Question about Nokia BH-104 Bluetooth Headset
Samsung - Nokia BH-104 Bluetooth Headset
Backup samsung convoy contacts to pc
Because of the importance of transferring contact information from one communication vehicle to another, there are a number of different automated ways to transfer contact information. To import contacts, such as VCF files from computer to Samsung Galaxy S9/S8/S7/S6/S6 Edge, you need to ask help from an Android data transferring program named MobiKin Assistant for Android or Assistant for Android (Mac Version). With it, you can move contacts between your Samsung Android phone and computer in 1 click.
Step 1. Click the above button to download and install MobiKin Assistant for Android on your Windows or Mac computer according to its prompt instructions. Then, launch it directly. After that, you'll be required to connect your Android phone to computer with USB cable or WiFi. Just choose the method for connecting as you like.
Step 2. After connection, you need to do some operations to make the device be recognized by the program. For example, you need to open USB debugging under "Developer" option, and install a right USB driver on the PC. (Sometimes you may need to install the USB driver manually due to unknown reasons when the automatic operation is not working well.)
Step 3. When your Android is recognized by the Android Assistant software, you can see an interface like below. Now, directly click "Super Toolkit" in the top menu, and select "Backup" option.
Step 4. Check the device and click "Contacts", then specify an output folder according to your needs. After that, click "Back Up" button to begin the process. backup-android-files-uwkecbqhxdnurjdgs33nmwp2-4-2.jpg
Complete procedure can be found on below link: 5 Ways How to Backup Android Contacts
Learn More:
How to Import Contacts to Samsung Galaxy S9 S8 S7 S6 Edge
Dec 21, 2012 | Samsung Convoy Cell Phone
Need to unlock my samsung galaxy i577
Hi, What kind of lock has your Samsung Galaxy been locked to? If it is a network lock, You can unlock it safer and easier using unlock code. You can get the unlock code for a Samsung Galaxy from www.onlinegsmunlock.com/samsung-galaxy/rs7wp9/ at affordable cost. Here are the steps for unlocking a Samsung Galaxy,
1 - Switch ON your Samsung Galaxy with a NOT ACCEPTED SIM Card.
2 - Samsung Galaxy will ask for "Password".
3 - Enter the Unlock Code.
Sep 09, 2012 | Samsung Cell Phones
Forgot my password for samsung e 390
Hello Dear,
Type the code * 2767 * 3855 # and the phonewill reset to the factory settings. Other interestingcodes for Samsung phones: * # 0228 # BatteryInformation
* # 0673 # Test MP3
* # 0782 # Date and Time
* # 0842 # VibrationTest
* # 1111 # SoftwareVersion FTA
* # 1234 # Softwareversion (short)
* # 1235789 # StateControl of Integrity
Hardware Version * #2222 # FTA
* # 232337 # BluetoothBroadcast Address View
* # 32489 # State ofCiphering
* # 742695 # Softwareversion, Hardware Version, Date of Last Calibration Radiofrequency
(Equivalent to * # 8999* 8376263 #)
* # 8999 * 8376263 #Software version, Hardware Version, Date of Last Calibration Radiofrequency
(Equivalent to 742 695* # #) * # 1546792 * #Admin settings (WARNING: not to experiment!)
