Question about Kyocera FS-C5015N Laser Printer
Ef not supported
Showing ef not supported on screen
I bought a new thermostat for my for my Depot commercial deep fryer model EFS - 40 at work for 3 days after that I just cut off and won't come back on so what would be the problem
Questions, Troubleshooting Help & Support Page 9 - Fixya
www.fixya.com/troubleshoot/page-9
I bought a new thermostat for my for my Depot commercial deep fryer model EFS -40 at work for 3 days ... SHOWS NO SIGNAL IT WAS WORKING FINE UNTILL I TRYED THE FAV BUTTON ... Once I found a fried ground wire in trunk replaced.
Sep 25, 2015 | Kitchen Appliances - Others
I have an error code "EF" for my Electrolux
Generally, EF error is showed with an additional number on your display... EF 1, EF 2, EF 3, EF 5, EF8, or EBF.
Each error code will depict a different cause and solution. Out of these solutions, the most common is the control board and possibly the UIB (User Interface Board), or too higher mains voltage coming into the house, causing damage in this UIB device.
Test and check voltage, if this isnt solve it, relace UIB device.
Hope this helps.
Mar 05, 2012 | Electrolux EW1200i Front Load Washer /...
Brother dcp 7055 error-EF
brother dcp 7055 error-EF laser
Nov 22, 2011 | Office Equipment & Supplies
My lg ku990 viewty mobile phone has come up on the screen totally yellow and says in the top left corner REFRESHING i have tryed turning it off and unplugging the battery but it makes no difference! i have...
Hi, read the sections on the fallowing links.
But keep in mind that you've the software do his work and wait cause this process take up to
1 hour and 30 min. As you can see what EFS MEDIA BUILDER by AKOM1976 do is read the phone
then you will see a map that you have to rename for the secret switch! There is a secret switch to see
the hidden folders. The map LGAP has to rename to TOTO and when finished vice-versa.
Be patient when re-flash the phone when its ready it show a yellow screen but don't do anything just
wait!!!!! At that time the EFS MEDIA BUILDER is unpacking the files and when the process is done
the phone restart again and install the files after that when it is ready the phone starts up with a brand new software and show the welcome and configuration screen for the time, date and screen settings as it came from the factory.
Read the links below and fallow the steps. This time your phone will be alive!
http://www.fixya.com/support/t2141371-screen_broken_cannot_get_contacts_ku990
http://www.fixya.com/support/t1793053-lg_ku990_yellow_sreen
Henk®Muskita©2010.
Dec 23, 2010 | LG KU990 Viewty
My CANON EOS REBEL xs does not show the picture I am trying to take on the screen. The screen is either blank or shows a menu screen
Set the shooting mode to a Creative Zone mode. Under the Setting tab, select [Live View function settings] and press SET. Select [Live View shoot] and press SET. Select [Enable] and press SET. Press the MENU button. Press SET.
Jul 09, 2010 | Canon Rebel XS / Eos 1000D Digital Camera...
KU990 .pxo file problem
hay there ..it will help you...i just made that same mistake but i overcome from it..connect ur mobile to usb..and open it through efs media..then.select the port if it shows..if not try refresing and reconnecting...after connect u will see a new lg app create by system..rename it to toto again and disconnect ..then reconect and rename..toto to lgapp..this return back my viewty..and am so glad..
Nov 26, 2009 | LG KU990 Viewty
View screen on back
The XT does not have a "live view" feature. You have to use the viewfinder.
The LCD is strictly for data and picture viewing.
Dec 08, 2008 | Canon Digital Rebel XT / EOS 350D Digital...
Kyocera FS-C5015N Laser Printer Logo
124 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
