Question about Garden
Ran out gas wont start
Ran out of gas now it will not start
  • 7,482 Answers
Hi mdd3562
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper and or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of sharp instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line/s condition...after a while they will degrade and need replacement.
Check/Clean/Replace your fuel filter if you have one.
When you remove your fuel lines from the carburetor be sure to make a drawing or take a picture of how the lines are connected to the carburetor.
Also a good time to take a picture for later reference for reassembly.
If the mower is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Bud
Posted on May 01, 2013
Ran out of gas out gas back in wont start wont?
you haven't mentioned what make or model of vehicle
you will have to check that the pump is actually working as some fuel pumps have small plastic gears as the pump and when run out of fuel these gears have no lubrication and so melt in the case
( toyota 4 runner from experience)
Jul 18, 2015 | Cars & Trucks
Ran out of gas and wont start
ran out of gas while it was warming up , I put gas back in it and turned the key a few time still wont start up
Jan 03, 2014 | 2000 Dodge Stratus
Ran out of gas and now it wont start
Today's not your day Lisa,now you have gas and still can't go.
Dec 23, 2012 | Cars & Trucks
Ran out of gas, replaced gas try starting, wont
hit the key five times without trying to start, just bump the starter, after the fith time turn it over and it should crank
Mar 23, 2010 | 1999 Cadillac DeVille
Ran out of gas, now it wont start. Just turns over
it might be that the gas pump isn't connecting to the engine.
Aug 06, 2009 | 2003 Chevrolet Silverado 1500
1994 cutlass supreme I ran out of gas. After i put gas in it it
if you let car run out of gas.it over heat fuel pump some times it damages it.it wont start again.
Jul 23, 2009 | 1994 Oldsmobile Cutlass Supreme
Car wont start
It is very bad to let your car run out of gas. You may need to give it exessive amount of gas when starting it.
Apr 23, 2009 | 1996 Oldsmobile LSS
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
