Question about Intel Desktop Board D845GLLY Motherboard
My pc with mother board d845glly is getting restart frequently after putting it on what doi do
  • Intel Master
  • 5,660 Answers
ahamed100
  • 148 Answers
SOURCE: PC RESTART ANY TIME
Important Note: Only a computer professional should perform assembling, disassembling, upgrading and troubleshooting computers since the electronic devices may cause serious damage to the installer, the system, or its components if it is done improperly. Before attempting to disassemble or assemble computers, install components in a computer or troubleshoot computers, carefully review the documentation specific for the computer and its related components. Lastly, make sure to follow Electrostatic Discharge (ESD) procedures.
  • Determine if the system worked before. Determine if there have been any recent changes. Often if a recent change is been made, the recent change is the cause of the problem.
  • Check to see if your system feels warm and check the processor for overheating. NOTE: Use extreme caution when checking for heat, since you can be easily burned.
  • Make sure that the power supply fan is running properly and any other external case fans are running properly. Make sure that the air intakes for the external fans are unobstructed and have at least several inches away from walls and other items.
  • Make sure the fans on the processor are connected properly and running.
  • Make sure that the thermal interface material or the thermal grease is applied properly.
  • Disable thermal measurements and power saving features in the BIOS setup program.
  • Update the system BIOS to the newest version. In addition, check to see if your system has a firmware that could also be updated to the newest version. Refer to your motherboard documentation.
  • Check the BIOS using the BIOS/CMOS setup utility, particularly the boot order. Make sure that your system is detecting all of the drives and make sure that the drive you are trying to boot is listed.
  • Do not overclock your system. Your system can become unreliable, may shorten the life of your PC components, may damage your PC components and may void your warranty.
  • Check the BIOS using the BIOS/CMOS setup utility, especially the RAM settings.
  • Suggest running ScanDisk to see if your hard drive has a lot of lost clusters and other anomalies. If you don't properly shutdown your computer using the Start button shutdown option, you may see some lost clusters and possible bad clusters.
  • Suggest running an updated virus checker to see if your system is affected by a virus.
  • Suggest reloading the OS, drivers or program.
  • Suggest reformatting the hard drive and reinstalling everything
  • Verify that your chassis/case and power supply is appropriate for the processor model and frequency and the motherboard you are planning to use. For Intel Pentium® processor 4 based systems, you should be using an AXT12V, SFX12V or PS3-12V power supply.
Posted on Mar 02, 2008
lolita
  • 385 Answers
SOURCE: dowloading graphic driver
You can download all drivers for Windows XP from here.
Lolita
Posted on Apr 10, 2008
  • 1602 Answers
SOURCE: restart my computer at rendering time.
GO ON LINE TO THE FOLLOWING SITES
WWW.X86.ORG
WWW.X86.COM
WWW.CSIF.CS.UCDAVIS.EDU/-WEN/INTEL.HTML
WWW.MOTHERBOARD.ORG
WWW.TOMSHARDWARE.COM
GO ON LINE OR ADDRESS BAR TYPE
INTEL SE7520JR2 MOTHERBOARD DG33 ERRORS
OR
INTEL MOTHERBOARDS DG33 RENDERING TIME
ENTER
SEE IF OTHERS ARE HAVING THE SAME PROBLEMS, IF IT IS BOIS, CURCIUTRY ERROR
OR RECALL ON MOTHERBOARDS.
ROD
Posted on Feb 09, 2009
zohail
  • 1223 Answers
SOURCE: D845GLLY mother board unable to detect 250 GB SATA seagate hard disk
have u installed sata raid driver in Win XP ur system might not contain the driver for SATA drive pls download and install
http://downloadcenter.intel.com/T8Clearance.aspx?sType=&agr=Y&ProductID=2300&DwnldID=17268&url=/17268/eng/iata87enu.exe&PrdMap=&strOSs=45&OSFullName=Windows*%20XP%20Home%20Edition&lang=eng
pls rate me FIXYA if ur problem is resolved
Posted on Mar 17, 2009
  • 48 Answers
SOURCE: MY MOTHER BOARD NMBER
Are you sure you downloaded it for your operating system? Try running the program as administrator. Try playing with the compatability options also
Posted on Feb 28, 2011
Can I replace 256 MB SD RAM with 512 MB DDR1 ram in intel 845 glly mother board?
I have installed RAM of 256MB each (2slots total 512MB ) and system BOOTS UP, but it keeps restarted on every 5 minutes.
Please advice
It is 845 GLLY Original and 1.7ghz.
Dec 27, 2009 | Intel D845GLLY Motherboard
PZ TELL ME ABOUT WHICH PROCESSOR(CLOCK SPEED) SUPPORT INTO 845GLLY MOTHER BOARD
845GLLY supported processors:
1.6GHz to 2.4 GHz Pentium 4 processors with system bus frequency of 400 MHz, for more information follow this link: http://support.intel.com/support/motherboards/desktop/d845glly/sb/cs-012859.htm
Apr 29, 2009 | Computers & Internet
Oct 16, 2008 | Intel D845GLLY Motherboard
Probblen in Additinol RAM
Hi Raj_jp, the Intel D845GLLY board must have SPD memory to function correctly in the system. The memory you added (512MB) must not support SPD. To help you understand what SPD is, you can click on this link which explains what SPD is.
http://searchcio-midmarket.techtarget.com/sDefinition/0,,sid183_gci533524,00.html#
The memory sold in this next link will function in you're Intel motherboard. http://www.memory-up.com/Memory/IntelD12696.html
So will the memory in this next link.
http://www.memorystock.com/memory/IntelD845GLLY.html
If you bought the 256MB memory recently, you should be able to return it & have it exchanged. The link above also lists the part number for the memory.
Good Luck!
Remember you're Intel motherboard uses you're system memory to run the onboard video card. The total amount of memory the video card uses can be adjusted higher or lower. You can adjust this in the bios. Go to Advanced Menu. Page 40 in the Intel user manual. You can download you're manual at this link.
http://www.intel.com/support/motherboards/desktop/d845glly/sb/cs-008853.htm
Mike
Jun 02, 2008 | Intel D845GLLY Motherboard
Dowloading graphic driver
Lolita
Apr 10, 2008 | Intel D845GLLY Motherboard
Sound driver
i want intel desktop board d845glly mother audio driver
Jan 19, 2008 | Intel Desktop Board D845GLLY Motherboard
Intel Desktop Board D845GLLY Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
