Question about LG SecurDisc 20x External Double-Layer DVD RW/CD-RW Super Multi Drive
CnM External Disc Drive
My external Disc drive has stopped working? It worked for a few weeks and now when I connect it to my laptop the lights come on it runs for a few second and then stops
2 Suggested Answers
get_fixya
  • 32 Answers
SOURCE: Laptop not recognizing drive...
sir
you should reinstall the drivers for your DVD ROM . It should be given to you when you have purchased it.
if not go here and download
Posted on Mar 10, 2009
My Toshiba px1394u-3g50 external hard drive is not working, light flashing and not recognised
Try connecting the hard drive to some other laptop and see if its getting recognized. Issue could be either with the hard drive itself of it could be with the usb port which you are using to connect the hard drive to your laptop.
Jan 17, 2012 | Computers & Internet
I have a 320gb toshiba external hard drive, i've been using it around 3 years without any trouble. A few days ago i lost the cable connecting it to the PC. I bought a few cables but no use. Doesn't...
This is because there is a connection problem between the external drive and the computer. If you have changed cables to no avail, you can open the casing of the external drive where you will find the hard disk inside. Unplug the two cables connected to the harddisk and replug it after a minute. Then try again. If it still does not work, then you need to buy just a usb enclosure and plug the harddisk there to be able to use it again.
Hope this helps. Thank you for using FixYa.
Jan 13, 2011 | Toshiba 120GB USB 2.0 Portable External...
I have a Fanner SPIRE Aluminium Gigapod External 3.5" external hard drive linked to my Windows XP laptop but the link up between the two has recently become increasingly slower as has the response of the...
The hard disk inside that Spire case has died - running the free space clean from CCleaner (a very intensive procedure) has been the death blow to an already sick disk.. Nothing more can be done to save it and the data on it. Replace it with a new one.
Jul 17, 2010 | Fanner SPIRE Aluminium GigaPod External...
External Buffalo Hard Disk 500 Gb model no HD-PF500U2/BK-AP not detecting when connnected to a laptop or a desktop PC
Check the usb port function in the computer bios settings and be sure that it is set to yes. Connect properly your external drive. If it has two wire usb connections, use both to obtain the maximum power that will be need by your drive.
Dec 18, 2009 | Buffalo Technology 500GB DRIVESTATION...
Disc drive stopped working
A hard drive can stop working just like any other electronic device when it becomes faulty.
First go into the BIOS configuration and check if the hard disk is detected. If not it could be faulty.
Next re-seat the hard drive, it just may need connecting again to make proper electrical connection.
If it still does not work, then remove the hard drive and plug it into an USB hard drive adapter and connect it to a working computer's USB port. If this computer cannot see it as an external USB hard drive nor can you open the folders and files then the hard drive is definitely faulty.
To get the laptop functioning again, replace the hard drive, install Windows on the new hard drive together with the laptop's device drivers and your programs.
Dec 11, 2009 | Compaq Presario Notebook
External hard drive wrong power supply was plugged in
The power circuits in the external hard drive enclosure may have burnt out or the fuse may have blown. Its unlikely your hard-disk is itself damaged.
You may remove the actual hard-disk from the enclosure and put it in another and access the data.
All the best!
Jan 29, 2009 | Computers & Internet
Hi. I have a Packard Bell Store & Save 3500 320GB external USB drive with power pack. Acer Laptop TravelMate 4220 with XP Pro SP3. Connecting the 3500 hangs the laptop. I read somewhere previously that...
The sequence you plug in the hard drive shouldn't matter. I would click Start -> Run and type:
eventvwr
Click okay. When the Event Viewer loads, click Application. Do you see any errors associated with the times you plug in the drive? Also, check the System events and look for the same thing.
If I were you, I would replace the cable connecting the computer to the external drive. If that doesn't work, I would get another external enclosure and transfer your drive to it.
Jan 24, 2009 | Computers & Internet
My PC is not recognizing my WD Passport 120GB USB external drive. I used just few days ago and connected the usb cable to my computer and the WD Passport drive and not recognized on my 2 laptop and 2 other...
I have the 80GB WD passport and it suddenly stopped working one day.  The unit lights up but nothing else.  Finally I cracked the case open and found, as I suspected, that the drive is simply a SATA laptop drive with a SATA-to-USB conversion card built in.  I suspected that the card was **** so I disconnected it and used a USB hard drive adapter (http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=3770&name=USB_Hard_Drive_Adapter) and I can read/write to the drive just fine.  Best part is that the adapter I use has its own power supply so I'm not pulling juice through the USB cable for a SATA drive.
Even though mine "works" again I don't recommend these drives to anyone.  They're just not sturdy enough or well designed.
Sep 09, 2008 | Western Digital Passport WDXML800UE...
Open Questions:
See all LG SecurDisc 20x External Double-Layer DVD Questions
LG SecurDisc 20x External Double-Layer DVD RW/CD-RW Super Multi Drive Logo
24 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
