Question about Whirlpool Duet GHW9150P Front Load Washer
Bearing I am trying to find out where I can purchase just the bearing for Kenmore front loaders, whirlpool is telling me I have to but the entire back half of the basket wich has the bearing in it already for $250.00 I just want the bearing where can I purchase it?
    President:
  • Whirlpool Master
  • 662 Answers
Just google kenmore washer parts Model:.................bearings.
Posted on May 01, 2013
SOURCE: open door
Turn off the machine and un plug, checked half hour later and the door opened.
Posted on Apr 20, 2008
  • 942 Answers
SOURCE: Whirlpool wfs1285aw noisy spin cycle
Hi..
If you washer is noisy,
  • Check that the water supply valves are turned on
  • Inspect the filter screen
  • Test for overheating
  • Inspect the water pump
  • Test the water inlet valve
  • Test the motor
General tips
  • Balance the load
  • Level the machine
  • Inspect the water pump for a blockage
  • Inspect the coupling
  • Inspect the transmission
  • Adjust the drive belt tension
  • Check the motor bearings
  • Check the drum brakes
Good luck !!!
Regards
PCmania
Posted on Jul 14, 2009
SOURCE: whirlpool front loader 6lhw0050pq washer won't
replaced belt
Posted on Jan 09, 2010
jumptrout51
  • 3361 Answers
SOURCE: For the Whirlpool GHW9200 washer, can the spindle
Sorry.
You gotta get the whole thing.
Posted on Sep 28, 2010
Testimonial: "Thanks for the prompt response. Looks like a new machine for the wife...bummer."
  • 2330 Answers
SOURCE: how do you remove the
you have to buy the whole tub or basket,each part is around 230 dollars.the basket part number is W10250573 and it's around 215 dollars,this is the part with the shaft on it,the rear outer tub part number is 285984 and it's around 225 dollars.
Posted on Apr 24, 2011
Why does it beep through the entire. Wash cycle. No code showing.
Whirlpool Duet GHW9150P Front Load Washer Beeping ...
www.fixya.com > ... > Whirlpool Duet GHW9150P Front Load Washer
Question about Whirlpool duet Washing Machines ... my front loader is not workingwhirlpool washer flashes and beeps will not finish a cycle 1 Beep/E10--Error: Water... It beeps through the wash and rinse cycle every couple of minutes. ... Cycle signal which tells you that the cycle is complete beeps through the entire cycle.
[PDF]front-loading automatic washer use and care ... - Whirlpool
www.whirlpool.com/.../U...
Translate this page Whirlpool Home AppliancesWash. This is the main portion of the wash cycle. You will see the washer tumble the load. ... Spin cycle. If the laundry is still wet, take half of the load out of the washer and try again. .... Using recommended AFFRESH® washer cleaner, add.
[PDF]DISHWASHER USER INSTRUCTIONS - Whirlpool
https://www.whirlpool.co...
Translate this page Whirlpool Home AppliancesThe first cycle using the sensor will run longer to calibrate the optical sensor. Rinse Aid. Using rinse aid will optimize your drying and wash performance. This dishwasher is ...... laundry detergent, hand soap, or dish detergent for hand washing .... models) you will experience more starts and stops throughout the entire cycle.
Continuous Beeping - Whirlpool Duet Sport Washer - The ...
appliantology.org > ... > The Laundry Appliance Repair Forum
Jan 25, 2016 | Whirlpool Washing Machines
I have a kenmore frontloading washer, during the spin cycle a noise like grinding can be heard, grinding can also be heard when turning drum by hand...help
its the drum bearings that support the inner drum,you need to replace these bearings,the problem with this is it was manufactured by frigidaire for kenmore and you cant just buy the inner bearing and lip seal as it comes with the outer rear half of the outer.tub where as with maytag neptune or whirlpool duet you can drive these bearin gs out and re-use the tub half,but you can't buy just the bearings and seal for a frigidaire front loader
Aug 31, 2012 | Kenmore Washing Machines
Loud noise during spin cycle kenmore model # w110.4770 front loader
When the rear bearing goes the best thing to do is shop for a replacement.
The rear bearing is not an economical repair to make and will cost more then the replacement with a similar new washer.