(* # * 73561 # OperatorCode, where applicable)
(* # 2456987 * # MasterKey) # * # 123580 TestMode main menu (not to experiment!, Equivalent to * # 9998 * 324 #)
* # 9998 * 324 # TestMode main menu (not to experiment!, Equivalent to * # 123580 #)
* # 0002 * 28346 # ItemMenu Handset Volume (sub-menu of the Test Mode Menu)
* # 0011 # NetworkConnection Status
(Same as in Test Mode,which not only returns to the main menu of the Test Mode)
* # 7412359 # Test MenuRadiofrequency
* # 9999 * 0 # NetworkMonitor
(Same as in Test Mode,which not only returns to the main menu of the Test Mode) * # 7465625 # setthe Phone List of Blocks # 7465625 * 27 *code # Remove the "PC Lock"
# 7465625 * 638 * Code# Remove the "Network Lock"
# 7465625 * 685 * Code# Remove the "Multi Lock"
# 7465625 * 746 * Code# Remove the "SIM Lock"
# 7465625 * 77 * code #Removes the "SP Lock"
# 7465625 * 782 * Code# Remove the "Subset Lock"
# 7465625 * 228 #Disable "Activa Lock"
# 7465625 * 2827 #Disable "Auto CP Lock"
# 7465625 * 28638 #Disable "Auto Network Lock"
# 7465625 * 28685 #Disable "Auto Multi Lock"
# 7465625 * 28746 #Disable "Auto SIM Lock"
# 7465625 * 2877 #Disable "Auto SP Lock"
# 7465625 * 28782 #Disable "Auto Subset Lock" Malicious code:
* 2767 * 3855 #Reset Full Phone (back as "just bought") * 7465625 * 27 *code # Set the "PC Lock"
* 7465625 * 638 * Code# Set the "Network Lock"
* 7465625 * 685 * Code# Set the "Multi Lock"
* 7465625 * 746 * Code# Set the "SIM Lock"
* 7465625 * 77 * code #Set the "SP Lock"
* 7465625 * 782 * Code# Set the "Subset Lock"
* 7465625 * 228 #Enable "Activa Lock" to restart the phone
* 7465625 * 2827 #Activate "Auto CP Lock" to restart the phone
* 7465625 * 28638 #Turn on "Auto Network Lock" to restart the phone
* 7465625 * 28685 #Turn on "Auto Multi Lock" to restart the phone
* 7465625 * 28746 #Turn on "Auto SIM Lock" to restart the phone
* 7465625 * 2877 #Activate "Auto SP Lock" to restart the phone
* 7465625 * 28782 #Turn on "Auto Subset Lock" to restart the phone These codes areworth a bit more for all Samsung phones, in particular: Samsung E390,Samsung Ultra Video F500, Samsung F510, Samsung F520, Samsung F700, Samsung SGHi520, Samsung i600, Samsung i620, Samsung L760, Samsung P910, Samsung P920,Samsung P940, Samsung SCHB100, Samsung SGH F600, Samsung SGH i550, Samsung SGHJ750, Samsung SGH I600, SGH i607 Samsung Blackjack, Samsung SGH P930, SamsungSGH Z630, Samsung Ultra Edition 12.1 (U700), Samsung Z100, Samsung Z105u,Samsung Z107V, Samsung Z110, Samsung Z130, Samsung Z140, Samsung Z140V, SamsungZ150, Samsung Z170, Samsung Z220, Samsung Z230, Samsung Z300, Samsung Z310, SamsungZ320, Samsung Z330, Samsung Z350, Samsung Z360, Samsung Z370, Samsung Z400,Samsung Z500, Samsung Z510, Samsung Z520, Samsung Z540, Samsung Z550 , SamsungZ560, Samsung Z600, Samsung Z610, Samsung Z620, Samsung Z650i, Samsung Z700,Samsung Z710, Samsung Z720, Samsung ZV10, Samsung ZV30, Samsung ZV40, SamsungZV50, Samsung ZV60, Samsung ZX10, Samsung ZX20. WARNING: Someof these codes may cause blockage or malfunction of the cell, therefore, it isunderstood that you use them at your own risk.
Dec 04, 2011 | Samsung SGH-E390 Cellular Phone
Themes for samsung monte s5230
Direct download themes http://www.mobileheart.com/cell-phone-reviews/samsung-2/samsung-S8000-Jet-1808.aspx http://www.umnet.com/phone/2300-Samsung_S8000_Jet http://gallery.mobile9.com/c/samsung-s8000-jet-wallpapers_2255/1/ http://www.tehkseven.net/wallpaper/samsung-s8000-jet-wallpapers.html FREE Ringtones http://www.mobiles5.com/topic/samsung-s8000-jet/
Jan 28, 2011 | Samsung Cell Phones
I cant find a driver for my samsung to conet with usb cable..
Samsung TV?
Samsung disk-drive?
Samsung digital-camera?
Samsung web-camera?
Samsung cell-phone?
What model?
Have you searched Samsung's web-site?
Dec 01, 2010 | Computers & Internet
Nokia BH-104 Bluetooth Headset Logo
14 people viewed this question
Top Nokia Radio Communications Experts
shaun taylor
Computer Repairing
Computer Repairing
Are you a Nokia Radio Communication Expert? Answer questions, earn points and help others
