Question about Samsung SAMTRON 56E/57E/56V
Samtron 56v monitor circuit diagram
Led blinking
4 Suggested Answers
SOURCE: samtron 56v monitor
Iam having Samtron monitor 56v . one of the pin of the CPU end connector has been broken and required replcement of the whole cable.I am not getting the same cable at Kochi in India. Please help me out.
Posted on Apr 24, 2008
SOURCE: samtron 56v monitor when powered on. monitor power led starts blinking and monitor gives a tick tick sound. have replaced eht and surrounding spares but with no effect. please help
this is due to the abnormal 5v supply to micom.check upthe 5v line.
Posted on Aug 03, 2009
SS PAI
  • 55 Answers
SOURCE: samsung samtron monitor does not work
Please check whether the power cable is properly inserted...
The power button of this model fails with time.You need 2 press it tightly and hold it till the LED is on....
try this...
Hope this helped...
Posted on Jan 05, 2010
Samtron 56v power
solution 1 please replace the horizontal output transistor in near to line output
solution 2 in case you changed the horizontal output when the problem not solved follow this.
monitor line output transformer burned replace them its kept on monitor from mother board to connect thru picture tube. very carefully to change the part because its have a storings voltage capacity in heavy.
solution 3 check the signal cable
May 01, 2013 | SAMTRON 55V 15" CRT Monitor
I have a monitor samsung and no power on it I check the fuse its ok and i found a power on power circuits what i can do
go to authorized personnel...don't try to do it by urself..
it contains more than 25000volt at EHT & power supply is most complicated circuit of monitor, so don't try it.
Aug 23, 2010 | SAMTRON 55V 15" CRT Monitor
I have a Problem in vga cable of my Samtron 56V Monitor.. Pls tel me how to replace
connect another cable as follows
1-red
2-green
3-blue
4-gnd
5-gnd
6-red gnd
7-green gnd
8-blue gnd
9-+5v from display card
10-stand by
11-synchronus ground
12-sda
13-hsync
14-vsync
15-scl
the numbers of pin are given
under pin
May 20, 2010 | SAMTRON 55V 15" CRT Monitor
Samtron Monitor 56V Display Problem
your power supply is probably bad. open the case with it unpugged and look for leaking or crowned capacitors. most electronic repair shops can replace them for you
Jan 10, 2010 | Computers & Internet
Samsung samtron monitor does not work
try this...
Hope this helped...
Dec 21, 2009 | SAMTRON 55V 15" CRT Monitor
Samsung 56V, difficult to switch on the monitor
check the capacitors inside the monitor, as they may be broken, and they start screen up, just change em and it should kickstart fine
Sep 19, 2009 | SAMTRON 55V 15" CRT Monitor
In my SAMTRON 56V monitor problem
my samtron 56v problem stand by when i power off yet i power on it is off position whats problem with me.switch is many time pressing then is on position.what is parts of my monitr suplly fault.wich part is spoil
Jul 02, 2009 | SAMTRON 78DF 17" CRT Monitor
Samtron 56v monitor
HI all,
The problem im facing is, im using a Samsung samtrong 56V monitor, there is horizontal line appearing in the both ends of the monitor screen which gives a mirroring effect. ( for ex: if ya move the cursor on that it will show multiples of cursors displayed in that line only.)
Please suggest me a method to solve this issue. are there any patch avail for this if so please send a link to download.
thanks a lot
Jan 10, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Samtron 56v moniter on but wosulation not coming
samtron 56v monitor wosulation problem how can i sovle this problem
Sep 28, 2007 | SAMTRON 55V 15" CRT Monitor
Computers & Internet Logo
42 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
