Question about YTL International Push Broadcast Spreader 125 Lb
Instructions to assemble tow behind lawn sweeper
The back instruction with rods
Why does right wheel does not turn freely?
Clean out grass and debris, check wear and tear on bearings
May 30, 2014 | John Deere 42 in. 24 cu. ft. Tow-Behind...
Lawn sweepers
Sounds like your gearbox may be locked up.
I recommend that you contact your nearest authorized service center, or you can download operators and service manuals directly from the Agrifab website by clicking on the provided link:
Downloadable Manuals
I trust this information proves useful.
Apr 22, 2014 | Agri-Fab Agri - Fab 9 cu.ft. Capacity 30"...
How do i replace the on off switch on Hoover U6485900
Make sure the power cord is disconnected! There are two sets of three screws one needs to remove. The first set hold the handle assembly to the sweeper body (there are two near the back of assembly and one in front). The second set is inside the cavity that hold the vacuum powered cleaning tool. There are two at the bottom of the cavity and one at the top. Refer to the Assembly Instructions in the Owner's Manual for help. One can then remove the power leads from the on/off switch, push the switch out, and insert a replacement switch. Pay attention to the color of the wires because some switches apparently work with models having 2 black wires (H-28161075), others with a black and yellow wire (H-28161074), and others with connectors to the wires. Reassemble the sweeper reversing the dis-assembly process outlined above.
Jan 02, 2014 | Hoover U6485900 Bagged Upright Vacuum
Assembly instruction manual for blue hawk spreader
That is a Lowes special item. I would go to Lowes customer service and see if the can copy one from another unit that they have.
Jul 07, 2013 | Blue Hawk 100 lb Capacity Tow-Behind Lawn...
Need parts for a earthway 2050TP pull behind spreader. where can I order them?
go to www.earthway-outlet.com. You can download the instruction manual with a parts diagram, part number. I believe you can order the parts you need from them. Try it.
Good day.
Nov 17, 2009 | Earthway 2050tp Semi - Assembled Estate 80...
Vacuum Power Switch on Handle Doesn't Work
The switch is very cheap. I have the same vacuum. The solution is to stick a thin peice of cardboard under the slide track for the rod in the handle assembly. You will see the rod when you disassemble the handle for the sweeper. Move the on/off switch on the handle assembly a few times and look at the bottom of the of the assembly to see a thin black rod with cut grooves. This rod activates the on/off switch.
There is a little track that this thin rod of plastic travels along. However over time the the plastic rod begins to recess further into this track. The rod still slides but is now to far away to activate the on/off switch. This isn't very technical but just slide a thin peice of hard paper or cardboard between the rod and the slide track.
Make sure the red on/off switch on the sweeper is set to off. Put the handle back with the switch in the off position. Test the sweeper using the handle a few times before reassembling the screws. This fix may not be permanent according to how you have the paper/cardboard set between the slide track and the rod but it works very nicely.
Hope this helps! : )
Apr 08, 2008 | Vacuums
YTL International Push Broadcast Spreader 125 Lb Logo
173 people viewed this question
Top YTL International Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a YTL International Garden Expert? Answer questions, earn points and help others
