera not charging
My camera will not turn nomatter what i do. if i try charge it the charging light goes red and then about 10 minutes later an orange lite flashes... can any1 help ??
  • Anonymous Dec 16, 2007
    started with great pictures for 3 months, now, won't turn on, when it does, yellow light comes on for a few seconds, then shuts off. i've changed the battery with no luck. help!
  • 3 Answers
I got the same problem...it means battery is somehow discharging instead of charging..better get an external charger and remove battery from camera after every use.
Posted on Jul 06, 2009
SOURCE:
MY LG TONE HBS-730 WILL NOT CHARGE
It is charged when the red light goes out. Press and hold the VOLUME DOWN button for one second and an audible will give you the battery charge level - high - medium - low.
Apr 20, 2013 | LG Tone HBS-730 Bluetooth Stereo Headset -...
Delta CL 180 model charger turns on when you plug in and the yellow light comes on but when you put the battery in to charge the lights go out?
If all lights go out after the battery is inserted, the charger has entered pre-charge mode. In approximately 5-10 minutes, the orange and red lights should turn on indicating that fast charge has been initiated. If all lights remain off after 15 minutes, remove the battery. The orange light should glow. Reinsert the battery. If the orange light goes out when the battery is inserted and all lights remain off for 15 minutes the battery should be replaced.
Hope this helps.
Apr 09, 2012 | Dewalt Drills
I have a Sanyo T700 camera. Just got a new battery off Ebay. I inserted it inside the camera and a red light came on. Does that mean the battery is charging or does a green light mean that its...
The manual says that a red light is a charging error. Green means it is charging and the light goes out when charging is complete.
The camera must be turned off when charging the battery. They recommend a full 8 hour charge for a new battery, then allow it to discharge completely (leave the camera on I guess) and charge it again "before use".
You can download the manual from this page. Select the "Resources" tab.
Nov 05, 2010 | Sanyo Xacti VPC-T700 Digital Camera
Flip Mino HD will not boot, charge or reset
Call Flip support, problems are happening to too many people, contact Flip support, if they cannot help, contact MacWorld or other online reviewers and let them know.
Jul 06, 2009 | Pure Digital Flip Mino Digital Camera
Panasonic vx37
My old Panasonic Palmcorder IQ shows a red light in both switch positions-camera and VCR. Maybe yours has red for camera and green for VCR so you could tell them apart. I found that the Panasonic battery that came with the camera was the cheapest kind with the least charging time. I bought other batteries, they were good for a while, but now, many years later, they won' t hold a charge. Since I am only recording inside of my house, I have resorted to using the AC wall socket for power. I have to take the battery out of the camera. I found a power plug-in hole (like ones on cell phones) in the battery compartment. I also found one of these holes on my battery charger. My camera came with a double ended power plug. I plug one end into my camera and the other end into the battery charger. I plug the charger power cord into the wall outlet, and I have power to my older camera. Maybe you can find this double ended power cord at a store or on line.
Did you know that there are 2 kinds of batteries? Some have memories and others do not rely on a memory. The ones with memories have to be fully discharged or they will only charge a little, and keep charging less and less each time they are charged. The ones without the memory can be charged fully without being discharged fully. Check into battery information on line to get more information. Maybe you can get the non-memory kind.
May 18, 2009 | Panasonic NV-VX37 Mini DV Digital...
Vivicam 8300s
I've been struggling with the same problem and could not figure out what the heck was goin on. When I would connect the camera to the charger the red light (indicating charging) would come on for like maybe 10 minutes. I could take pics for like 30 minutes then the camera would lose juice. Also, the green battery icon (indicating a full charge) would only stay green for like 1 minute then it would go right to the yellow battery icon (half charge). After a couple of weeks the red light indicater would only come on for like a second. I played around with mine and realized that the battery terminals were not connecting to the power source inside the battery holder. Basically the battery wasn't snug enough inside the battery holder to connect to the power. When I pushe the battery in with my finger the red light indicater would stay on. So I took a little piece of paper (folded slightly) and wedge it in the battery holder and closed the battery holder cover. Hope this makes sense! (And helps.)
Feb 28, 2009 | Vivitar ViviCam 8300s Digital Camera
Charger blinks red and does not charge
This maybe a solution. I had the same issue just now. Pulled battery, put back in, placed on dock, and still blinking red. So I removed the camera from the dock, pulled battery, put same old battery back in, placed on the dock and turned the mode switch on right away before it started blinkin red. It seems to be charging now with one bar and has not gone blinking red for 15 minutes.
I was outside with the camera in 10 degree weather taking pics of my dogs but had been inside for 20 minutes before placing it on the doc. I think something may have happened with the charging circuit and turning it on right away with it on the doc may have reset the charging. Try it. Hope it works for you.
Oct 23, 2008 | Kodak EasyShare DX6490 Digital Camera
Sidekcik Lx will not charge.
Try a new battery for it.
Sep 09, 2008 | T-Mobile Sidekick
Samsung NV10 Digital Camera Logo
350 people viewed this question
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