The bearing is built into the rear half of the tub and the entire washer must be torn down to replace it.
Apr 25, 2012 | Maytag Washing Machines
My clothings get grease like stains sfter I wash them with Kenmore washer.
Don't know if this is a front or top loader since you did not supply the model number. But if the stains are grease, it could only mean that the bearing seal has been compromised. Water is getting into the bearings and the bearing grease is what is on your clothes. You need to have the bearing and the seal replaced on your machine.
It is not to bad on a top loader in terms of cost to repair. But, if you have a front loader, that is a different story, since the entire machine needs to be torn apart to get to the bearings and the replacement parts and labor can be as much as a new washer. In either case, get a few estimates before deciding whether to repair or replace the washer. Hope this helps you.
Jan 08, 2011 | Kenmore Washing Machines
Top part of agitator does not rotate (bottom part does)What's the fix? Can I do it myself? Should I get a repair service?
If this is a Whirlpool manufactured top loader (such as Kenmore), the problem may be a worn agitator cam assembly, worn agitator dogs, loose agitator bolt, or all of the above. The following link explains what agitator dogs are and how to access them:
http://www.fixya.com/support/r3608577-replacing_agitator_dogs
Whirlpool manufactured washers use a split agitator design. The top half is known as the "auger, while the lower half is the agitator. Between the two pieces is a cam assembly, with small teflon teeth known as "dogs". There's also an agitator bolt that holds the entire assembly to the center post.
If the auger (top half of the agitator) is slipping, I would suspect the dogs or cam assembly need to be replaced. The part number for the dogs is included in the link I provided. For a little more you can purchase the entire cam assembly which includes the dogs, the cam, the cam seal and thrust bearing.
If the entire agitator appears loose or slipping, check the agitator bolt to ensure it is tight. DO NOT overtighten as this can restrict movement of the agitator or damage it. Tighten until snug.
Replacement parts can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If you do not wish to order parts on line, use the part numbers from the Sears website and go to your nearest appliance parts retailer. The agitator parts are commonly sold as part of their in-store inventory.
If you have any questions, please post back with your MODEL NUMBER (located on a nameplate along the wash tub rim under the lid) and let me know. I hope this helps you. NOTE: This is a very easy and inexpensive repair that does not require the assistance of a repairman. The average cost for the entire cam replacement kit is $15.
Mar 11, 2010 | Kenmore Washing Machines
Kenmore stackable , agetator cone does not move
repairclinic.com
If you have any questions, please post back and let me know. I hope this helps you.
Mar 10, 2010 | Washing Machines
My agitator doesn't turn like it used to
If this is a Whirlpool manufactured top loader (e.g., Kenmore, Estate, Roper and some later model Maytags), the problem is either a worn agitator cam assembly or worn agitator dogs. The following link explains what agitator dogs are and how to access them:
Whirlpool uses a split agitator design. The top half is known as the "auger, while the lower half is the agitator. Between the two pieces is a cam assembly, with small teflon teeth known as "dogs". There's also an agitator bolt that holds the entire assembly to the center post.
If the auger (top half of the agitator) is slipping, I would suspect the dogs or cam assembly need to be replaced. The part number for the dogs is included in the link I provided. For a little more you can purchase the entire cam assembyl which includes the dogs, the cam, the cam seal and thrust bearing.
repairclinic.com
If you have any questions, please post back with a MODEL NUMBER (located on a nameplate along the wash tub rim under the lid) if it is different from the one you posted this question under. I hope this helps you.
Feb 18, 2010 | Kenmore Washing Machines
The agitator sounds like it is grinding and shacky. It is not agitating properly
If this is a Whirlpool manufactured top loader (e.g., Kenmore, Estate, Roper and some later model Maytags), the problem is either a worn agitator cam assembly, worn agitator dogs, loose agitator bolt, or all of the above. The following link explains what agitator dogs are and how to access them:
repairclinic.com
Feb 18, 2010 | Kenmore 24032\24036 Top Load Washer
Hi..
  • Test the motor
General tips
  • Balance the load
  • Level the machine
Good luck !!!
Regards
PCmania
Jul 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
29 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
