Question about Casio Exilim EX-S600 Digital Camera
Casio digital camera ex-s600 won't turn on
It shows red when charging but I can't get it to turn on whether it's on the dock or not. When I connect the USB it won't connect I still can't get it to turn on. it worked fine but i haven't used it for nearly 3 mos and now it won't work. Please help.
  • 10 more comments
  • southern23 Nov 16, 2007
    I am exactly the same didn't use it for only a month and it won't turn on. Wouldn't mind but haven't had it that long
  • Denise Rawr
    Denise Rawr Nov 17, 2007
    i put the battery on the dock..this red light was blinking. i put the battery in the camera it did not turn on. i plug the camera into the usb with the battery in side and it still did not turn on.
  • emm123 Nov 21, 2007
    also have the same pb as dineseey23, the red light on the dock keeps flashing and I can't turn my camera on. There's no help on that flashing light in the basic reference guide. Do you think it is the battery? How can I check? Where can I find such battery?
    Emmanuel
  • bas55 Nov 25, 2007
    I have same problem, red light is flashing when "charging".
    Can see pictures when in dock, but can`t turn on camera.
  • Anonymous Mar 24, 2008
    I have the same problem as well. I didn't use the camera for two months and it won't turn on and won't charge. My friend has a different model of the Exilim and also has the same problem. She replaced the battery in hers and it still won't work.
  • subsulta Mar 31, 2008
    i have exactly the same problem. My camera flashes with a red light when it is on the dock although it still does not turn on , you can see the pictures but not turn it on so you are unable to take photos.
  • Anonymous Apr 04, 2008
    I have the same problem as everyone above. My camara wont start.
  • Anonymous Apr 24, 2008
    Won't turn on.
    can view pictures when it is inthe charging dock by pressing Photo.
    Charge button appears as flashing.
  • Anonymous Jul 09, 2008
    Won't turn on.
  • Anonymous Jul 31, 2008
    won't turn on; flashes red charging light while in port, doesn't charge, however.
  • Anonymous Aug 07, 2008
    Same problem as reported by others.  Can't wait to call in for my battery unfortunately they're on the east coast and I'm on the west which means calling by 5pm PST.
  • Anonymous Mar 13, 2009
    Mine won't turn on either. I called Casio and unfortunately my warranty just expired so I have to shell out $20 for a new battery. If you call them, get tech support and tell them whether you get a flashing light on the charger when you try to recharge the battery.
*** SOLUTION *** Mine had the same problem. My camera works now. What did the trick for me was removing the Flash Card. It appears card went bad and the camera would never power on because of this. I just removed the card and the camera powered on. I tested the card on my printer and it wont let me read or reformat. Hope this helps. -HenryVerde
Posted on May 01, 2008
I just got one off ebay and im having the exact same problem! i dont know weather to call casio and yell or email the person and yell... its so frustrating. So its the battery that is causing all of this blinking and no power then?
Posted on Mar 26, 2008
My camera has been fine 3 months ago when i charged it the last time. But now it doest turn on and the flash light is not on either. What is the problem? Do i need to change the charging dock?
Posted on Jul 09, 2009
Same thing happened to me :o) thanks for the help!!
Posted on Jul 19, 2008
I too called the number posted above and the lady on the phone said it was indeed a problem with this models lithium battery. Casio will send you a new battery for free once you provide the serial number on the bottom of the camera as well as your name, phone number, and mailing address. EASY. Took me 3 minutes.
Posted on Jun 29, 2008
I read on another post that tons of people are having this problem (I am too right now) and all you have to do is call casio at 1-800-435-7732 (9am-8pm M-F & 9am-5pm S/S) and in less than 5 minutes, they will be sending you a new battery for free. There's another number for those in the UK... I don't have it off hand.
Posted on Jun 15, 2008
I finally bought a new battery and it started to work fine again. I found the battery in the first (battery) shop I went to, so I guess it is a common model... about 20€ though...
emm123
Posted on Mar 27, 2008
I received a new battery, there was something wrong with the old battery, now everything is working fine.
Posted on Feb 07, 2008
I bought an exilim camera not to long ago and it will not power up. it will work on the docking bay to look at the pictures but will not charge up.is it the battery and is this a common fault with them?
Casio should be sued. There's been so much of this problem. They produced so much faulty batteries.
Posted on Feb 01, 2008
Your problem is the battery. mine is doing it now to and from reading everyone else's experiences they needed a new battery because the old one went bad.
Posted on Aug 12, 2007
SOURCE:
Presently charging my camera, does the red light alway blink?
Base on User's Guide of Casio Exilim EX-S600 Digital Camera, Flashing red light when charging the battery is mean "charge error"
(see the picture)
to overcome some problems that may occur, please refer to the User's Guide of Casio Exilim EX-S600 Digital Camera which can be read here:
http://support.casio.com/pdf/001/EXS600_e.pdf
good luck :)
Apr 17, 2010 | Casio Exilim EX-S600 Digital Camera
NP-20 lithium battery not charging
Buy Ni-cd batteries instead there pretty good.
They are inexpensive, reliable and resist abuse way better than NP-20 because those batteries are poor for high performance applications such as digital cameras.
Good luck
Apr 11, 2009 | Casio Exilim EX-S600 Digital Camera
Charging Camera
I would test the docking station first. Do you have a way of charging the camera without using the docking station?
Thought I'd ask because some can and some can't.
Jun 21, 2008 | Casio Exilim Card EX-S600 Digital Camera
Casio exilim ex-s600
Take out the battery and memory card, then reinstall them.
Jun 20, 2008 | Casio Exilim EX-S600 Digital Camera
Casio Ex-S600 (Exilim Digital Camera)
The NP20 battery that your camera requires is not taking a charge because of a "charge error". Please contact tech support and give them your address and they will replace the battery free of cost for you.
Nov 13, 2007 | Casio Exilim EX-S600 Digital Camera
Docking station does not synchronise
Possible faulty connection between docking station and camera. Depending on age of the camera- send it back for replacement from the seller or contact Casio. Does this model have a removable memory card? If so invest in a card reader - very cheap and more reliable than docking stations.
Aug 20, 2007 | Casio Exilim EX-S600 Digital Camera
Charger light flashing, battery not charging
What you can do is call their tech support department and they should be able to replace the battery for you. Tech support will take your information and request you to send in your battery before they replace it.
Jul 23, 2007 | Casio Exilim Card EX-S600 Digital Camera
Camera possessed?
There is obviously a connection problem between the camera and the dock. Is it possible to recharge via a normal charger. I don't think you will get a repair- unless it is a young camera with some warranty left
Jun 21, 2007 | Casio Exilim Card EX-S600 Digital Camera
Please help
It should still be under warranty, sounds like the rechargeable battery has died, either take it back to the shop or buy a new battery.
May 03, 2007 | Casio Exilim EX-S600 Digital Camera
Casio ex-s600
Hello Gery, Try with the new battery. Best regards, Arpad
Jan 10, 2007 | Casio Exilim EX-S600 Digital Camera
Casio Exilim EX-S600 Digital Camera Logo
2,173 people viewed this question
Top Casio Cameras Experts
Ekse
atollminsk
Level 1 Expert
Parshiv Luthra
Are you a Casio Camera Expert? Answer questions, earn points and help others
