Question about Dell Vostro 270S Desktop Computer- 3rd generation Intel Core i5-3450s processor
Boot pxe - Dell Vostro 270S Desktop Computer- 3rd generation Intel Core i5-3450s processor
Error Message PXE-MOF: Exiting Intel PXE ROM. what does this mean?
That means your hard disk is not being detected. PXE is a network boot, which is typically used in business environments. Check your BIOS settings and ensure your hard disk is being detected. If it is, make sure your boot order is set correctly. Network boot (PXE) should be set to the last item in the sequence. If the hard disk is properly being detected and an OS is present, you should never see PXE.
If your hard disk is not showing up, power your PC down (unplug the power) and check the cables to make sure they are seated.
Mar 17, 2013 | Acer TravelMate 5730-6204 Notebook
Tip
PXE-E61: Media Test Failure
Issue:
My computer gets this message when I try to boot it:
PXE-E61: Media test failure, check cable
PXE-M0F: Exiting Intel PXE ROM.
Solution:
Your computer is set to boot from the network (PXE = Netboot).
Go to your BIOS and make sure you boot from your hard drive.
Remarks:
Shouldn't be enabled by default
[more...]
on Jan 04, 2009 | Acer Aspire 3680 Laptop
Hello, My laptop shows the following message when I turn it on- Realtek PCIe FE Family controller Series v1.19(08/10/09) PXE-EGI-Media test failure,check cable PXE-MOF-Exiting PXE ROM Reboot an
It can't locate a working boot disc. Most likely lost communications with hard drive. Look in BIOS again to see it recognizes the drive. If not try re-seating / reconnecting drive.
Feb 16, 2013 | Dell Inspiron N5010 Black
PXE-M0F Boot Failure
turn off network boot altogether in bios. also load bios optimum defaults.
May 08, 2012 | Computers & Internet
My laptop does not work it says PXE-E61:Media
Put 'Hard Drive C:' before 'Network' in the boot order
(If the hard drive does not appear in the boot order, that's why the PXE network boot agents start)
Note : Check that the hard drive is seen in the BIOS setup
Cause:
PXE (pronounce Pixie) is an agent used to boot on to the network
It's using the DHCP protocol to localise a server where the image of the OS is located
In order to PXE boot press F12 at startup or configure the boot order in BIOS to display 'Network' before 'Hard Drive C:'
If, for any reason, the hard drive is not seen the computer will attempt to boot on the network controller.
That is caused by the hard drive is missing, unplugged or failed
Jan 11, 2011 | Acer TravelMate 4062LCi Laptop Charger...
Prablon may loptop pxe-mof exiting broadcom pxe rom .broadcom undi pxe-2.1 v14.0.8
I think you hard drives failed. When the hard drive fails, the boot tries to find another way to boot up, so if the boot sequence lan is enabled, it will try to boot from the lan port (in your case broadcom pxe), when it can't boot from here either, it exits (exiting broadcom pxe). Replace your hard drive and re-install windows.
Oct 14, 2010 | Computers & Internet
Can't boot up without a boot disk
Your computer has been configured to try to "boot" by loading the Operating System from a network-connected "boot-server". Since you're _NOT_ likely to have such a "boot-server" in your home-network, the error-messages that you get are what are _expected_ when your computer is _NOT_ connected via the Ethernet cable to a 'PXE' (Pre-Boot Execution Environment) boot-server.
Enter BIOS-setup, and disable the "boot from network" option.
Mar 01, 2010 | Computers & Internet
Acer Aspire 5100-5674 won't boot. Keyboard won't work, mouse initializes. PXE-E61 : Media Test Failure then PXE-M0F : Exiting PXE ROM I really need some help, I just bought it. And would really like to...
PXE errors are generated by the network boot ROM. In other words, the boot process is attempting a network boot (your BIOS' 4th boot option), which means that your system was unable to boot from a HDD, CD-ROM, or USB device (the first 3 boot options).
PXE-E61 Media Test Failure, System won't boot:
1.Go to Bios Settings
2.Remove LAN booting from booting options...For laptop ,type "X" on the LAN booting option.
3.Save The configuration
Also verify if your harddisk is detected by BIOS
Jul 30, 2009 | Acer Aspire 5100 Notebook
your e-machine is set to boot from the network (PXE = Netboot)
go to your BIOS and make sure you boot from your hard drive
Aug 31, 2008 | Acer Aspire 3680 Laptop
Dell Vostro 270S Desktop Computer- 3rd generation Intel Core i5-3450s processor Logo
64 people viewed this question
Alun Cox
