Question about IBM xSeries Computers & Internet
Xseries 346 XP Install Problem!
Hi, I'm trying to install XP on my server, however the windows install cannot find my HD... so, I've tried putting some SCSI drivers onto a floppy and adding them as part of the XP install but still doesn't work! the drive is being registered by the machine so I know it works, and I had Windows 2003 working fine previously. I'm guessing I'm not using the right drivers? can you point my in the right direction as to which drivers I should be using or if its another problem? Thank you :)
  • 103 Answers
You need to install a "server OS" either (server 2000 or 2003, 2008)
windows xp will not work on the sever machine
Posted on May 02, 2013
2 Suggested Answers
  • 93 Answers
SOURCE: SCSI hard disk is not detecting in IBM xSeries 346 Server
Hi
While running the windows 2003 setup (winnt.exe), it will ask for SASI driver, you have to add the scsi driver... then windows 2003 os will detect the HDD.. then it will install..
Posted on May 19, 2009
Install Windows 2012 on IBM xSeries 346 server
check from the manufacturer which operating systems are compatible with your server
Mar 31, 2014 | IBM xSeries 346 Server
When Installing Windows Server 2003, Windows setup says it could find any hard disks
This is because the Hard disks are connected to Raid Controller . So you need the Raid controller driver in order to Install Windows 2003 OS. You can download the driver cd from below link .
http://www-947.ibm.com/support/entry/portal/docdisplay?lndocid=migr-5072250
Download image file > Burn to Disk > Boot Server from it > Follow the Wizard
That's all
Aug 06, 2012 | IBM eServer xSeries 346
Problems with IBM Xseries 346 Server
Check Light Path Diagnostic which is located on the front side of server . It gives a clue of what's the issue . If you can't see any amber on Light Path Diagnostic , then its an indication of max logs logged on BIOS event logs. You may need to restart server > Get into Bios and clear all event logs . This would remove the information sympol from server .
Jul 31, 2012 | IBM xSeries 346 Server
I am loading windows xp pro and it goes thru the instaltion till it goes to resart after restart it says there is no hard drive. i have run the rom iag, and it checks the hardrive oassin in all tests. how...
get a copy of xp pro service pack 2,or borrow dell xp cd of someone it comes with integrated drivers and installs all the way through,or disable sata in bios and give it a go worked for me
Apr 28, 2011 | IBM eServer xSeries 346
I have IBM XSERIES 346 server.when we start the server then a warning displaythat one logical drive is off line and two are defunt. Please help me to solw this issue.
i have the exact same problem. i bought this server in an auction and i can not install any os on it. have tried ubuntu and centos but neither can find the hard drives.
Nov 12, 2010 | IBM eServer xSeries 346
Steps to configure raid10 on xseries 346 with 4 HD using raid manager cd
See page 60 of the Configuration manual for that model located at http://www.abchost.cz/download/262-4/installation-guide-serveru-ibm-xseries-346-2u-s-cpu-intel-xeon.pdf
Jan 06, 2010 | IBM xSeries 346 Server
Hi
Apr 07, 2009 | IBM eServer xSeries 346
Physical drives not found
I"t says one logical drive is offline and two physical drives are defunct."
sounds like RAID. Try booting up off of one drive. If there is no OS, try keeping one drive in the drive bay and see if you get a orange light then. like dereknewland said, could be the backplane.
Mar 11, 2009 | IBM eServer xSeries 346
Xseries 346 wont boot
You don't say whether or not your os is on the RAID 5 partition. Assuming that it is (for performance reasons, this is not recommended) then you should check to see if you have the option of configuring a separate raid configuration on your raid card (e.g. do you have a card with more then one RAID channel?) If this is so, I would create a separate RAID 1 array and install the OS just on that. Then you can mount the RAID 5 array with your data intact. Once you're up and running, you can remove the old OS partition, as it's no longer needed.
Apr 02, 2008 | IBM xSeries 346 Server
Install windows xp on a IBM xseries 200 8479 computer
You have to download the scsi driver from the ibm site. You'll need a floppy and floppy drive. When you boot with your xp cd to setup press F6 to install driver.
Link to your IBM. Since IBM have different models you have to type it at the provided link.
http://www-304.ibm.com/jct01004c/systems/support/supportsite.wss/brandmain?brandind=5000008
good luck
Dec 20, 2007 | IBM eserver xSeries 200 8479
Computers & Internet Logo
111 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
