Question about Dishwashers
Electrolux dish washer WT65E
Showing C8
2 Suggested Answers
VOTIT
  • 2071 Answers
SOURCE: my dish washer dose not start, it keeps yieling "
Hi enasammar, First thing to do is to reset. Merely unplugging the power cord from the wall socket for 4 hours, then power up again.The purposed of unplugging is to dissipitate the stored current in the memory IC thats control the unit to hang up, so it will gone. Take out all inside the unit and clean,then turn on . If still not working give me the model number so i can find the schematic diagram for that unit. Hope it may helps.
Regards: VOTIT
Posted on Dec 03, 2010
C8 fault code
C8 = During rinse phase boiler doesn't empty
possible causes:-
Are the rinse arms clogged?
Does the rinse pump work correctly?
Is there water in the level sensor tube?
Is there scale in the boiler?
Does the boiler level sensor work properly?
CAUTION: RESETTING THIS ALARM WITHOUT FIRST ELIMINATING THE CAUSE IS DANGEROUS; THE BOILER HEATING ELEMENTS COULD WORK DRY, FURTHER DAMAGING
THE INTERNAL PARTS OF THE DISHWASHER.
CAUTION: C8 IT MUST BE MANUALLY RESET AFTER ELIMINATING THE CAUSE OF THE
MALFUNCTION
Jun 25, 2014 | Electrolux Dishwashers
Dishwasher electrolux wt30 error code c8
Hello Said Raji - Are you certain the error code is C8? Could it possibly be CE? If so, it typically indicates that the dishwasher has detected a configuration error. A professional will need to check the wiring connections between keypad and main control board.
Jan 16, 2013 | Electrolux WT30H240DU Dishwasher
DISHWASHWER WT 65 EIM:ERROR CODE C8.WHAT DOES IT MEAN?
according to the manual...error code 8 indicates a problem with the control panel. here is the link to this manual...page 21 of the pdf http://manuals.electroluxusa.com/prodinfo_pdf/Kinston/154671101en.pdf
Hope this helps you! PS, this model number in the link may or not be similar to yours I had a problem locating your exact machine..so let me know if it isn't the right one and I'll go look some more. meantime...is there another model number on the inside side of the washer door?
Jun 21, 2012 | Electrolux Dishwashers
Electrolux wt55 error code c8
If there is a set button hold it for 5 seconds.
C8 means that at the rinse phase the boiler did not empty.
The reasons are ..
1) the nozzles are blockled
2)Drain pump out of order
now you must reset c8 from the parameter in order to start again the dishwasher
May 05, 2011 | Dishwashers
What does the display C 8 stand for as i am not able to start the dishwasher
The reasons are ..
3) bad luck
now you must reset c8 from the parameter in order to start again the diswasher
kostas
Jan 17, 2011 | Electrolux 504199 Dishwasher
Electrolux dishwasher error c8 What does this mean please??
The reasons are ..
3) bad luck
kostas
Nov 08, 2010 | Electrolux 504199 Dishwasher
G,day i have a electrolux dish washer model 302 that is not heating at all.where do i look for the heating element.Thanks
Hi Kanejake,
I'm Harvey the Master Plumber.
Your question is: you have a electrolux dish washer model 302 that is not heating at all.where do you look for the heating element?
First, check to see if the "air dry" button is on. It should not. The heating element is the blackish rail that runs around in the bottom of the d/w. I don't recomend this repair to homeowner. You might consider looking in the Repair Directory for a repairman. If the d/w has a few years on it you should compare the costs of repair verses replacement.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 13, 2008 | Electrolux Dishwashers
Have a trouble: dish-washer will not drain.
I just moved into a new house and builder had provided a dish washer drain just below my kitchen drain line.
DIsh washer install was done by me, every thing worked out OK except dish washer would not drain after a wash cycle.
Cause: drain provided by builder was blocked and needed a circular small cut before mounting drain hose over it.
Mar 21, 2007 | Electrolux 24 in. ESI6220X Free-standing...
Dishwashers Logo
97 people viewed this question
Top Dishwashers Experts
