Question about Kitchen Appliances - Others
Cleaning Grill How to clean girl
  • 3 Answers
With wire brushes on cooking grade and 409 and wipes on other surfaces. Common sense and elbow grease.
Posted on May 01, 2013
Tip
Easy grill cleaning
It's that time of year, time to get the trusted outdoor grill cleaned and ready for that never ending supply of burgers, franks, and whatever else suits your palette.
Unfortunately that grill needs to be made to look almost new, and what a pain that can be.
Try this to make cleaning a lot easier. Put the grill in a large plastic trash bag and spray oven cleaner in the bag. Close the bag and secure it with a twist tie. Let it sit at least 24 hours then remove and rinse it clean with a garden hose.
on Apr 08, 2010 | Grilling
Sear burner shooting fflames not glowing
Try turning down the temperature on your gas grill. Have you tried cleaning the grill with chemicals lately? Grease on the the burners maybe? Just found out that WD-40 is great for cleaning the grill. But you probably have to wait a while to use it again. Wipe excess cleaner off with dry paper towels.
May 13, 2014 | Nexgrill 720-0234 (LP)
Grill doesn't heat to high temperature.
try cleaning the injectors they could be blocked
Aug 13, 2012 | Ducane 30400040 Stainless Steel Grill
How to remove top grill on SZ650 for cleaning?
Inside the refrig. door around the top part of the door frame is either 1 screw in the center or 2 screws in the corners holding the upper grill to that door frame/rim. remove that/those screws which usually are phillips head and pull grill down and on the back side of the grill will be some springs that have a hook where they attach to the grill unhook those springs and the grill will come completly off. When cleaning the coil beware to be as gentle as possible and try not to bend the fins on the coil.
Gene
Aug 09, 2011 | Sub-Zero 650 / O Bottom Freezer...
How do I clean the outer grill of the interior? Does the lid come off for cleaning?
There are 5 screws maximum with grill. Unscrew and gently lift up for cleaning and refix it.
Dec 11, 2010 | LG LS-K2430HL Heat Cool Mini Split Air...
Need to clean..............how do I get it apart to clean model 280SS Have had this model for quite sometime and it deperately needs a cleaning. THNAK YOU!
There are four clips the hold the grill to the cowl.
Look along the outer edge, on the back.
One clip at 11 o'clock, one at 2 o'clock, one at 4 o'clock, and one at 8 o'clock.
Use a flat blade screw driver to push the 11 and 2 positions down (do 11 then do 2) and the grill shuold come off. The clips are just tabs molded into the grill, don't push too agressively, or the tab will break, and the grill will not latch on as well. Check the Vornado website for more information. They used to have a video about cleaning.
Use mild soap and water the clean the blades after removal.
Sep 14, 2010 | Vornado Circulating Fan
I just bought a used refridgerator and it seems to make a buzzing, rattling noise at times then stops. Then it will start again later. The girl I bought it from said the coils may need cleaned or it may...
Hi there
The noise is a very annoying thing in refrigerators but to stop these please do the following.
Pull the refrigerator away from the wall and unplug it.
Find the condenser coils on the refrigerator and clean them. These coils disperse heat, so cleaning them improves the effectiveness of the refrigerator which helps to stop the refrigerator from buzzing. To locate the coils, you will need to check your refrigerator owner's manual as they may be rear mounted or floor mounted coils.
Remove the dust build up on the condenser coils with a vacuum cleaner or condenser brush. If there is a large amount of build up on the refrigerator coils, you can use mild soapy water to more thoroughly clean them.
Clean the grill on the front of the refrigerator as it will also help eliminate the noise. The grill on front of the refrigerator should snap off and on, but check for screws first. Then pull firmly toward you to remove the grill.
Do these troubleshoots and the buzzing should stop
Sep 02, 2010 | Refrigerators
How do I get my panini maker clean again
From the Owners Manual:
Before cleaning, switch the grill off at the on/off button, switch off at the power outlet and unplug. Allow your Professional Grill to cool before cleaning. The appliance is easier to clean when slightly warm. Always clean your Professional Grill after each use to prevent a build up of baked-on foods. Wipe cooking plates with a soft cloth to remove food residue. For baked on food residue squeeze some warm water mixed with detergent over the food residue then clean with a non abrasive plastic scouring pad.
May 24, 2010 | Breville 800 Class 800GR Indoor Grill
Ignitor on gas BBQ no longer works. Replaced battery and cleaned out chamber (light rust). I've tried to remove the ingnition housing, but the entire front panel of the BBQ needs to be removed. Suggestions...
Check to see if the probe where it sparks to the burner inside the grill is clean and not shorted by grease or other gunk and the burner itself in this area is not too heavily rusted or corroded. If not, short of disassembling the whole grill and replacing the spark module, spend $2-3 and buy one of those pistol type grill lighters. The ignition systems on BBQ grills rarely seem to last long.
Feb 24, 2010 | Grilling
Kitchen Appliances - Others Logo
75 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
