Question about Refrigerators
Bosch kan56v40au/04
Freezer not working. Will only go down to about zero degrees centigrade. Fridge ok. No frost build up. No leaks. This board has a PC Board to control operations including temperature. I've changed that already - no change. What should I try next
  • Paul Henderson May 13, 2013
    I have exactly the same model, same problem and have tried the same pcb change with the same result - ie no change. Anyone care to throw some light on this please?
  • 262 Answers
SOURCE: Kenmore Fridge- all lights blinking
sorry to say this but the mother board has took a hit replace this and all will be well
Posted on Jan 01, 2008
  • 90 Answers
SOURCE: FRIDGE/FREEZER MODEL: SR42NMB Multi Frost
You have a clogged defrost drain tube. best way is to thaw unit out. Your vents are being blocked so no air flow is pushed down.
Posted on Jan 05, 2008
  • 139 Answers
SOURCE: Freezer ok fridge warm (15 degrees)
You have a hotpoint mistral f/f i take it in silver..
Check to see if the fan is running at the bottom on the back of the fridge its next to the compressor behind the panel ...
if the compressor is running and the fan is not then your fault is the fan..
IF the fan is running then its the sensors...
These are located in the freezer section, pull out the draws and remove the panel behind it.... six screws.......... you will c threes plugs at the top ledt hand side.. the yellow one is for the fridge the green one for the freezer.... replace both if your freezer is not working...
Also just below the freezer door there is a panel remove the panel and use a vaccumm to clean the fluff that has built up on the coils..
hope this helps if you need anymore help dont hesitate to ask...
by the way the sensors are called evap thermistors...
Posted on Jan 11, 2008
  • 14 Answers
SOURCE: Bosch Fridge Freezer Classixx
This button is the winter/summer setting.
If you switch it on so as the red mark shows this is set for the summer setting.
What it does is allows the interior light to come on very dimly when you shut the door.
The fridge then thinks it is too warm and starts to cool down more, designed for when the ambient temperature is high.
Hope this helps
Deep diver
Posted on Jan 17, 2008
SOURCE: Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
Posted on Nov 23, 2008
What is the normal temperature to set the fridge and freezer
  • A frigidaire should have a temperature of between thirtyseven degrees farenheit (three degrees centigrade) and forty degrees farenheit (five degrees centigrade). Any higher and the food will go off, any lower and you'll lose nutrients and fresh food can be ruined.
  • The ideal freezer temperature is zero degrees farenheit (negative eighteen degrees centigrade) which will store food safely and stop bacteria forming
  • It's a good idea to buy a fridge thermometer and check the temperature if you are not sure it the thermostat is working efficiently
  • If you adjust the thermostat, it generally will take twentyfour hours to adjust the temperature
Oct 15, 2014 | Refrigerators
Fteezer not freezing not at temperature to keep
How do I get the plastic back panel off without breaking it to defrost the evaporator? Bosch No Frost fridge freezer icing up in top third of fridge
You unplug the refrigerator & let it melt &
work on cleaning up the water
If your getting too much ice build up, it could
be that you have a leak & lost refrigerant or
other system that heats things to prevent that
have failed
Have you turned down the thermostat to see if
that helps?
Aug 31, 2013 | Bosch Refrigerators
Frost in the freezer, and ice build up on back under a metal cover
Defrost issue, bad heater or bi-metal our timer, maybe board
Sep 01, 2012 | Refrigerators
Fridge not getting cold.....still
Hello Nick,
Don't let your frustrations get the best of you...
WE can do this...!!
Defrost consists of only three (3) parts...
- Control board (or timer, not in your case:
(see below)).. A common problem.
- Defrost heater element (to melt the "FROST"
(seldom fails)
- DEFROST THERMOSTAT
(to keep the temp DOWN)
The EASIEST but most expensive part is the
DEFROST control board.
Take lots of pictures before removing any wires.
Main Electronic Control Board
Mar 07, 2017 | GE Profile PDS22MHR Bottom Freezer...
I have a bosch fridge freezer model kgu3220 gb. It is ten years old. For the last few days, the fridge isn't cooling but the freezer works fine. The temperature on control panel is stuck on 11 degrees. I...
Once the fridge is shut OFF for few hours to defrost and then switched ON , if the fridge works with cooling , then the fault is with the AUTO DEFROST TIMER or the circuit -maybe the heater, break in the lines to the timer, heater, the fan.
The build up frost will block the flow of cool air to the fridge from the freezer evaporator.
So remove and check.
Jan 13, 2011 | Bosch Refrigerators
Hi there, we recently purchased a Bosch Platinum side by side fridge and freezer model number KAN56V40AU. The problem we are experiencing is that the fridge section is not cold enough and the temperature...
you will be able to get a technician out under warranty to properly diagnose the fault
you do not have to return it as they will come out for the job
call the service agent listed on the warranty booklet
don't touch it your self as that will void the warranty
Jul 14, 2017 | Bosch Refrigerators
My fridge clicking, buzzing and then clicking back off. Inside it was starting to warm up and was starting to leak water onto the floor. Today someone came out and replaced the relay. After 4 hours the...
Hello, no if the compressor is still running and you are not hearing the click you should be ok. It will take approx 8-10 hours for it to get to normal temp. The frost you mention on the freezer panel could be a problem with the defrost system. I would leave it over night and check it tomorrow. If there is a major ice build up comment back and i will assist you further. Mike
Oct 19, 2009 | Maytag Refrigerators
Refrigerators Logo
78 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
