Question about Dell Inspiron 2200 Notebook
Screen goes black after loading windows xp - Dell Inspiron 2200 Notebook
    Novelist:
  • 148 Answers
Is it possible that it's display output is set to external screen, display no 2 from within the graphic cards settings/preferences. I cannot see how while in the GUI (XP Loaded) that making an adjustment not suitable for Laptops screen can take affect without XP sending out error messages. I really am curious now as to what the problem is or was, cheers.
Posted on May 01, 2013
3 Suggested Answers
leecom72
  • 4806 Answers
SOURCE: Dell Latitude D600 Bootup then screen goes black
bad display drivers, boot into safe mode (F8 on boot) it should let you use the computer, unistall the graphics drivers and reboot again in normal mode, when your in re-install the graphics again
regards
Posted on Nov 22, 2008
bschilz
  • 2049 Answers
SOURCE: My computer begins to load windows, then after the
Nine times out of ten if that's when your display stops, it's simply because your display settings are set to something that your monitor can't handle. Depending on what it's not supporting, some monitors respond by going black ... others just go "crazy" displaying unintelligible gibberish.
If that's the problem, it's fairly easy to fix.
First things first ... let's get you a bootable system.
Boot in safe mode - press F8 when the Windows loader presents you with the 30 second list of choices, and then select "Safe Mode" as your boot option.
Right click on the desktop and click Properties, and then on the Settings tab.
Now click and drag the Screen Resolution slider to the far left ... you want the smallest settings that your screen will support. Typically that'll be 640x480, or 800x600.
Also change the Color Quality dropdown to 256 colors, or whatever is lowest. (You probably don't need to go as low as 16 colors, if that's presented as an option.)
Now, click on the Advanced button, and then the Monitor tab of the resulting dialog box. Change the Screen refresh rate to 60 Hertz.
OK your way back out, and reboot your machine. If these setting were the source of the problem, it should now be able to boot normally. You may not like the screen settings, but at least you now have a place to start.
"Start experimenting with the settings to see what does, and does not, work with your monitor."
If the display is still blank or gibberish, the my recommendation is to once again boot into Safe Mode, possibly Safe Mode with networking, and update your video display drivers. It's likely that they are incorrect or otherwise broken. Now start experimenting with the settings to see what does, and does not, work with your monitor.
I tend to start with the screen resolution. Once again right click on the desktop and click Properties, then Settings, and then drag the Screen Resolution slider a notch or two to the right to increase your display resolution. Now click Apply. It should change the resolution and display a small message box asking if you want to accept this setting. If you don't respond within some time, it assumes you can't see it, so it resets to the previous setting. If the screen goes blank or you can't read it, wait at least one minute before doing anything. The problem may resolve itself, and you'll be able to say "well, that resolution doesn't work", and move on to try another.
If, after a full minute or more the screen remains blank or unreadable, you'll have to reboot into safe mode, as we did originally, to restore your setting. (Why might this happen? Windows "remembers" and doesn't bother to ask you if you reset to something that you previously said worked. If you mistakenly said "this works" when it didn't ... perhaps by random keyboarding while the display was blank ... well, that could be how we got here in the first place.) You can repeat this process of trial and error for each of the screen resolution, the color depth and the screen refresh rate. (For CRT displays, you really do want the refresh rate to be as high as your monitor supports.)
Posted on Nov 28, 2009
After changing out fan IBM think pad t40 screen goes black after windows xp screen finishes losding up
Wait Black Screen? AFTER you changed the fan... hmmm... I think I know what the problem is. Okay solution one; You might of hit a wire or cord in the computer when you changed out the fan. Two: You might have the virus 223, get it fixed and it should be going again! Hoped this helped! :D
Mar 25, 2013 | IBM ThinkPad T40 2373 Notebook
My window xp has no monitor
Is the screen black from the moment you turn your PC on? Or do you see the BIOS splash screen and Windows loading, but when Windows starts it goes black?
Jan 21, 2013 | Computers & Internet
Windows XP Home Boots midway and screen go black.
Follow the tips below to fix the problem:
  • Scan PC for Viruses
  • Clean Registry
  • Run Last Known Good Configuration
  • Repair Windows
Mostly professionals recommend Intel Partner Software, RegInOut System Utilities to fix the Windows boots to black screen problem.
Dec 27, 2011 | Microsoft Windows XP Home Edition
Xp tries to load and then goes to safe mode black
Try choosing "Last know good configuration" when you get to that screen,then hit ENTER
Apr 13, 2010 | ASUS Eee 4G Notebook
My acer aspire 3050 will not run normally. after the windows xp loading screen thers a black screen tht never goes away. y wont it load?
boot from your windows xp installation disc or system restore disc.......
either do a Repair Or Restore (windows=Repair)
Follow the on-screen Directions.......
In Other Words, You have a corrupted Windows Installation........1 or more vital system files
Apr 21, 2009 | Computers & Internet
Black screen after fresh install xpmc 2005
Are you able to go windows safe mode if yes ... Start > Run > Msconfig > Ok
in the general tab you have option to seleect Normal Start up > Click on apply and ok and restart yiur computer that should work
Apr 09, 2009 | Microsoft Windows XP Media Center Edition...
Blank Black Screen After Windows XP Loading Page
the easiest solution would be to re-install windows and hope it is not a hardware problem
Jan 12, 2009 | Dell Dimension 2400 PC Desktop
Dell Inspiron 2200 Notebook Logo
27 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
