Question about Canon PIXMA MP780 All-In-One InkJet Printer
My printer says that the ink is empty however I just put a new genuine canon cartridge in. It originally said wrong cartridge so then I put a new one in. I tried to do a auto head align but it won&#
    New Friend:
  • 21 Answers
print head(cartridge carriage unit) is complaint, you have to replace.
Posted on Dec 18, 2017
  • 385 Answers
SOURCE: Canon PIXMA MX330 multifunction printer. I get a
unfortunatly not!The m/c will print each and every fax!I can suggest getting a fax to email nr and recieve the faxes on your pc and then printing what u need!Memory does keep about 258 pages depending on the coverage on the pages!
Posted on Mar 31, 2010
  • 56 Answers
SOURCE: Pixma MP780 Printer, not printing
sometimes those measures of ink levels are not very accurate. actually they're usually rather far off... try a new cartridge Usually the easiest solution.
Posted on Aug 17, 2007
SOURCE: Does not print on paper
Experienced the same problem a few months back with my new MP600 .. had to take it to an authorised repair centre where they replaced the print head .. all good since
Posted on Nov 04, 2007
  • 2306 Answers
SOURCE: Canon PIXMA MP500 New Black ink cartridge produces no ink
If you don't use it very often the black could have dried in the printhead, and you will need a new one. Another possibility is that the purge unit is not cleaning and priming the printhead properly. I have seen several defective purge units. For 1 year it can be replaced under warranty, after that it is a $90.00 repair job in the shop.
Posted on Jun 25, 2009
  • 739 Answers
SOURCE: head alignment
Your problem sounds more like a blocked nozzle and that would require a cleaning routine to be run.
You need to access the tools section of your printer. This is often done in the printer utility app if the printer doesn't have direct access on its own control panel.
Posted on May 18, 2010
When I put a new Black ink in my Canon MX452 it shows my black as empty
if the black cartridge is genuine and new...take it back. It is faulty.
If the cartridge is refilled or compatible...hold the STOP button for 6+ seconds to disable ink monitoring. This should clear the 'empty' error and the printer should work again.
good luck!
May 17, 2014 | Canon PIXMA Office Equipment & Supplies
Ink is leaking out of ink tanks and filling up maintenance cartridge. Had a extra print head (used) and it did the same thing
1- Remove ALL the ink cartridges from the printer
2- Check that there is no residual tape on the cartridges.
3- Then clean the contacts on the cartridges as well as inside the printer itself
NOTE: Clean the contacts with a small amount of warm water on a cotton swab until no ink comes off on the swab.
4- If any of the other cartridges are low, empty, leaking or bulging, replace them with genuine and original ones.
5- Then turn off the machine and unplug it for 60 seconds
6- Insert the cartridges and check to see if the issue persists
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Canon Printer Support
Feb 26, 2014 | Canon imagePROGRAF W8400 InkJet Printer
Unrecognized ink cartridge
This model Canon/Epson printer may only let you use genuine Canon printer cartridges. If you try to refill these ink cartridges it will not work because the Canon cartridges have an embedded chip in the cartridge that detects the empty cartridge even though it has been refilled. This means you need to purchase and install genuine printer cartridges.
May 06, 2013 | Canon MP250
I have replaced the empty black ink and the light wont go out. What do I do?
....So hold down the stop/reset button for more than 5 seconds when the PC tells you the cartridge is empty and stops you. Won't make the light go out (only new genuines will do that) but you will be able to print.
Aug 07, 2010 | Canon PIXMA MP240 All-In-One InkJet...
Canon MP390-error message
You need to use brand new original genuine canon cartridges. with most inkjet printers the refills and the replica cheaper cartridges do not work
Jul 26, 2010 | Canon MultiPASS MP390 All-In-One InkJet...
Hi! I has refill my ink cartridges for canon mp490 printerbut I don't know how to reset it to make it print.i know you may have more idea then me.thanks for your help.thanks
Welcome to the world of Canon. Simply put, the PG-210 CL-211 cartridges have what I like to call "digital fuses" built in. One fuse for "new" and one for "empty". When you install a new Canon cartridge both "digital fuses" are intact. The "new" fuse tells the printer that it is a new genuine Canon cartridge and resets the page counter internal to the printer. With the page counter reset, the printer "blows" the "digital fuse" and that cartridge enters the used state. When the page counter on the printer believes the cartridge to be completely empty it will "blow" the second "digital fuse" and the printer will from then on refuse to recognize it as a valid cartridge. Some claim to have ways around this, but Canon really has won this battle. My Cartridge World store does not refill these cartridges and does not recommend refilling them. Buying original Canon cartridges is what we recommend.
Jun 14, 2010 | Office Equipment & Supplies
I replaced the black in cartridge on a Canon MP620 with a non-OEM cartridge. Everything seems to work fine, bu I keep getting a message that the cartridge is empty. I moved the chip from the original...
When you moved the original chip to the new cartridge, the chip is saying the cartridge is empty. Try removing the chip and the printer should know the cartridge is not empty, but might give you a message that it is not a genuine Canon cartridge.
May 09, 2010 | Canon PIXMA MP620 All-In-One InkJet...
Put in a compatible red ink cartridge but no red ink printed. Can't put in the original cartridge in to verify the printer as it is detected as empty. However, for other colors that I replaced with same...
So, is the new cartridge "compatible", or is it not as compatible as they claim?
Try a "genuine" replacement cartridge.
Start the software that came with the printer.
There is a "ink-jet test" utility, and a "head-cleaning" utility.
Run each of them, to see if anything is "clogged".
Dec 05, 2009 | Office Equipment & Supplies
Hi , use the genuine canon ink cartridge the printer can identified the ink cartridge. and colors.
Feb 19, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
I posted the original problem. Although the cartridge was genuine I had taken it out and reinserted it as I wasn't sure I had loaded it correctly the first time. Advice from my local retailer was that this was a mistake. Canon PIXMA printers no longer recognise a cartridge once it has been removed. Solution was another new cartridge which I shan't remove until it's empty. When this second cartidge is empty I shall try the first cartridge again as it is still full and unused. It has yet to print anything! Why Canon's helpdesk couldn't help is a mystery. I conclude that Canon's printer management systems are unfriendly to users. They are friendly only to Canon. I hope my experience will help others especially those considering buying a Canon printer. dudbob
Jan 22, 2007 | Canon PIXMA iP1600 Printer
Canon PIXMA MP780 All-In-One InkJet Printer Logo
132 people viewed this question
old marine
old marine
